Thought I'll outline major DSLR modification types for easy understanding, and knowing what choices one has available when modifying a DSLR.
IMPORTANT: First and foremost, DSLR filters are referred to with many names, and all mean different things to different people. Here is a compilation of names these filters may be referred to. BUT I would advise that you use standard naming convention like LPF-1 or LPF-2 instead...
LPF-1
- Front Filter
- Dust removal filter
- Piezo element filter
- IR/UV block filter
- H-alpha pass filter
- Larger filter
- Pinkish looking filter
- Anti-alias filter (1)
LPF-2
- Rear Filter
- Color limiting filter
- White Balance filter
- H-alpha block filter
- Smaller filter
- Bluish looking filter
- Anti-alias filter (2)
Mod Choices:
1. LPF-2 removed and replaced with a modified filter [stock LPF-1 AS-IS]
2. LPF-2 removed and NOT replaced [stock LPF-1 AS-IS] (My recommendation...)
3. LPF-2 removed and replaced with clear glass [stock LPF-1 AS-IS]
4. Both, LPF-2 and LPF-1 removed (full spectrum) [external UV/IR block required]
5. LPF-2 removed and replaced with a modified filter & stock LPF-1 removed
Note: All options, except #4, 'may not' require external UV/IR block; additional UV/IR block can be added for refractive optics (to prevent star bloating). Light pollution suppression is something that can be used with any mod type
Note: Narrowband (NB) filter can be used with any mod type; 'NO' #4 external UV/IR block required if using a NB filter
To conclude, remember this...
"Essene of any astro mod is to get rid of stock LPF-2"
Edited by mmalik, 03 December 2014 - 06:01 AM.
