Manually use the scope. If you try and turn it on and use the motors to steer the scope, your going to burn out your motors. Its not about the weight issue here and load capacity. The mount is undersized, but thats just part of the problem. If you try and use those motors to lift the scope after its leaned over, you very well cold damage those motors or and make them completely unreliable. Load capacity isn't just about how much the mount can safely carry, its also about how much weight the motors can move.
In your situation, balance the scope as best you can and use it manually without power applied. Even the tracking motor is going to be under more load than it was designed for. When the scope is upright, or moving in a downward direction, it wont mater. But if your trying to move the scope up, you may notice that the motors just stop working. By that time, it will be too late.
If you just wanna have fun with the scope, just make sure its balanced correctly.
There are still issues your going to have with the load bearings on the mount. You could easily damage them and not know it, but when your using a smaller scope, it will feel rough and notchy, even during tracking. Just knowing that your doing this, I would never purcahse that mount from you.
I think others seeing your message, and reading this, should also consider looking elsewhere if that mount ever comes up for sale.
...Ralph
Did you use the EQ6 yourself with a C14 on it? What is your evidence that you would burn out EQ6 the motors? For example I use a CG5 ASGT with a C11 and it works just fine, I have used it for many months, and Celestron themselves sold the CG5 with a C11 as a package.
If the C14 is counterbalanced very well in both axes, it should take only a reasonable amount of force to move it into any position, why would the motors become unreliable on the EQ6? My CG5 motors sound just fine with my C11 for example, they didn't burn out or become unreliable, Goto pointing is very reasonable, and tracking is perfectly smooth at 700x magnification.
What is your evidence that the tracking motor is going to be over burdened in any bad way?
If you have personal experience of this mount and C14 then fair enough. Otherwise, I would like to hear the views from others who have actually used this mount / OTA combo.
Alistair G.
