Super Compact Electronic Focuser
27 replies to this topic
#1 GM Carlson
GM Carlson
  • Loc: Conroe, Texas, USA
Posted 20 June 2014 - 08:20 PM
You may have seen my earlier post on the Focuser Project. The basic idea was to come up with a reliable inexpensive ASCOM compliant focuser. Here's my latest go at it. It uses a Teensy 2.0, which is similar to the Arduinos. In fact I was able to port my Arduino Nano code to it in lust a few minutes.
The focuser consists of a small geared stepper motor, part# 28BYJ-48 5V. I was able to buy 3 of these on eBay for $6 total! Although they're faily slow, the fastest speed is about 12RPM, they have quite a bit of torque. They also have very high resolution, 4096 step per revolution. Driving the fine foucus of my Moonlite yields a insanely fine resolution of 0.4um/step.
There is a small single sided PCB that has a ULN2003 and a few passive components. The entire unit runs off power from the USB, much like a small camera.
The coupling to the fine focus shaft has a knurled screw that acts as the clutch. Loosening the screw allow manual control of the course focus.
  • PrestonE, Pinbout and iwannabswiss like this
#2 GM Carlson
GM Carlson
Posted 20 June 2014 - 08:25 PM
The focuser is compatable with the stand-alone and ASCOM driver for the MoonLite focuser. I have run it with Sequence Generator Pro, and it works great. If you'd like to build one for your scope, let me know and I'll send the Arduino C Source code. All you need is the free Arduino IDE and the Teensy add on, which is also free. Or, beter yet, go see that Geek kid down the block.
Here's the acrylic housing I made. The whole unit is not much larger than a focus knob.
  • calypsob likes this
#3 GM Carlson
GM Carlson
Posted 20 June 2014 - 08:31 PM
I forgot to mention the device also supports temperature sensing. The little device in the upper right corner of the PCB is an Analog Devices TMP-36. For test I have it mounted on the board, normally it would have a cable and attached to the tube of the scope.
#4 obin robinson
obin robinson
  • Loc: Norfolk, VA
Posted 20 June 2014 - 09:07 PM
That is freaking awesome!!!!!
obin :bow:
#5 Xephius
Xephius
  • Loc: Houston, TX. USA
Posted 21 June 2014 - 01:55 AM
Bad asteroids.....
This goes on the list of things to build. Very cool project! Do you plan to show this off at a star party any time soon?
#6 GM Carlson
GM Carlson
Posted 21 June 2014 - 08:35 AM
I'll be out at the NHAC star party this evening. I have it mounted on my C1100 which I'll have with me. I think this module (the motor and controller) could be used on almost any scope if the torque requirement are not too high. It works very well on my large format MoonLite lifting a heavy SBIG camera with filter wheel and OAG.
#7 orlyandico
orlyandico
  • Loc: Singapore
Posted 22 June 2014 - 08:13 AM
interesting... i made a similar Arduino application (emulating the moonlite protocol) which i posted on the INDI forum and my blog. although in my case i used the stock Feathertouch motor.
i have tons of those cheap ebay motors lying around. Didn't realize they were beefy enough for these types of applications.
#8 Xephius
Xephius
Posted 22 June 2014 - 08:47 AM
OP,
Can you post up the details on the hardware portion of your kit? I like the mounting bracket and focus drive interface. Can we have PN# and sources?
John
#9 GM Carlson
GM Carlson
Posted 22 June 2014 - 10:41 AM
Yes. I saw your post and that's what gave me the inspiration for the project. I'll have to send you the code. I used the front end of your command processor, but rewrote the parser. Thanks.
I'd post the code here, but I'm not sure how it could be done. I don't think there is a file section.
George
#10 GM Carlson
GM Carlson
Posted 22 June 2014 - 10:45 AM
Xephius, are you a member of the North Houston Astronomy Club? I have a machine shop, so I machined those components from material I had laying around. I could bring the unit to the next club meeting on Friday, and show you how it goes together.
George
#11 careysub
careysub
  • Loc: Rancho Cucamonga, CA
Posted 22 June 2014 - 02:58 PM
This is nifty! I've made this a "favorite thread" for future reference. I would like the source code also, can you post it (how many lines?)?
#12 GM Carlson
GM Carlson
Posted 22 June 2014 - 07:57 PM
The sketch is pretty short and simple. I hadn't though of just posting it in a message. Here goes:
// Moonlite-compatible stepper controller
// Written by George Carlson June 2014.
// This version uses the Tiny 2.0 a uController mased on the Atmel ATMEGA32U4.
// hardware for the remote hand control is not supported.
// Many thanks to orly.andico@gmail.com, for the original command parser, others for bits on code picked up here and there on the net
// Since the MoonLite focuser only works with positive integers, I center (zero) my system at 30000. The range is from
// 0 to 65535, so 30000 is a good round number for the center.
// If the Current Position, or New Position is set to 0, this code will set the values at 30000. The reason for this
// is the system is designed to be set at center, manually focused, then focused in a +/- fashion by the controller.
#define RUNLED 11 /* Amber LED lights whenever motor is active, 11 for the Teensy */
#define HOME 30000
#define MAXCOMMAND 8
char inChar;
char cmd[MAXCOMMAND];
char param[MAXCOMMAND];
char line[MAXCOMMAND];
char tempString[6];
unsigned int hashCmd;
long pos;
int isRunning = 0;
int speed = 2;
int eoc = 0;
int idx = 0;
long millisLastMove = 0;
int Current = HOME;
int Target = HOME;
int DistanceToGo = 0;
int minSpeed = 2;
int maxSpeed = 20;
int testPin = 12;
// Temperature measurement
int temperatureChannel = 0;
unsigned int wADC;
double temperature;
int tempTemp;
#define SCALE 0.488 /* ADC>centigrade scale for my particular Teensy */
#define OFFSET 100 /* 2 * 50 offset for TPM-36 */
// Remote hand controller NOT USED ON TEENSY VERSION (but could be)
int handController = 1;
unsigned int rADC;
int speedTable[16] = {2,2,4,8,10,20,0,0,0,0,20,10,8,4,2,2};
int goTable[16] = {-1,-1,-1,-1,-1,-1,0,0,0,0,1,1,1,1,1,1};
// Motor connections
int motorPin1 = 18; // Blue - 28BYJ48 pin 1
int motorPin2 = 19; // Pink - 28BYJ48 pin 2
int motorPin3 = 17; // Yellow - 28BYJ48 pin 3
int motorPin4 = 16; // Orange - 28BYJ48 pin 4
// Red - 28BYJ48 pin 5 (VCC)
// lookup table for motor phase control
int StepTable[8] = {0b01001, 0b00001, 0b00011, 0b00010, 0b00110, 0b00100, 0b01100, 0b01000};
int phase = 0;
void forwardstep() {
Current++;
if(++phase >7)
phase = 0;
setOutput(phase);
for(int i=0; i < speed>>1; i++){
delay(1);
void backwardstep()
Current--;
if(--phase <0)
phase = 7;
setOutput(phase);
delay(1);
void setOutput(int out)
digitalWrite(motorPin1, bitRead(StepTable[out], 0));
digitalWrite(motorPin2, bitRead(StepTable[out], 1));
digitalWrite(motorPin3, bitRead(StepTable[out], 2));
digitalWrite(motorPin4, bitRead(StepTable[out], 3));
int GetTemp(void)
wADC = analogRead(temperatureChannel);
if(wADC < 20)
wADC = 0; /* no temperture sensor attached (avoid noise)*/
temperature = ((wADC * SCALE)-OFFSET);
// The returned temperature is in degrees Celcius * 2 for benifit on MoonLite drivers
return (temperature);
void readHandController()
// digitalWrite(testPin,LOW);
// rADC = analogRead(handController); /* read twice, keep second reading */
analogReference(INTERNAL);
if(rADC > 20)
// if hand controller is connected
rADC = rADC>>6;
if(goTable[rADC])
speed = speedTable[rADC];
Target = Target + goTable[rADC];
isRunning = 1;
digitalWrite(RUNLED,HIGH);
// digitalWrite(testPin,HIGH);
long hexstr2long(char *line) {
long ret = 0;
ret = strtol(line, NULL, 16);
return (ret);
// start of program
void setup()
Serial.begin(9600);
//setup the motor pins as outputs
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
pinMode(RUNLED,OUTPUT); /* yellow LED */
pinMode(testPin, OUTPUT);
analogReference(INTERNAL2V56);
memset(line, 0, MAXCOMMAND);
millisLastMove = millis();
// Forever Loop
void loop(){
// readHandController(); Not used in Teensy Version
DistanceToGo = Target - Current; /* compute remaining distance to go */
if (!Serial.available()){
// run the stepper if there's no pending command and if there are pending movements
if (isRunning) {
if(DistanceToGo > 0)
forwardstep();
if(DistanceToGo < 0)
backwardstep();
millisLastMove = millis(); /* reset idle timer */
else { /* Check to see if idle time is up */
if ((millis() - millisLastMove) > 5000) {
// if so, turn off motor
digitalWrite(motorPin1, 0);
digitalWrite(motorPin2, 0);
digitalWrite(motorPin3, 0);
digitalWrite(motorPin4, 0);
if (DistanceToGo == 0) {
// if motion is complete
digitalWrite(RUNLED,LOW);
isRunning = 0;
else {
// read the command until the terminating # character
while (Serial.available() && !eoc) {
inChar = Serial.read();
if (inChar != '#' && inChar != ':') {
line[idx++] = inChar;
if (idx >= MAXCOMMAND)
idx = MAXCOMMAND - 1;
else {
if (inChar == '#')
eoc = 1;
} // end if (!Serial.available())
// process the command we got
if (eoc) {
memset(cmd, 0, MAXCOMMAND);
memset(param, 0, MAXCOMMAND);
int len = strlen(line);
if (len >= 2)
strncpy(cmd, line, 2);
if (len > 2)
strncpy(param, line + 2, len - 2);
eoc = 0;
idx = 0;
// the stand-alone program sends :C# :GB# on startup
// :C# is to start a temperature conversion, doesn't require any response (we don't use it)
hashCmd = (byte(cmd[0]) | (byte(cmd[1])<<8)); /* combine the two command charaters into an unsigned int */
switch (hashCmd) {
// GP command Get current position
case ('P'<<8 | 'G'):
pos = Current;
sprintf(tempString, "%04X", pos);
Serial.print(tempString);
Serial.print("#");
break;
case ('T'<<8 | 'G'):
// GT command Get Temperature
tempTemp = GetTemp();
sprintf(tempString, "%04X",tempTemp);
Serial.print("#");
break;
case ('I'<<8 | 'G'):
// GI command 01 if motor running, 00 if not
if (DistanceToGo != 0)
Serial.print("01#");
else
Serial.print("00#");
break;
case ('B'<<8 | 'G'):
// GB command Get current backlight value, always 00
break;
case ('H'<<8 | 'P'):
// PH command Find motor home
Current = HOME;
isRunning = 1;
break;
case ('V'<<8 | 'G'):
// GV command Get software version, always 10
Serial.print("10#");
break;
case ('N'<<8 | 'G'):
// GN command Get new (target) position
pos = Target;
Serial.print("#");
break;
case ('C'<<8 | 'G'):
// GC command Get temerature coefficient, always 2
Serial.print("02#");
break;
case ('D'<<8 | 'G'):
// GD command Get motor speed
sprintf(tempString, "%02X", speed);
Serial.print("#");
break;
case ('D'<<8 | 'S'):
// SD command Set motor speed
speed = hexstr2long(param);
if(speed < minSpeed)
speed = minSpeed;
if(speed > maxSpeed)
speed = maxSpeed;
break;
case ('H'<<8 | 'G'):
// GH command Get half step mode, always 00
break;
case ('P'<<8 | 'S'):
// SP command Set current position
pos = hexstr2long(param);
if(pos == 0)
pos = HOME;
Current = pos;
break;
case ('N'<<8 | 'S'):
// SN command Set new position
if(pos == 0)
pos = HOME;
Target = pos;
break;
case ('G'<<8 | 'F'):
// FG command Start motor command
isRunning = 1;
break;
case ('Q'<<8 | 'F'):
// FQ command Stop motor command
isRunning = 0;
break;
} // end process command
} // end forever loop
That's all folks,
George
#13 Xephius
Xephius
Posted 22 June 2014 - 08:39 PM
First, WOOT on the code snip in forum. ;)
George,
I am not a member, but have been intending on joining... if they will have me! :foreheadslap:
I would love to see it in person. I will bring my 6339. If I do cobble one together, I can think of one or three other forum members with the same scope who would probably be interested... Have you guys through about adding a "manual hand controller"? I think you have a ton of unused IO's on that micro controller. That is something that would be a huge help when using this under normal viewing.
John
#14 GM Carlson
GM Carlson
Posted 22 June 2014 - 11:15 PM
John
The first two versions were manual. See 2nd version
Then I saw Orly's posting on the Indi site. I've written a lot of embedded code over the years, but only test programs and such on PC's. So I am not the one to write an ASCOM driver. Using an existing driver by emulating the MoonLite focuser was a big break.
The manual focuser uses a slide pot with a center detent. Sliding the lever forward moves the motor forward. The further you move the lever, the faster the motor goes. Pulling the lever backwards does the same in reverse. This only requires a single ADC input. The hand controller in the photo uses an 8 pin Tiny25 processor.
#15 orlyandico
orlyandico
  • Loc: Singapore
Posted 23 June 2014 - 12:12 AM
I noticed that you're not using AccelStepper like the version I posted on the INDI forum. I find the use of AccelStepper to be a big plus.
You can use your existing Forward Step and Backward Step functions in the class initializer for AccelStepper, and avoid having to deal with maintaining the position yourself. AccelStepper would also take care of ramping speed up and down for long slews.
#16 macona
macona
  • Loc: Beaverton, OR
Posted 23 June 2014 - 12:23 AM
I plan on using accelstepper on my mod of GM Carson's code with one of the low voltage Pololu drivers. If I ever get it done I will post the code.
#17 Xephius
Xephius
Posted 23 June 2014 - 01:05 AM
You guys are very cool. I really like the CNC enclosures and nice PCB work. Are you etching or using your CNC to cut them?
I am planning to attend on Friday, I am really looking forward to it.
Clear skies,
John
#18 GM Carlson
GM Carlson
Posted 23 June 2014 - 08:35 AM
If I was using a larger stepper motor with significant rotor and load inertia, I would consider ramping the step rate, but with such a small geared motor, there is no need for ramping unless I wanted to run the motor at high speed. Simplicity is the beauty of this design.
The circuit board was mechanically etched on a CNC router of my design. I built the machine for high precision work but also with the 27x48" work area I can do fairly large items. Below is a photo of the machine I built. The circuit board is machined while mounted on a vacuum platen. This keeps the material very flat.
  • tim53 and allardster like this
#19 Xephius
Xephius
Posted 23 June 2014 - 10:35 AM
OOoooohhh so nice....
I really like your table, and use of the tool box. Very cool setup.
I had a HF X2 mill that I converted to CNC with a flood enclosure and started building a tool changer... but it had to stay in Canada when I left... :(
Envy!! Very nice machine.
John
#20 GM Carlson
GM Carlson
Posted 23 June 2014 - 12:09 PM
Oops, I found a bug. When attempting to make moves of greater than 32768. The unit moves the wrong way. Declaring the variables Current, Target, and DistanceToGo as long will cure this.
This is a photo of the driver board with the SMT parts installed. The isolation tracks with cut with the CNC router and then the board will tin plated (electroless Tin).
George
#21 Xephius
Xephius
Posted 28 June 2014 - 12:53 AM
George,
Well, sorry I missed you if you attended the NH Astro Club. The website said General Meetings Friday 27th 11:30pm - Sat 28th 2am.... I have checked it several times over this last week because I took off work to come back from Austin to attend tonight. But as it turns out, the website had a glitch sometime last week and the normal General Meeting times were not updated. :(
I am going to go clean some glass and read forums :shrug:
Clear skies,
John
#22 sn8matt
sn8matt
Posted 05 September 2014 - 09:01 PM
I like this design and am going to try to add a (optional) stand alone hand control for observing. My idea is to use a small project enclosure. Maybe a switch for coarse or fine and a rotary encoder for direction. If anyone has any input on the code to add I'd greatly appreciate the help. Just a point in the right direction would be helpful.
#23 LaughingVulcan
LaughingVulcan
Posted 22 February 2017 - 02:35 PM
I am trying an arduino focuser project very similar to your project described on your blog. I had the same concept to use an existing protocol and ASCOM driver rather than writing a custom ASCOM driver.
I have the Arduino working with the Serial monitor using the Moonlight protocol. It also works well with my old EasyFocus ASCOM driver I have been using for years.
So, I wanted to make sure it works with the current Moonlight ASCOM driver. Hmmm, this is a problem and I hope you have a hint as to what I need to do:)
When the Chooser selects the driver, and the Properties page is selected, it first pops up a screen wanting to know which of the installed Moonlight focusers I want to use. I don't have any moonlights, so the list of focusers is blank. I can't move on to the properties page to set COM port, etc.
I don't know how this list gets populated - I assume I need some dummy entry indicating I have a focuser? How do I set this?
Thanks for any help,
Robert Brewington
BrewSky Observatory
#24 ecjoyner
ecjoyner
  • Loc: Florissant, CO.
Posted 13 April 2017 - 07:07 AM
where can i get this hardware, any sellers ?
#25 wotalota
wotalota
  • Loc: SW New Hampshire
Posted 09 November 2017 - 09:16 PM
There is the myFocuserPro2 project which is documented with part lists and suppliers.
https://sourceforge....focuserpro2diy/
Rating: 5 - ‎3 votes - ‎Free - ‎Windows - ‎Communication
5 days ago - Download Arduino ASCOM Focuser Pro2 DIY for free. Version 2 of the myFocuser Project. Version 2, myFocuserPro2 for telescopes controlled ...
