Mystery of the melting binocular
135 replies to this topic
#26 schang
schang
  • Loc: columbia, sc
Posted 21 June 2015 - 05:16 PM
Talcum can help, though it is only a temporary fix... The oils in your hands, whether coming from  your own body, or other sources, can be effective plasticizers, which overtime can work into subsurface of rubber and soften it. When that happens, it becomes sticky.  The more of them, the stickier that area becomes.
#27 MartinPond
MartinPond
Posted 21 June 2015 - 06:50 PM
The most common polymerizer used in China is Lead,but it's dangerous to rub lead powder
  and hold it in your hands.  I  was speculating ... maybe magnesium powder would help
  (a magnesium 'fire starter' for camping rubbed on #400 emery paper)
Might be messy,of course.
#28 schang
schang
  • Loc: columbia, sc
Posted 21 June 2015 - 07:21 PM
Yes, you are speculating...
#29 MartinPond
MartinPond
Posted 21 June 2015 - 10:13 PM
I should be able to move forward to experimentation soon, as it pertains to the magnesium.
As regards the lead:
http://www.cbsnews.c...-not-just-toys/
I asked  a chemist friend about the California warning labels...I thought it was just the
surface.  It's all the way through when lead is there.
Edited by MartinPond, 21 June 2015 - 10:51 PM.
#30 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 22 June 2015 - 06:06 AM
I have a pair of six-year-old 15x70 Celestrons that have started to "melt" around the areas that I grip.  I do use deet-based insect repellent.  I'm not sure this would have happened if I didn't use the deet.  Does anyone know for sure?
In any case, wiping the affected areas with Goop Off seems to have stopped the melting, or at least slowed it down.
I'm thinking about buying a pair of Canon IS binos.  Maybe I should clean my hands with a moist towelette after applying deet repellent.  No way I'm not going to spray myself with repellent before I go out in the warm months.
#31 schang
schang
  • Loc: columbia, sc
Posted 22 June 2015 - 07:07 AM
There are a lot of different types of plastics around the house, which contain various additives to achieve specific properties for desired performance.  The lead you linked in your quote is not in the metal form, but a chemical compound, likely a hydrocarbon/other elements compound with lead in the bond.
Now, I do not know exactly what you are trying to achieve... Be careful with the magnesium ( and aluminum) fine powder/dust...please read the following link before you do anything
http://nj.gov/health...nts/fs/1136.pdf
#32 Ravenous
Ravenous
  • Loc: UK
Posted 22 June 2015 - 07:10 AM
Somewhere I saw kits of pre-cut soft leather, which someone was marketing for people who restore olde-style film cameras.  (Olympus Trip 35 and so on.)
It made me think maybe someone with this decayed grip problem could use an attractive replacement material... provided the grip shape is reasonably flat and doesn't have too many curves, a flat piece of material could be stuck on top with a bit of work.  I think there were instructions recommmending a common contact adhesive for the job.
Just a thought for those of you with expensive binoculars, which have succumbed to this problem...
#33 Sarkikos
Sarkikos
Posted 22 June 2015 - 10:26 AM
You could always cover the affected areas with Velcro.  Would you prefer the ribbed or furry side?
:grin:
Edited by Sarkikos, 22 June 2015 - 10:27 AM.
  • Ravenous likes this
#34 Binojunky
Binojunky
Posted 23 June 2015 - 10:37 AM
Yes wipe your hands, I once saw a owner of a brand new pair of Fujis try to put them down only to find them melted to his hands, the palm prints were permanent, other options are light cotton gloves like they use when handling artifacts or a clip on bug repellant like the one by Woods Off, TD.
#35 Sarkikos
Sarkikos
Posted 23 June 2015 - 10:46 AM
I have used the clip-on repellents, and also the kind you can set on your observing table.  But I always like to spray some repellent directly on myself as extra insurance.  I guess I need to buy a jumbo box of moist towelettes.
Edited by Sarkikos, 23 June 2015 - 10:46 AM.
#36 FLYFRICK
FLYFRICK
Posted 18 September 2016 - 09:18 AM
After calling Cannon re my 10x30 IS binoculars starting to melt while stored in the case in air conditioned room, they told me to send them back for repair. I was sure they knew about this problem and would fix it. Next thing I get from them is a repair estimate for $362.40!!! That's about what they cost new when I bought them ten or so years ago. I asked for a trade in allowance - no reply. they have only been used occasionally at sporting events. No
Then I googled 10x30IS cannon melting and saw all kinds of articles...wish I would have done that before the agony of a visit to the post office to ship my precious cargo. I will call them tomorrow to tell them how not pleased I am with their expensive products and their total lack of customer service.
Caveat Emptor... :mad:
From this forum I have learned to try goof off, wd40, coconut oil and baking soda, Windex, Alcohol,etc. Can anyone give me a definitive piece of advice on the best approach to remove the soft sticky goo that will also last?
THANKS  Bill
  • done and koeb like this
#37 Bonco
Bonco
  • Loc: Florida
Posted 18 September 2016 - 03:30 PM
I don't think melting surfaces are unique to Canon products. I have a Celestron bino and a an Oberwerk where the painted and/or plastic parts turned terribly sticky. I have a BSA rifle red dot scope that did the same thing. Heavy rubbing with a cloth and WD 40 helps clear it up but don't think it cures the problem. None of my instruments have been exposed to the discussed contaminents. It seems to me there is a issue with the chemistry of products mostly from China. Probably other manufacturers too. If someone has a better way than WD40, let me know because it takes a lot of scrubbing.
Bill
#38 hallelujah
hallelujah
  • Loc: North Star over Colorado
Posted 18 September 2016 - 03:47 PM
Bill
#39 Mike G.
Mike G.
  • Loc: Oberlin, Ohio
Posted 19 September 2016 - 03:07 AM
There are people who can remove the degraded coverings and replace them, making your ugly binos look like new again
http://www.suddarthoptical.com/
Much cheaper than the Canon price
my old 8x56 Celestron Ultimas had this treatment and I'm quite happy with the results.
#40 Pjames
Pjames
Posted 14 October 2016 - 02:38 PM
I'm coming in late to the discussion, but my Canon Image Stabilizer 10x30 IS case has indeed become very sticky and unusable, and I'm out of ideas on how to remove the stickiness. I've tried isopropyl alcohol, goo gone, nail polish remover, and more with zero success. The binocs were seldom used and kept in a room temperature drawer in our living room. Any advice?
#41 MartinPond
MartinPond
Posted 14 October 2016 - 04:47 PM
The most common type (or the only type I actually have seen)   stickiness is this thin layer of semi-gummy
stuff put over hard plastic to make it feel like rubber. The best stuff I have used on it so far is
coconut oil (very common, in jars at the grocery store) mixed with baking soda to make a paste,
left on in a thin film for 2-5 minutes, and then scrape with fingernails or a plastic knife .   It's been magic.
It really undercuts the stuff's hold on the plastic beneath.
A mild pot-scrubber might do it well too, but you'd need more paste and you might force it through crevices.
Edited by MartinPond, 14 October 2016 - 04:49 PM.
#42 FLYFRICK
FLYFRICK
Posted 14 October 2016 - 05:00 PM
GOT THE BINOCS BACK FROM CANNON AFTER NOT WANTING TO SPEND THEIR ORIGINAL COST ON REPAIRS. THEN I REMEMBERED A BUTTON IN A MERCEDES I OWNED THAT DEVELOPED THE SAME PROBLEM; STICKY AND GOOEY TO THE TOUCH. I PAINTED THAT BUTTON WITH CLEAR NAIL POLISH, WASN'T REAL PRETTY BUT IT SURE WASN'T STICKY ANYMORE.
DID THE SAME TO MY BINOCS. QUICK CHEAP FIX...NOT PRETTY BUT QUITE FUNCTIONAL.
#43 MartinPond
MartinPond
Posted 14 October 2016 - 05:09 PM
That's a new trick.
Good to add to the whole thread!
#44 Grimnir
Grimnir
  • Loc: London, England.
Posted 16 October 2016 - 03:40 AM
My Canon 10x30 IS suffers from this problem. I lent them to a neighbour in the summer and they came back in melt mode possibly because he had sun cream on his hands when he used them - unfortunately I forgot to tell him not to use lotion when using binos. I think the chemical reaction is still progressing - albeit very slowly - but I don't know how to arrest it.
Optically, of course, they're unaffected but it's still very annoying.
Graham
#45 MartinPond
MartinPond
Posted 20 October 2016 - 09:31 PM
You just remove the scummy bumper-sticker-like layer.  It's fairly thin.
Usually the reaction is already through the surface cladding and hard plastic awaits beneath.
#46 Binojunky
Binojunky
Posted 21 October 2016 - 11:08 AM
Deet did the damage, if you didn,t use it then they would have been fine IMHO, TD.
#47 R1200C
R1200C
  • Loc: Eastern Ohio
Posted 27 December 2016 - 09:01 PM
Just pulled my Canon binos, (12x36 IS) out of the case and their totally melted, kept inside, have never taken them outdoors, have never in my life purchased bug spray or sun screen.  Just poor quality.
  • Bonco likes this
#48 Mauikj
Mauikj
  • Loc: Maui, Hawaii, USA
Posted 29 December 2016 - 05:47 PM
I have the Cannon 10x42 IS binos.  After about 1.5 years they started getting sticky.  I don't use bug spray or lotions of any kind.   They were only used a few times so it is very disappointing that these binos which cost over $1,000 deteriorated so quickly.  Talcum powder (after cleaning with alcohol) helped, but they still look terrible.  Although great to use I would not recommend them due to this issue and the pretty crummy lens caps and flimsy battery compartment cover.  Such a shame as the optics and stabilization are so good.
#49 R1200C
R1200C
  • Loc: Eastern Ohio
Posted 19 January 2017 - 08:21 PM
Quoting myself but good news.  Sent the melted Bino's back to Canon, they gave me an estimate of $370 to fix.  After an hour on the phone, (literally) they agreed to do it at no charge.
#50 psjunkmail
psjunkmail
Posted 16 May 2017 - 04:02 PM
The melting "rubber" is due to the fact it wasn't cured properly....not enough of something improtant.
I worked in the business machine industry as a service rep and we had feed rollers made out of polyurethane.   It wasn't all, but some would revert back to their original liquid state....just like the coating on these Canon binocs.   You could tell they were headed "south", as the roller would start to soften, then get sticky.  In some cases, it would just revert to a puddle of goo.
So, it isn't the bug repellent stuff making it go soft.....
