Tasco 6TE-5
#1
Posted 19 April 2014 - 03:47 PM
#2
Posted 19 April 2014 - 04:24 PM
I really don't use it much since I found an Edmund Voyager 6001 that is a very sweet little scope and way more usable. But I am keeping the Tasco to remind me where I started in this hobby.
Dave
#3
Posted 19 April 2014 - 04:27 PM
#4
Posted 19 April 2014 - 04:38 PM
Dave
#5
Posted 19 April 2014 - 04:44 PM
I am using mine with various Orthoscopic eyepieces which I have collected over time. Not to pun here, but I like to use it to observe... The Moon. The supplied eyepieces work well enough, but if you can come across any Celestron/Vixen Orthos, you will be in another class.
I have used a 6mm with great success, A 5mm is still okay but becomes too dim for the best of views.
They cut corners with the baffling. Contrast suffers a bit. I will someday get around to doing something about that...
#6
Posted 19 April 2014 - 04:49 PM
With all the cheap alt az mounts out there I might be able to piece something together. It would be fun.
#9
Posted 19 April 2014 - 05:00 PM
Thank member CharlieB for this:
2" conduit clamps from HomeDepot or elsewhere.
That's brilliant! Are those clamps on a dove bar on the other side of the scope? I can't quite tell.
#10
Posted 19 April 2014 - 05:05 PM
My Sears/Tower 50mm is on a Celestron dovetail bar scrounged from somewhere. But uses the same rings.
#14
Posted 20 April 2014 - 03:55 PM
I'm visually not getting it: don't know how this
http://www.garvinind...uit/Conduit-...
got looking like whats above.
#15
Posted 20 April 2014 - 04:35 PM
#16
Posted 20 April 2014 - 05:18 PM
I absolutely cannot do the search. It really is not working for me. I can't figure out why. Help anyone?
#17
Posted 20 April 2014 - 05:38 PM
#18
Posted 20 April 2014 - 05:44 PM
#19
Posted 20 April 2014 - 06:13 PM
Ha! Don't know for sure, but I think it might be this: http://www.garvinind...uit/conduit-... Looks like it!
That's it Frank! Eureka! Looks just like scope rings :-). Thanks so much-- a life saver.
#20
Posted 20 April 2014 - 06:29 PM
I buy mine at Home Depot. I have a lot of 40 and 50mm scopes and they work like a charm.
Charlie, I wonder if this very clever fix would also work for 60s? There was a thread about how hard those rings are to find. Ever tried it on light weight 60mm OTA?
#21
Posted 20 April 2014 - 07:19 PM
#23
Posted 20 April 2014 - 09:51 PM
I think you can find conduit hangars that will work with 60mm scopes. I'll check tomorrow on the size.
