OneSky Newtonian - Astronomers without borders
5216 replies to this topic
#226 MSimmons
MSimmons
    AstroGear Today
  • Loc: California, USA
Posted 22 September 2014 - 10:03 AM
I think with the influx of questions on a shroud I'll document how to make one out of the foam sheet. It took me about 20 minutes to make a shroud that is attached to the top of the OneSky, slides in the OTA when collapsed (credit where credit is due - Steve's design was the inspiration, his mod seems very solid)
Great! And with your permission we'll post the plans on our site.
  • BFaucett likes this
#227 OrdinaryLight
OrdinaryLight
  • Loc: Massachusetts
Posted 22 September 2014 - 09:45 PM
I was out tonight with the AWB 130 for about an hour and a half and had a fantastic session with this fun scope from my red zone back yard (mag 5 stars visible near zenith with some concentration):
M70, M54, M22 - my first ever views of these globs; very low in the Southern sky but M22 was still amazing at 97x with many stars resolved
M29 - the 2.5º TFOV of the scope frames Gamma Cygni, M29, and the double star between them nicely
Albeiro (Beta Cygni) - great color contrast double
Double Double (Epsilon Lyrae) - nicely split at 97x
M57 - good at 97x
Cr 399 / Brocchi's cluster / Coathanger - great in 6x30 finder and 24mm
M27 - large and bright at 97x
M52 - nice at 97x
Double Cluster - wonderful at 27x
  • jlandy and BFaucett like this
#228 SteveG
SteveG
  • Loc: Seattle, WA
Posted 23 September 2014 - 01:56 PM
I look forward to seeing that forum come up. I'll post instructions on how I made my shroud, and other mod's to the Onesky.
  • havasman and BFaucett like this
#229 jlandy
jlandy
  • Loc: Groton, CT
Posted 25 September 2014 - 08:50 PM
Alright, made a new shroud tonight to show how I made mine. Took under an hour, but that was with taking pictures and dealing with the puppy.
First picture: Material List
1
2 sheets of 12x18" EVA foam from Michaels - $1 each
Glue Gun
Razor (or scissors)
Tape Measurer
Optional - straight edge, will help a lot with making clean cuts
Step 1 - Cut the foam sheet
2
the total length you need is 18.85". I have found that finishing with a total length of 18.5" will give you enough leeway to have the shroud slide easily without introducing large gaps. Cut the 2" off the 18" wide foam sheet (save this strip, you'll use this later). Cut an additional 2.5" wide length of the extra foam sheet, and another 2" wide strip
Step 2 - Lay down some glue (sorry about the horrible quality of this picture)
3
Slide the 2.5" strip against the 16" wide sheet. lay a stream of glue across the seam
Step 3 - Glue the 16" sheet and 2.5" strip together with a 2" strip
4
After placing the strip, I used a heavy book to seal the glue. When that has cooled, glue half of the second 2" strip along the edge of the 2.5" strip. this will leave a tab to glue when you roll the sheet
5
Step 4 - Roll the sheet, glue the ends
6
7
This is the only tricky part. lay a stream of glue on the second half of the 2" tab you just glued. Roll the sheet around, and mate the edges. If you have a flat edge or ruler handy, this is a good time to squish the seams together on a flat surface.
Step 5 - cut out the eyepiece hole (no picture, sorry!)
I put the cylinder in the OTA, marked the eyepiece area with a marker, took the cylinder out, cut the section out with scissors, then went to the final step
Final Step - Glue to the OneSky
8
I place a dab of glue on the factor shield, then glue little foam tabs to the telescope to give it more hold. Just be carefull not to make the tabs too large, else you won't be able to put the end cap back on!
Let me know if you have any questions, I'll do my best to clarify everything
  • Jim7728, havasman, Abhat and 11 others like this
#230 jlandy
jlandy
  • Loc: Groton, CT
Posted 27 September 2014 - 08:21 AM
After fighting the dew all night, managed to catch an hours worth of data on a new target - M33! The Triangulum Galaxy
Edited by jlandy, 27 September 2014 - 08:22 AM.
  • havasman, BFaucett, therealdmt and 2 others like this
#231 howard929
howard929
    Member
  • Loc: Low End of High Ground
Posted 01 October 2014 - 09:08 AM
Well, I finally bought a set of metric allen keys for the secondary tilt ( 2mm was the right one, TY.)  and have a chunk of flock board coming in the next day or so. I'll pull the primary out and check the spot location, straighten out the secondary, put something on the focuser threads and with no solid plans in mind, muck around with the flock board. With rain for the next week or so I hope to be ready when it ends for some lunar observing. It's such a sweet looking little telescope. I like it.
BTW, JLandy, you post the most consistently nice photos taken with that little telescope. Keep up the good work, they're most enjoyable. :bow:
Edited by howard929, 01 October 2014 - 09:16 AM.
  • jlandy, BFaucett and Ficere like this
#232 BFaucett
BFaucett
  • Loc: Houston, Texas 29.78° N
Posted 01 October 2014 - 07:18 PM
"Guess what?  I got a fever, and the only prescription is more cowbell of jlandy's photos!"   :cool: :) :grin: :grin:
http://www.dailymoti...ore-cowbell_fun
Seriously, I've very much enjoyed viewing his photos in this thread and I look forward to more of them being posted. :waytogo:
Cheers!
-Bob F.  :)
Edited by BFaucett, 01 October 2014 - 07:22 PM.
  • jlandy likes this
#233 howard929
howard929
    Member
Posted 02 October 2014 - 11:14 AM
As planned, I just removed the primary, 4 phillips head screws and one 3mm allen head screw through the dovetail and find that the mirror clips are too tight and the center spot off by more then 2.6mm. A quick check with a dial caliper shows that it's off center from the edge of the blank by at least 105 thou. Not really surprising finds IME from mass produced DOBS. I'm good with how to get this right and do love to tinker. But now I have work to do. :)
Edited by howard929, 02 October 2014 - 11:16 AM.
#234 jlandy
jlandy
  • Loc: Groton, CT
Posted 02 October 2014 - 11:32 AM
interesting, what effect did that have on your viewing? I'm curious now if I should do the same check
#235 howard929
howard929
    Member
Posted 02 October 2014 - 11:49 AM
I have no clue. Since getting it almost 3 weeks ago it's been sitting in a spare bedroom. Finding the time to check it all out was my issue. Early mornings are best for me so I'll continue working on it tomorrow. At f/5 I'm sure the center spot where it is would have made high power views soft and a loss of snap to focus.
#236 howard929
howard929
    Member
Posted 02 October 2014 - 12:19 PM
J,
Sorry if that seems short. I was typing then got a call on the phone and w/o being able to edit, just posted it. I'm not sure what anyone should do with their AWB and wish for no riots over this.
#237 havasman
havasman
  • Loc: Dallas, Texas
Posted 02 October 2014 - 01:06 PM
 no riots
  :applause:  :applause:
+1
#238 jlandy
jlandy
  • Loc: Groton, CT
Posted 02 October 2014 - 02:27 PM
J,
I have recently joined a local club, looking through my telescope and comparing to the big dobs I would say the views are pleasantly comparable. I really doubt that my OneSky has any assembly troubles, particularly when considering the quality of the pictures I've been able to take (not trying to toot my own horn!). I was more curious than anything
#239 Binojunky
Binojunky
Posted 02 October 2014 - 02:31 PM
Regarding the centre spot, its designed to get you in the ball park, thats why its a good idea to do a final touch up on a out of focus star,this will show up any collimation errors.DA.
  • howard929 and BFaucett like this
#240 BFaucett
BFaucett
Posted 02 October 2014 - 06:49 PM
jlandy,
And, I'd bet you have the most tricked out "two hundred dollar" telescope in the entire club!!!  :grin: :grin: :grin:
Just curious...  What have been some of the club members' comments about your scope?   Had any of them heard of the AWB OneSky before?
-Bob F.
Edited by BFaucett, 02 October 2014 - 07:09 PM.
#241 jlandy
jlandy
  • Loc: Groton, CT
Posted 02 October 2014 - 09:33 PM
jlandy,
-Bob F.
A few had heard from reading the Gizmag review of it, none had seen one in action before though
We had a star party recently, I am very much the new guy, but it was fun having a bunch of the public come back to my telescope to see the view after looking at the same object in a 16" dob. In general the nebula are more brilliant, but the OneSky holds it's own with the globs and open clusters
#242 havasman
havasman
Posted 03 October 2014 - 12:15 AM
Got my 2nd one in today. This one stays with me. I'll get out in the garage tomorrow and build it a stand and watch the moon tomorrow night to prepare for the eclipse party the physics/astronomy department at a local community college is throwing next week. Looking forward to answering the ubiquitous "How much?" question with $200 and watching them start planning in their heads.
  • jlandy likes this
#243 howard929
howard929
    Member
Posted 03 October 2014 - 02:20 PM
I'm totally pumped as well. With all issues out of the way but the flock board, there "should" be an hour of good seeing early tonight before clouds roll back in with the moon well positioned. I'm so ready for this I can taste it!
#244 howard929
howard929
    Member
Posted 03 October 2014 - 02:40 PM
BTW - I'd rather not use the red dot finder so I'm looking for a finder eyepiece for the AWB. The ES 68 24mm "seems" to be pretty much what I'm looking for, kinda wide AFOV and low magnification.
Anyone have a suggestion?
Edited by howard929, 03 October 2014 - 02:42 PM.
#245 Fuzzyguy
Fuzzyguy
  • Loc: Colorado/Kansas
Posted 03 October 2014 - 03:14 PM
I really like my ES6820, but I'm using it with an 8" SCT which is pretty easy on EP's. I enjoy the views with it through my 80ED also with it's over 3º FoV and 4mm exit pupil on large DSO's. Don't have any experience with DOBs though. You might check the total FoV with your system to see if it is larger than with your 2" 30mm before you buy. I'd think that would be a nice "finder" EP.
#246 howard929
howard929
    Member
Posted 03 October 2014 - 04:21 PM
Thank you Larry. That's good advice though I want this finder for one of these that only has a 1.25" focuser.
#247 Fuzzyguy
Fuzzyguy
Posted 03 October 2014 - 08:09 PM
Sorry Howard, I admit to just looking at your equipment list. My bad.   :blush: Looks like a really nice scope though!
Edited by Fuzzyguy, 03 October 2014 - 08:10 PM.
#248 howard929
howard929
    Member
Posted 03 October 2014 - 08:15 PM
It really is a nice telescope. Just came back inside after a good 40 minutes of lunar views. My hopes for this telescope were high and it didn't fail to deliver.
Edited by howard929, 03 October 2014 - 08:16 PM.
  • havasman likes this
#249 havasman
havasman
Posted 04 October 2014 - 12:20 AM
ES68 24mm works very well in the OneSky with 2.51 degree TFOV. It's  w  i  d  e ! And clean too.
I plan to take it to a public lunar eclipse viewing next week so I checked it a bit ago. The moon's sharp without false color and the field keeps it in view for quite a while. It should work well for the general public too 'cause it's so easy to use.
#250 havasman
havasman
Posted 04 October 2014 - 01:20 AM
I like high power views when I can get them. Last week at the club dark site I watched the Copernicus crater for a good while as the light was striking it at a low angle giving the walls and particularly the larger of the 2 central mountains a lot of drama. At 263 and 328x with the XT10i the crater floor and the "smooth" area toward Montes Carpatus were thickly peppered with the tiny-est impact craters I've seen. The light gave the larger peak's spires a particularly spike-y look; like a porcupine or the tail of that dinosaur, I thought.
Tonight I took the OneSky out for a high power spin from my white zone driveway, concentrating on the same crater and the same area. It was a VERY transparent, slightly turbulent, cloudless, severely light polluted sky left behind after a line of showers & storms blew through N Texas this morning. EP's were all 82deg, starting with 6.7mm and working down to 3.5mm and then back up. Exit pupils 1.3mm down to 0.7mm.
The 6.7mm is my highest power ep that comfortably frames the entire moon in view and looked, as expected, crisp and sharp without flaws. The light still fell on the crater at a favorable angle so that the complex walls, twin peaks and the exterior rubble fields all were showing well. 97x, 1.3mm exit pupil, 51 arc' TFOV.
The 5T6 gave a noticeable boost in magnification and remained completely sharp. The mag boost better showed the fine rubble in the crater, the complexity of the crater walls and the odd shape of the large peak. 130x, 1.0mm exit pupil, 38 arc' TFOV This focal length starts to outperform my expectations for the OneSky.
The 4mm UWAN again noticeably boosted the size of the image, showing more detail in the crater floor and starting to show the tiny craters outside the walls toward the nearby mountains when the transparent air would settle for a second or two now and again. The image remained sharp but was more dependent on the air above. This view was the most impressive in how much fine detail of the crater and its surrounding area was visible with the little scope and completely violates my expectation for the OneSky's limits. 163x, 0.8mm exit pupil, 30 arc' TFOV
The 3.5T6, from here on this night and for me, finally ran beyond the point the OneSky could respond to. The sharpness softened. Some of the rubble outside the crater walls lost its texture, as did the interior walls and other features that had been improving with the progression of magnification to this point. 186x, 0.7mm exit pupil, 26 arc' TFOV
 I took a look at Vega, Alberio and Epsilon Lyrae. The views gave no surprises. The 3.5mm continued to fail. In all the others: Vega showed no color or flare. Alberio was beautiful and looked best, on balance, in the 4mm. The double-double split cleanly and showed best in the 5T6.
The results of this little test of the high power capability of the OneSky satisfy me completely and exceed my expectations for the little scope. Another plus is that i am not at all tempted to go buy a 2.5T6 now.
Edited by havasman, 04 October 2014 - 01:27 AM.
