Nikon D5100 DIY Baader Filter question
24 replies to this topic
#1 fulatoro
fulatoro
Posted 18 May 2014 - 11:11 PM
I finished disassembling my D5100 and was getting ready to install the baader filter. I am not sure how to proceed however. Looking for help from anybody who did this before.
I am installing a BCF-1 filter. The camera is now disassembled, I can see the dust filter glued to the IR/UV filter. I can simply desolder them to remove.
However, once I do, I am not sure where to put the BCF-1 Filter. There is a rubber holder that the CMOS sits into. I think the BCF goes there. The BCF just sits just exactly right in the holder. I am however concerned that it might come loose once I close everything up.
Do I need to use some sort of adhesive?
Any help appreciated.
Moussa
#2 mmalik
mmalik
    DSLR camera modifications
Posted 18 May 2014 - 11:53 PM
See if Canon mod here... helps answer your questions? Regards
#3 fulatoro
fulatoro
Posted 19 May 2014 - 01:45 AM
Thank you. Went through that already. Unfortunately not much Nikon information out there...
Moussa
#4 mmalik
mmalik
Posted 19 May 2014 - 02:06 AM
Some D5100 threads; may try PM'ing folks, including Brent (nofxrx). Regards
http://www.cloudynig...6184871/page...
http://www.cloudynig...6354613/page...
http://www.cloudynig...5923916/page...
#5 SteveRosenow
SteveRosenow
Posted 19 May 2014 - 02:53 AM
Uh, would you mind telling me how you dismantled your D5100?
And more importantly, how big a task is it?
#6 Campos
Campos
Posted 19 May 2014 - 03:33 AM
Hi there,
See if it helps:
http://www.lifepixel...d-diy-tutorials
The 5100 is not listed but it shouldn't be much different from other models.
Greets,
#7 fulatoro
fulatoro
Posted 19 May 2014 - 03:47 AM
Thank you campos. I had also seen the site. Unfortunately, they are not using a BCF1 which is smaller than their filter hence the difference in mountings.
I bought the BCF1 based on reading on CN that it is compatible with D5100. Hopefully one of the professional modders with Nikon experience will chime in with a bit of advice.
#8 fulatoro
fulatoro
Posted 19 May 2014 - 09:28 PM
Anybody... I am really bummed about having having my camera in pieces not being to image... Thanks.
Moussa
#9 fulatoro
fulatoro
Posted 19 May 2014 - 11:14 PM
I followed a couple of links. The job is not especially difficult. It took me 45 minutes to remove the screws and desolder 4 leads on the motherboard. It took that long as I was making sure to label and stick together screws.
http://www.dpreview..../thread/3203819
Look at ifixit link referenced there.
Next is this from life pixel. But frankly the first link is all I needed.
http://www.lifepixel.../nikon-d7000-ir
#10 fulatoro
fulatoro
Posted 20 May 2014 - 12:16 AM
More pictures of where I am in the process.
#11 fulatoro
fulatoro
Posted 20 May 2014 - 12:18 AM
The new Filter and the rubber cover to the sensor...What to do next, options:
1-Remove dust filter and current filter (as seen in picture above) and Use 1mm adhesive tape and glue new filter to current sensor package.
2-Remove Dust filter and try to detach old IR/UV filter and attach the new one (might break something, not sure).
#12 SteveRosenow
SteveRosenow
Posted 20 May 2014 - 01:06 AM
I have a D5100 that has thrown an Autoexposure Error and I wonder if perhaps replacing the board would solve it.
This is an interesting thread, I'll be following up on it!
#13 Campos
Campos
Posted 20 May 2014 - 05:57 AM
There is no problem if you use a bit of silicone to secure the new filter in place, just 4 small blobs at the cornes will do the trick.
On Canons you can remove the dust cleaning filter, just disable the auto cleaning function before you open the camera and it will work fine, on Nikon's I'm not sure if this works too, IMHO removing the dust cleaning filter would be better for astro, but then again I'm not sure if it will bring any error message once it's powered back on.
#14 fulatoro
fulatoro
Posted 20 May 2014 - 11:29 AM
Thanks for the input LuAs. I just got a reply from Brent Oliver from HyperDSLR Mods. I am quoting below:
"The double sided tape is a great way to affix the filter to the sensor.
I would NOT attach to the rubber covering of the sensor but on the actual sensor clear glass.
And yes, just De solder the original filter and put it safely away in case u you decide to revert the camera at a later time. "
I will use some 2mm tape for cell phone screens to affix the new filter.
Something like this, they have a 1mm type, but with long lead time, I will just have to limit the contact area to avoid covering the sensor.
http://www.amazon.co...dible/dp/B00...
#15 fulatoro
fulatoro
Posted 20 May 2014 - 01:23 PM
I saw a few motherboards on eBay from $100.00 - $125.00.
Moussa
#16 fulatoro
fulatoro
Posted 22 May 2014 - 06:47 PM
Finally done. Used double sided 1mm tape to glue the filter to the sensor glass. Thanks for all the suggestions. Now for first light tonight...
I will try and post before/after baader filter mod pictures.
Moussa
#17 fulatoro
fulatoro
Posted 22 May 2014 - 06:49 PM
More pictures
#18 fulatoro
fulatoro
Posted 22 May 2014 - 06:50 PM
Camera reassembled.
#19 mmalik
mmalik
Posted 22 May 2014 - 09:12 PM
Good luck!
#20 Gary BEAL
Gary BEAL
Posted 22 May 2014 - 09:26 PM
Indeed, good luck, braver than me.
Gary
#21 17.5Dob
17.5Dob
Posted 22 May 2014 - 10:03 PM
Gary
I've built every one of my computers from the ground up, but that looks way beyond my skills.
Post some AP's as soon as you get finished.
#22 nofxrx
nofxrx
    Vendor (HyperCams & Mods)
Posted 26 May 2014 - 09:11 PM
Hey Moussa!
Looks good!
You may have an issue there with the tape actually cropping into your FOV/sensor...
The Baader filter is not much larger than a standard APS-C sensor, so you need to use very thin strips of tape in order to minimize the chances of a "mechanical cropping" of the image/sensor.
Best thing to do, and you may have done this (but hard to tell from the images here), is to attach the double sided tape to the sensor first. And when you do, install it so that there is at least ~1mm or more gap between the sensor edge and the tape (when looking straight down at the sensor.
Now, that brings up "what is the edge of the sensor?"
The Green rectangular area in the middle is the only "used" part of the sensor...the gold areas/borders are NOT used..so feel free to cover those up..
Make sense?
Hope this helps, and good luck! :)
#23 fulatoro
fulatoro
Posted 03 July 2014 - 02:01 AM
Thanks for the advice. Unfortunately I only just saw this message. I do indeed have minor cropping issues. Not a big deal but I wish I saw your message before putting it back together.
Here is a first light image of M51
http://www.astrobin.com/full/99882/A/
#24 nofxrx
nofxrx
Posted 03 July 2014 - 02:05 AM
Yea, hard to beat results like that! Nice work!
#25 kalasinman
kalasinman
Posted 07 October 2014 - 10:15 AM
Love to see a before-after of any Ha object.....Jack
