I have a modified Sony NEX-5 and have been imaging with an Astronomik UV/IR cut filter for a while now. Wanting to do more observing in my green zone front yard I decided to pick up an UHC filter. I debated between the Lumicon and DGM filters, but due to price and availability I opted for the Astronomik UHC filter. It's a bit less aggressive than the other two, not by much though, but I felt it should greatly enhance my experience nonetheless. Since I primarily image I couldn't help but throw it in the imaging train last night for a test.
A few weeks back I had taken a 10-minute exposure of M27 with just the UV/IR cut filter. The moon was around 8-9% illuminated and 45 degrees below the horizon and the Milky Way was visible. My test image last night was with the moon at around 85% illuminated and around 45 degrees above the horizon (almost at culmination.) There was no hint of the Milky Way and only the brightest stars were visible with the naked eye. There was a large difference in humidity between the two tests and a little bit of a temperature differential too.
Below are the results of the test and I'm very happy with the results. Post-processing was minimal, white balance adjustments in FITSWork and a slight level adjustment on the UHC image (the background was slightly darker than the non-UHC image.) The filter really seems to reduce the fainter stars bringing more focus to the nebula itself. It's much easier to discern the fainter portions of the nebula and it appears to have had an impact on moon-glow as well (which I wasn't fully expecting.)
Not only does it seem to be great on nebulae, it will also increase the number of nights that I can image.
