How I removed the glued-on IR-cut
2 replies to this topic
#1 ccs_hello
ccs_hello
Posted 10 July 2014 - 11:06 PM
Sometimes we received the CCD cam with the UV/IR-cut with AA filter glued on using UV-adhesive. App[lying heat gently from the boundary in four sides of the cover glass allows the glass to be pushed away.
The tools I used are
- I use a heatgun (designed for surface mount devices)
- flat blade screw driver to push the filter glass away
- 91% alcohol to remove residual adhesive on the CCD glass
There may be other methods.
Attached picture: heatgun (feeding hot air)
Clear Skies!
ccs_hello
#2 ccs_hello
ccs_hello
Example fo such CCD (side view)
The SMD soldering unit:
#3 David B in NM
David B in NM
Posted 10 July 2014 - 11:26 PM
Thanks CCS,
Here's a method I use.
http://www.youtube.c...h?v=HSBf_nkTfNE
David B in NM
