I'm not too sure who sells these larger BA8 binos anymore; Oberwerk only sells up to the 70mm size presently, AFAIK. They can be found in England under the Helios Apollo brand. TS in Germany sells up to the 85mm versions.
Be aware that the eye relief of the 28x110 and 22x85 and 15x70 siblings are all quite short at around 9-10mm. These will likely be inadequate for eyeglass wearers. The 20x110/15x85/10.5x70 use a longer eye relief eyepiece with a smaller 55° AFOV rather than the 64° AFOV of the higher mag. models in each size. These lower mag. variants will be better suited for eyeglasses.
I have the limited production William Optics 22x70 ED version of these BA8 binos which use the same eyepieces as the 28x110 and I find the eye relief is about the same as my Fujinon 16x70s-- around 9mm. This is totally inadequate for my strong + eyeglasses. The IF focuser range is a bit broader than the Fujis; I can focus to around +9 diopters with the WOs but only to about +7 with the Fujis. I'd assume the minus side of the IF focuser range would be about the same.
The sliding adjustable mounting foot on these binos makes them relatively easy to balance. Of course, because these are straight-through design binos, to prevent neck pain at high viewing angles, they do best on a parallelogram or other cantilevered mount that allows reclined viewing with the tripod to the side.
Rich
