3D Printed Coma Corrector
18 replies to this topic
#1 Tucker512
Tucker512
  • Loc: Arizona
Posted 28 August 2014 - 03:34 PM
I thought I would post some details on the 3D-printed 1.25" coma corrector I just made with some stock lenses for my little fast Newtonian.
I fully understand why there is no real market for a 1.25" coma corrector. There are very few fast telescopes that only have 1.25" focusers, and very few owners of such small telescopes are likely to put a several-hundred-dollar wide-field eyepiece on such a scope. But I had an old 4.5" f/8 mirror I acquired and turned into an f/3.4 mirror then mounted it in the OTA for an Orion Starblast (with the metal tube cut off to the correct length).
I primarily made the scope to fit around my 7mm Pentax XW eyepiece, but I also have a 15mm Celestron Luminos 82-degree eyepiece. On the 4.5" f/3.4 it would give a 3.3-degree FOV at 25x. Such a view would be great except that, as is, all you see is the most textbook example of coma I've ever beheld at the eyepiece! Yikes!
So I poked at some design ideas in Zemax using stock lenses and came up with something quite decent using just 3 elements: a plano-convex (PCX) and plano-concave (PCV) together acting as a meniscus lens, and a double-convex (DCX) lens.  Ideally all three lenses would be BK7 glass, but I found the PCX and DCX in BK7 and the PCV in SK18 at Anchor Optics (part of Edmund Optics), all for about $50. I tweaked the design and it works fine with only a slight enlargement of the on-axis spot, but it isn't noticeable at only 25x.
The PCV is uncoated as no coated version was available that would work. My only concern with that is the two plano surfaces of the PCX and PCV lenses mate up. The best solution would be to cement the elements together. The lazy solution that I went with is to space the plano surfaces with shims by 0.25mm = 0.010". Tests on bright targets show no noticeable internal reflections.
The coma corrector reduces the focal length by about 2%, in this case from 377mm to 369mm. The corrector actually pushes the focus back about 9mm, so no extra in-travel on the focuser is required, which is good, because I didn't have a lot left. However, this short outward travel precludes mounting the coma corrector in a barrel with a 1.25" female fitting and set screw, like a Barlow lens; there isn't enough room. Instead, the lens needs to screw into the filter threads on the bottom of the eyepiece.
I originally planned to get the coma corrector's three parts (body, lens spacer, and retaining ring) machined, but then we got a 3D printer at work and I've done nothing but play for 2 weeks... The only thing holding me back from printing the coma corrector parts was how to attach it to the eyepiece since you can't print or otherwise easily cut such fine threads. Then I thought to make slightly flexible tabs that would push out against the female threads of the eyepiece barrel, which worked great. The coma corrector presses into the eyepiece and is held securely, but it is pretty easy to wiggle it back out.  It doesn't seem to wear on the PLA type plastic, and it hasn't loosened up with repeated use.
The spots are significantly better off-axis, with no visible degredation on-axis.  The edge stars aren't perfect, but are rounder and easily 5x smaller!  It makes the 15mm EP completely useable, which was certainly not the case before.
The attached diagram shows the internal layout of the coma corrector and the placement of the lenses. The photos show the corrector by itself (you can see the tabs that hold it into the eyepiece barrel) and the corrector installed on the 15mm eyepiece. All in all a fun little project!
Scott
  • ccs_hello, rnabholz, BoriSpider and 9 others like this
#2 Chriske
Chriske
    Kijkerbouw Urania
  • Loc: Boechout, Belgium
Posted 28 August 2014 - 04:28 PM
:waytogo:
#3 BoriSpider
BoriSpider
  • Loc: S.W.FLA
Posted 28 August 2014 - 10:17 PM
Nice.
#4 cheapersleeper
cheapersleeper
  • Loc: Sachse TX
Posted 28 August 2014 - 10:28 PM
That is fantastic.  Just built a 6" f5 and it would be nice to be able to just use a 32mm plossl.
B
#5 starcanoe
starcanoe
  • Loc: Gulf Coast, Panhandle of Florida
Posted 28 August 2014 - 10:54 PM
Nice indeed.
And much cheaper than a paracorr!
You could put a drop of thick oil between the two lenses to increase light throughput and decrease an ghosting.
#6 coinboy1
coinboy1
  • Loc: Tulsa, OK
Posted 29 August 2014 - 10:34 PM
Super awesome! I love this type of ATMing!!
#7 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 29 August 2014 - 10:40 PM
Very interesting.  Thanks for sharing the details of your creation with us! :waytogo:
#8 ds-in-wa
ds-in-wa
  • Loc: Vancouver, WA
Posted 30 August 2014 - 01:22 PM
What details?  This is a very interesting topic and it would be nice to see spot diagrams and design details (curvatures, thicknesses, spacing, and diameters).
Douglas
#9 Chriske
Chriske
    Kijkerbouw Urania
Posted 31 August 2014 - 02:48 AM
Douglas
agree...!
#10 Tucker512
Tucker512
  • Loc: Arizona
Posted 31 August 2014 - 04:31 PM
Thanks for the feedback.  Here are some more details.
These are the three Anchor Optics lenses I used. Cost about $50 total, but I noticed they are 50% off right now:
AX27253:  25mm x 100mm PCX
AX27982:  25mm x -50mm PCV
AX27744:  25mm x 75mm DCX
Attached are images showing the prescription, spots sizes with and without at the same scale, and a layout of the lenses/mirror.
  • Oregon-raybender, coinboy1, stargazer193857 and 1 other like this
#11 starcanoe
starcanoe
Posted 01 September 2014 - 09:47 AM
Surplus Shed has some coated cemented achromatic lenses that look like the planoconvex and planoconcave ones you have mated together.
And I'd bet they have some coated singlets and doublets that would be in the ballpark of the other lens.
With some research and some fiddling you could probably come up with something pretty nice using those.
They also have bigger diameter lenses. And the best news is the lenses are more like $5 to $7. Wait for one of the major discount sales and get em even cheaper!
#12 Relativist
Relativist
  • Loc: OC, CA, USA
Posted 04 September 2014 - 04:02 PM
are you going to publish the stl file as well?
#13 Chriske
Chriske
    Kijkerbouw Urania
Posted 05 September 2014 - 12:06 AM
And if so, not just the stl file but also the source code file please. If you publish that original file, corrections can be made in case of other eyepiece brand or type.
Best should that file be converted to STP or STEP format first. A STEP/STP format file can be opened in all 3D drawing software.
#14 Heph333
Heph333
Posted 15 April 2017 - 02:00 PM
Bump: would also love an STL file. The lenses are still available... still $50, but I have no idea the dimensions for the spacers.
#15 Tucker512
Tucker512
  • Loc: Arizona
Posted 15 April 2017 - 03:56 PM
Here is the current iteration of the 1.25" coma corrector in STL format:
http://darkskyimages...rrector_STL.zip
It is optimized for a Delos eyepiece.  If the field stop position in your eyepiece is different, the design would probably have to change slightly to be ideal.  If you know what eyepiece you plan to use, I don't mind modifying the file.
The hole in the side of the body is made to be tapped for a small 4-40 set screw to hold the retaining ring.
Scott
  • stargazer193857, Heph333 and cloudypatio like this
#16 Heph333
Heph333
Posted 15 April 2017 - 08:04 PM
Thanks so much. I actually don't even have any eyepieces yet (pretty sure I have some old Kellners somewhere). I'm currently printing new primary & secondary mounts for the mirrors out of an old 6' f/5 I built 20 years ago.
#17 Vla
Vla
Posted 17 November 2018 - 07:49 AM
When I raytrace this prescription, it does correct coma, and flattens the field, but there is a load of spherical aberration instead (3/4 of a wave p-v). Also, primary spectrum is over 0.2mm, i.e. over 3 waves of defocus in the blue F-line, and 1.1 wave in the red C-line. It agrees with raytrace spots presented here, which are about 1/10 of the 400 micron square, or 40 microns in diameter. Airy disc diameter at f/3.4 is 4.5 microns (e-line). Error in prescription?
  • stargazer193857 likes this
#18 ed_turco
ed_turco
  • Loc: Lincoln, RI
Posted 17 November 2018 - 12:14 PM
Kellners are too poorly corrected to show any improvement with a coma corrector.   That $1K Paracorr requires premium eyepieces to work well and thrill the observer.  I learned this the hard way by pairing a Paracorr with, of all things, a Kellner eyepiece!  smile.gif
Twenty years ago.
Edited by ed_turco, 17 November 2018 - 12:14 PM.
#19 stargazer193857
stargazer193857
  • Loc: Southern Idaho
Posted 24 November 2018 - 07:03 PM
You would get some coma correction, but without being able to select the glass type or radii, you could be in for plenty of chromatic aberation and spherical.
