Hello Eric,
I'm so very glad you're enjoying the 127 Mak. I have never used one personally but the overwhelming majority of folk that have used one speak very highly of it. I hope it continues to give you many years of observing pleasure.
Hello Christian,
Thank you for your posts and for those images. Looks like you've been able to manage the telescope's acclimation very well in temperatures significantly colder than where I live.
I just wanted to provide some feedback on my progress over the last several months with the Orion 180mm Mak. I have spent many hours this past winter observing in sub zero temperatures (down to about -7 or -8C) and the instrument has performed admirably. I have seen no need to actively cool the 'scope.
Sometimes I have to teach late into the evening (until 9pm) and so my office has to be heated throughout this time. But on such evenings I just set the instrument outside on the pavement in my back garden with the caps on and let it cool for about an hour. This strategy has worked really well for me. Indeed, just last night, I was observing mighty Jupiter with my Mak. I made a quick sketch of what I observed (see attached).
Time: 23:05-15 UT
Seeing: I-II
Temperature: -2C
Jupiter: CM II 200 degrees
The air was nice and tranquil and though the planet had lost some altitude as it had passed culmination in the south, the image was clean, stable and bright at 190x, tack sharp and full to the brim with low contrast details. The background sky is pleasingly dark. It is a first rate planetary telescope and optically leaves little to de desired. It is also incredibly robust; never once have I needed to recollimate the instrument.
I found an old review of an Intes 7" f/15 Mak that dates from 2005: the reviewer compared his Maksutov to a 5" f/15 refractor on Jove and the Moon and concluded that the former was the easy winner in good conditions.
http://www.cloudynig...15-deluxe-r1009
I have concluded the same thing in my own tests with a 5" f/12 refractor.
Finally, I am also aware of two optical tests which were carried out on the Synta 180 Mak;
http://forum.astrono...180/2700mm_MAK_
http://airylab.com/c... 2012-40001.pdf
Wishing you clear skies!
Neil.
Edited by astroneil, 25 March 2015 - 04:16 PM.
