Do you refocus with each RGB filter?
10 replies to this topic
#1 moxican
moxican
Posted 12 August 2014 - 10:27 PM
The topic says it all. I have acquired an ASI120MM-S recently, and although I am happy with the camera monochrome imaging is a little new to me. I have googled the subject but all I could came up with is a formula of finding the dept of focus, not exactly what I was looking for. I read it somewhere that different colors of the spectrum has different focus point. I think it said that blue is the one to watch for in that matter.
I use a C9.25 with the camera and usually shoot aroung F20.
Do you guys refocus for each filter? If yes, what is your technique?
#2 Mike Phillips
Mike Phillips
Posted 12 August 2014 - 11:29 PM
I do this, but only because of two reasons.
1) I have a motorized CFW AND focuser which enables me to be lazy, not bump or touch the ota/mount between filter change and focus attempts
2) The focuser (JMI) includes a digital readout and PC control which allows me to 'see' where the focus position I like is.  This means I fiddle with it to see where I think it's best in focus and then can compare it to the other filters.
Typically the R&G are nearly the same in avg and above conditions but the blue tends to be slightly out, typically no more than 2 micron/steps of the focuser.
So, without a motorized CFW OR focuser, I wouldn't bother, but it depends on your filters.  With a good CFW and focuser you can 'tell' how much difference there is which means a LOT just to know, much less control.
YMMV,
#3 leviathan
leviathan
Posted 13 August 2014 - 01:29 AM
Yes, I do refocus from B->G->R->IR and the difference is significant on 5m focus. More than that, difference might be more or less depending on seeing. Least difference is indeed between G and R. Astronomik Typ 2c RGB and Baader 685nm that is.
Edited by leviathan, 13 August 2014 - 01:30 AM.
#4 yock1960
yock1960
Posted 13 August 2014 - 06:32 AM
As Mike said, red and green are close, blue is definitely a refocus. Motorized is probably the way to go, but I haven't added that complexity yet. I don't trust myself to focus on target (except the moon) and slew off to a star to use a focus mask. PIA? Yes, but you want the detail.
Steve
#5 John Boudreau
John Boudreau
Posted 13 August 2014 - 08:21 AM
In case you are assuming your system's critical focus zone (CFZ) in that configuration to be that of a native f20 system, it's not. Your CFZ will still be that of the C9.25's native f10. Any time we use a scope with an auxiliary optic like a Barlow or eyepiece that will be the case.
#6 Sunspot
Sunspot
Posted 13 August 2014 - 09:30 AM
I always plan on refocusing between filters, sometimes it just doesn't seem necessary. I'd definitely plan on refocusing the blue filter and when I use the IR filter, that is a must. Experimentation is a good plan but one of the very best amateur planetary imagers once told me that he always refocuses between filters.
#7 CharlesW
CharlesW
    Long time member
Posted 13 August 2014 - 10:00 AM
I have a motorized focuser, an Optec, and I use a Bahtinov mask to get focused. Firecapture stores the offsets so when I change filters, it refocuses to the new position.
#8 moxican
moxican
Posted 13 August 2014 - 05:33 PM
Wow, lot of info here guys, I appreciate it. I use Baader LRGB CCD filter set. So, it is a good idea to refocus the blue filter, I am not imaging in IR yet. But when I refocus the blue I assume the focuser needs to travel inward, meaning that blue focuses at a shorter focal length a little bit then G and R. I do have a 10:1 dual speed focuser to adjust that small, althogh my filter wheel and focuser are not motorized.
The question is than, how do I know how much to adjust? Is there a way to calculate it and come up with a number say B needs to be readjusted X amount of microns?
#9 WarmWeatherGuy
WarmWeatherGuy
Posted 13 August 2014 - 06:37 PM
You could use a Bahtinov mask on a star with all the filters and write down the offsets for each color (from the previous color). Then use a star to focus the first color and then move by the offset amount after each color change. It is somewhat open loop but only the deltas, which should be small.
#10 John_K
John_K
Posted 30 September 2015 - 11:10 PM
Just re-bumping this topic.
With a Shoestring adaptor and a JMI motorised focuser, does Firecapture know how to reset the focus point for a particular filter as previously set by the user?
Edited by John_K, 01 October 2015 - 01:44 AM.
#11 JoseBorrero
JoseBorrero
Posted 04 October 2015 - 08:27 AM
JMI motorised focuser can try, but since it doesn't have a stepper motor the position might not be accurate.
