USB corded shutter control for Nikon
#1
Posted 08 April 2014 - 09:22 PM
Obtain
- a suitable USB-serial dongle (that has a RTS output),
- Nikon corded shutter remote MC-DC2 (or a clone: about $3),
- one PNP Epitaxial transistor (e.g., 2SA1015, BC556, 2N5087, NTE234, etc.) <-- this type has low Vce(sat)
- one 4.7K ohm 1/8W resistor,
- two Germanium diodes (e.g., 1N34 or 1N60), and
- a pair of thin wires which goes in between USB dongle and the MC-DC2
Total cost should be less than $20.
Finished product first.
(No need to use the manual control MC-DC2 during computer remote control operation.)
BTW, I use Stark Labs' "DSLR Shutter" (free) to control it.
Clear Skies!
ccs_hello
- calypsob, rbh, daltomagne and 1 other like this
#2
Posted 08 April 2014 - 09:27 PM
Top contact: "Focus" (yellow wire)
Middle contact: "Common" which is the camera Ground (white wire)
Bottom contact: "Snap" (red wire)
The glass diodes I used are 1N60. Black band facing the RED wire.
BLACK wire goes to the center contact.
NOTE: Germanium diode is essential. fleabay sells them 3 pcs for $1.
Clear Skies!
ccs_hello
- calypsob and daltomagne like this
#3
Posted 08 April 2014 - 09:34 PM
Item 370668345808.
Solder the PNP transistor (2SA1015.)
RTS thru 4.7K resistor (yellow-violet-red) to 2SA1015 Base.
2SA1015 Collector connects to Ground. This pin is shutter control's "Common" (black wire.)
2SA1015 Emitter connects to shutter control's "combined diode output" (red wire.)
Clear Skies!
ccs_hello
#4
Posted 08 April 2014 - 09:45 PM
P.S. similar project/previous linkie http://www.cloudynig.../Number/6444548
Clear Skies!
ccs_hello
- calypsob, cmooney91 and daltomagne like this
#5
Posted 09 April 2014 - 12:08 AM
#6
Posted 09 April 2014 - 06:32 AM
All I can say is I might consider giving out 2 Germanium diodes, 1 PNP transistor, and 4k7 resistor for free.
Clear Skies!
ccs_hello
#7
Posted 09 April 2014 - 02:12 PM
I would need to see each component from multiple angles.
#14
Posted 09 April 2014 - 11:16 PM
Solder the YELLOW (Focus) wire to the non-banded end of the Germanium diode (1N34).
Solder the RED (Snap) wire to another non-banded end of the Germanium diode (1N34).
A spare 1N34 Germanium diode is shown. Buy the correct type, not Schottky Silicon diode type!
Solder the other end (black band end) of the diodes together.
Now solder red wire (came from the USB-serial dongle) to the "black band" side of the diodes.
Solder the black wire (from USB dongle) to the MC-DC2's white wire.
Technical note: for Nikon, both focus and snap are needed; for Canon, "snap" is good enough thus no diode needed (ignore "focus" lead.)
#16
Posted 10 April 2014 - 04:20 AM
I can't imagine two exposed wires like that would be very solid nor durable, as I would be attaching the setup to a 50-foot USB cable and operating things *somewhat* remotely (read: from inside the house with the telescope about 50' away from the front door).
I would think that housing everything in the existing controller and using it as a junction box would work (with stripping the OEM innards), no?
#17
Posted 10 April 2014 - 07:17 AM
Yes, keep the original USB dongle's cable and strain relief.
Just use the dongle's Black (GND) and Yellow (RTS) wires to solder to the transistor elsewhere (e.g., inside the MC-DC2 remote control box or use a small capsule as the container.)
Clear Skies!
ccs_hello
#18
Posted 10 April 2014 - 04:31 PM
Let me know if I missed anything:
1.) Aforementioned USB dongle.
2.) 10pcs 1N34A Germanium Diodes
3.) 100pcs 4.7K-ohm resistor
4.) NTE234 transistor
5.) Spare MC-DC2 cable release.
#19
Posted 10 April 2014 - 08:07 PM
Yes, you have all parts. (Assuming you will put the transistor inside the MC-DC2 controller unit, so you don't need the extra red-black wire pair as I did.)
BTW, NTE234's pinout is the same as 2SA1015's, so you will be fine.
Once you complete the project, please post some pictures.
Now the long wait (for orders to arrive) begins.
Clear Skies!
ccs_hello
#20
Posted 12 April 2014 - 08:44 PM
#21
Posted 19 April 2014 - 09:40 PM
#22
Posted 19 April 2014 - 09:47 PM
Great work Steve!
(I also tested it on my D5100 BULB setting.)
Clear Skies!
ccs_hello
#24
Posted 18 May 2014 - 07:12 AM
For some Nikon models (D1H, D1X, D2H, D3, D4, D200, D300, D300S, D700, D800, etc.), MC-30 (or clone) cable <-- "circular shape connector" is needed, as opposed to MC-DC2 rectangular shape connector.
D70S and D80 need MC-DC1 cable.
Note to DIYers: I can ship you partial parts (just cheaper components) for free, if you'd like to go for the DIY route. Just PM me.
Clear Skies!
ccs_hello
- LauraMS likes this
#25
Posted 18 May 2014 - 07:20 AM
Hope the list will grow.
Clear Skies!
ccs_hello
