I have been thinking about DIY a parallelogram mount for my binoculars or a future binoscope for wide field viewing of the Milky Way and DSO for some time... Originally, I have my eye set on a binoscope with 90mm aperture and 500mm focal length, using the offset method as shown here
http://www.cloudynig...hp?item_id=2438
This method is the simplest way(I think) of DIY a bonoscope without getting into complex alignment/collimation difficulties on the back end. Other method has also been explored with the use of penta prisms which is still doable, but the penta prisms add a hefty cost to the project. However, none of the methods worked out after waiting for the objective lens cells for about 10 months, and still I have no idea when they are available. While waiting all this time, I started the tripod project of making crutch tripod. I made one for my Dob mount for the C102AZ, which worked well. So I made another one for the parallelogram mount with the crutches that I have (but bought another pair for $2.00 at a Goodwell store to make up for the single crutch left over). They are strong and light weight, so light weight that I need to add a weight under the eyepiece tray to ensure that it is not toppled over. Here is the unfinished pic
