What did you do to your Scope/Mount Today?
6358 replies to this topic
#3076 Esso2112
Esso2112
  • Loc: Magnolia, TX
Posted 26 November 2017 - 06:13 PM
Today I got an original Unitron electric clock drive attached and working on my Unitron 152 (now a 152c). Had to drill out and tap the RA wheel that came with the clock drive to fit the larger shaft on the older mount.  Original solid RA wheel untouched this way and I can go back to all original configuration by just taking the newer wheel off and putting the original back on. I was a little nervous working on the clock drive wheel because I only had the one. Everything works nicely.
I also replaced the focuser tube rack and the pinion shaft on my 114.  The original tube was worn down to the brass on top where the stop screw slot is.  Too much play.  I picked up an unused focuser for a 3" Unitron and stole the tube out of it.  The grooves don't go all the way around like mine did and they are much more angled. Because of this, I had to use the newer pinion shaft and knobs.  It is nice to have knobs on both sides, though. The focuser is now smooth as butter and the 114 is now set up as my grab n go scope with its alt-az mount.
  • Mr Magoo, Bomber Bob, Garyth64 and 1 other like this
#3077 clamchip
clamchip
  • Loc: Seattle
Posted 30 November 2017 - 05:34 PM
I thought since its winter and also I thought how nice it would be to have a powder coated
tube, no off gassing to worry about and I could assemble almost right away I decided to look
into having it done to a 4 inch aluminum tube 5 feet long.
They can do the outside for around $160, but no one can do the inside, I got this from 2 local
Robert
  • Joe1950 likes this
#3078 TSSClay
TSSClay
  • Loc: Manchester MI
Posted 30 November 2017 - 08:10 PM
Robert,
I baffled my powder coated tube.  Worked a treat.  I made a baffle stack held in position using nylon threaded rod and  positioned this to eliminate stray light.
Clay
#3079 clamchip
clamchip
  • Loc: Seattle
Posted 30 November 2017 - 08:26 PM
I'll probably do that.
My plan on this one was powder coat interior flat black and have one baffle in the middle of the
tube I can slide in place and be observing in a jiffy since the powder coat is baked it probably
doesn't off gas at all.
Its this Edmund 4 inch I built from parts many years ago, the unpainted one:
Robert
Edited by actionhac, 30 November 2017 - 08:38 PM.
  • steve t, Terra Nova, member010719 and 5 others like this
#3080 TSSClay
TSSClay
Posted 01 December 2017 - 07:53 AM
I agree that, being baked on, it probably does not out-gas.  With powder Coat you have to take the thickness of the coat into consideration.  PC tends to be quite thick making things that have to fit inside the tube too tight to work after powder coat.  For my 6" f10 I asked them to mask the inside of the tube to allow my cell and focuser tailpiece to fit correctly.
This baffle stack construction seems to work quite well leaving the inside bare of paint.
Clay
  • clamchip, Terra Nova, Bomber Bob and 3 others like this
#3081 Bigern
Bigern
  • Loc: Miami Fl.
Posted 01 December 2017 - 03:13 PM
Mounted a green laser on the C90 and Tasco 11TR.
  • tim53, terrapin, member010719 and 2 others like this
#3082 clamchip
clamchip
  • Loc: Seattle
Posted 01 December 2017 - 08:42 PM
I've given my poor old Lava lamp a new life as a Newton's ring checker for long refractors.
This is my Edmund 4 inch and if you try and hold the tube vertical under a florescent light its
a little to long.
So I kept the base of my poor old Lava lamp and screwed a compact florescent bulb in it.
Now I check the lens with the scope on the bench, and for my purpose having the tube
horizontal will give me the information I'm looking for better than a vertical tube.
I'm getting the Edmund ready for some winter observing and wanted to make sure the lens
retainer is adjusted properly. I like it loose enough for a slight rattle but not too loose because then
the air space can flop around uneven and really spoil your evening.
Never throw anything out.
Robert
Edited by actionhac, 01 December 2017 - 08:46 PM.
  • tim53, Deven Matlick, terrapin and 5 others like this
#3083 clamchip
clamchip
  • Loc: Seattle
Posted 05 December 2017 - 07:44 PM
Today I am cleaning a Edmund 6X23mm finder.
This finder goes way back into the 1950's, and clear up into the Edmund red tube era.
In continuous production all that time, and by the same contractor, circle T, as far as I can tell.
Although small in aperture, its gigantic in quality.
Unfortunately the eyepiece needed to be disassembled.
My spanner wrench is too large to remove the retaining ring, so I was trying to unscrew it
with a tooth pick and other assorted things when nurse Mendy made me a sheet metal tool
cut exactly the right width to fit in the retaining ring's slot, as she is demonstrating in the
photos. Thanks Mendy, I Love You!
Edited by actionhac, 05 December 2017 - 07:51 PM.
  • Terra Nova, Bomber Bob, Garyth64 and 1 other like this
#3084 roscoe
roscoe
    curmudgeon
  • Loc: NW Mass, inches from VT
Posted 05 December 2017 - 08:03 PM
That's quite a gal, that Nurse Mendy!!
For those of you without a Nurse on call, her sheet-metal idea is a good one, and also a pair of dividers with the sharp points filed or ground off just a bit can be made to work pretty well, too.
  • clamchip and Joe1950 like this
#3085 clamchip
clamchip
  • Loc: Seattle
Posted 05 December 2017 - 09:49 PM
The dividers idea is great! thanks I'll remember that!
Robert
Edited by actionhac, 05 December 2017 - 09:50 PM.
#3086 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 06 December 2017 - 09:50 PM
Thanks to Glenn, my 1976 C5 Astro has a tabletop wedge:
Rather than make some Fred Sanford contraption, I splurged and got an OEM solution.  It has the slots in the bottom for tripod attachment, and I held on to a vintage Meade field model, so she's all set to point & track -- just as she did 40+ years ago...
  • tim53, Terra Nova, walter a and 3 others like this
#3087 mitsos68
mitsos68
  • Loc: Athens - Hellas.
Posted 07 December 2017 - 12:33 AM
since I live in an apartment, I had to assemble ad hoc the large heavy Polarex tripod in my balcony when my 102mm refractor used.
Inspired by the old Celestron C100E (https://www.cloudyni...00#entry7699849) , theTasco 20TE pier (https://www.cloudyni...hl= tasco 20te)   and by this article:  https://www.cloudyni...tron-bino-pier/ , I assembled a pier for my telescope using an aftermarket EQ5 pedestal and two EQ5 half piers. The required EQ5 to Polarex mount adapter was custom fabricated from a solid steel block at a local CNC shop. All three parts are rigidly assembled using the provided screws and bolts. I had only to remove the ball bearing washers under the main bolts (the used to connect the pier/half pier) to the EQ5 equatorial heads).
The result is a nice yet functional pedestal for my refractor.
Regards
Dimitris
Athens-Greece.
Edited by mitsos68, 07 December 2017 - 07:19 AM.
  • tim53, Deven Matlick, CCD-Freak and 13 others like this
#3088 TOM KIEHL
TOM KIEHL
Posted 09 December 2017 - 10:20 PM
I finished the C.C,Young mount today . Now on to the OTA
More pictures in my thread for this project .....Here >>>   https://www.cloudyni...aker/?p=8263115
  • Vesper818, Deven Matlick, CCD-Freak and 12 others like this
#3089 deSitter
deSitter
    Still in Old School
Posted 10 December 2017 - 05:07 PM
Thanks Gary for the illuminator - I reversibly upgraded it to a red 3v LED which is much better on the batteries and the eyes!
-drl
  • Deven Matlick, DreamWeaver, steve t and 8 others like this
#3090 Esso2112
Esso2112
  • Loc: Magnolia, TX
Posted 11 December 2017 - 08:16 PM
Tonight, I completed the upgrades to my Unitron 152.  Replaced the original focuser with a super focuser.  Added the 60x700mm guidescope and counterweight bar.  Conversion to a photo-equatorial complete.  I do have the 220 camera as well.  Thanks a bunch to someone on this forum for helping make this happen.  The really nice thing is that it can always go back to completely original in a short amount of time.  I love that the Unitron accessories require no drilling to add additions.
Edited by Esso2112, 11 December 2017 - 08:18 PM.
  • deSitter, tim53, Deven Matlick and 14 others like this
#3091 Terra Nova
Terra Nova
  • Loc: 39.07°N, 229m AMSL, USA
Posted 12 December 2017 - 10:36 AM
Looks great! You now have a 155! ;)
  • Esso2112 likes this
#3092 Esso2112
Esso2112
  • Loc: Magnolia, TX
Posted 12 December 2017 - 11:07 AM
Thanks Terra. Yes, it’s now a 155 with a pre-155 main scope. Just waiting on a super unihex. To arrive and then it’s good to go.
  • Terra Nova and Bomber Bob like this
#3093 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 12 December 2017 - 05:20 PM
That is just awesome!
#3094 akman1955
akman1955
  • Loc: Alaska
Posted 12 December 2017 - 06:26 PM
smile.gif Hey what is this dusty Orion mount call with polar finder and years made?? It was out in my shed for yearsbelushi.gif
#3095 deSitter
deSitter
    Still in Old School
Posted 12 December 2017 - 07:16 PM
That's the Hammerview OTC
-drl
#3096 akman1955
akman1955
  • Loc: Alaska
Posted 12 December 2017 - 07:22 PM
-drl
#3097 deSitter
deSitter
    Still in Old School
Posted 12 December 2017 - 07:59 PM
-drl
Sorry not a fan of Orion's hammertone finishes nor their naming schemes. "Skyview" "Edge On" "Versa-Go" - all bad!
-drl
#3098 roscoe
roscoe
    curmudgeon
Posted 12 December 2017 - 08:21 PM
If I have the story right, back in the dayu, Orion used to get stuff from Guan Sheng optical, not Synta.
I think that mount is from that era.  It might be marginally better than the Syntas ( Guan Sheng's scopes were.....)
  • Augustus likes this
#3099 DreamWeaver
DreamWeaver
  • Loc: Tucson, AZ
Posted 12 December 2017 - 08:46 PM
Is it this one?  This is from their June 2000 website.
Edit:  Disregard the link.  My iPad and the Wayback Machine website aren't getting along tonight.
Edited by DreamWeaver, 12 December 2017 - 09:48 PM.
#3100 deSitter
deSitter
    Still in Old School
Posted 12 December 2017 - 09:12 PM
blush.gif so what you saying?? piece oh crap??flowerred.gif heavy as hell. Date made?? I guess I should throw it in the fairbanks dump?? according to you guys?????
Yeah, it sort of defines cheap and Chinese. It looks cheap, it performs cheap, it is cheap.
-drl
