image sensor sizes
10 replies to this topic
#1 ccs_hello
ccs_hello
Posted 03 April 2014 - 08:08 PM
Time to add some more popular sensor sizes:
Clear Skies!
ccs_hello
  • sharkmelley, elpajare and ChristopherL like this
#2 ccs_hello
ccs_hello
Posted 03 April 2014 - 08:10 PM
And by numbers:
Clear Skies!
ccs_hello
  • sharkmelley, ram812, ChristopherL and 2 others like this
#3 CounterWeight
CounterWeight
    Star walker
  • Loc: PDX, OR.
Posted 03 April 2014 - 10:16 PM
This should get a sticky? Nice work on this presentation, like that you added the circles for figuring the diagonal of the flat image field.
  • ram812 likes this
#4 fishonkevin
fishonkevin
  • Loc: Michigan
Posted 03 April 2014 - 10:37 PM
We get to many stickies with the contests. But I am going to add a link in the 'Best Of' thread, like I did with MR's.
  • ram812 likes this
#5 CounterWeight
CounterWeight
    Star walker
  • Loc: PDX, OR.
Posted 03 April 2014 - 11:05 PM
Thanks Kevin :)
#6 ccs_hello
ccs_hello
Posted 04 April 2014 - 12:42 AM
Thanks folks :)!
18mm and 25mm diameter circles reflect two most commonly used image intensifier image plane format.
Clear Skies!
ccs_hello
#7 mmalik
mmalik
    DSLR camera modifications
  • Loc: USA
Posted 04 April 2014 - 02:46 AM
Image circles/sensors...
  • philipus likes this
#8 ccs_hello
ccs_hello
Posted 10 January 2017 - 08:11 AM
Just to add the explanation of the type-X format....
Image sensor size in inch unit, was originated in the old vacuum tube based image sensor era, e.g., Vidicon.
In that era, the size is based on the required image circle size in optical format.
The name is always preceded by "type-", e.g., type-1" Vidicon tube.
To map to reality, you have to de-rated the number by 66% approx.
Marketing like that (e.g., 1 pound can coffee) thus this representing method stays.
This type of "inflation" is no longer used, when being expressed in KMS format, e.g., a diagonal-6mm image sensor, indeed would have a true diagonal size of 6mm in its imaging area.
Clear Skies!
ccs_hello
#9 Alex McConahay
Alex McConahay
  • Loc: Moreno Valley, CA
Posted 10 January 2017 - 08:38 AM
How did the 1/2" (for instance) get its name? Its measurements do not seem to be related to half an inch.
Alex
#10 waitingForTheMiracle
  • Loc: Norway
Posted 10 January 2017 - 08:58 AM
The inch-based formats were named from the outer diameter of the vacuum tube that captured the image. The actual image area was quite a bit smaller, partly due to the thickness of the tube walls.
When we got electronic sensors, they continued the naming tradition. So an "x inch" sensor means that if you were to make a vacuum tube with the same actual imaging area, the outer diameter of that tube would need to be around x inch.
#11 Alex McConahay
Alex McConahay
Posted 10 January 2017 - 04:03 PM
Thanks......
Next question----
What is a vacuum tube?
(just kidding.)
Alex
