What did you do to your Scope/Mount Today?
5131 replies to this topic
#5126 ccwemyss
ccwemyss
  • Loc: Massachusetts
Posted 16 February 2020 - 10:54 PM
Finally got around to collimating a 114 that I picked up from SGW a while ago. First order of business was flipping the crown and flint back to the proper orientation and fixing a damaged spacer. But the images were still disappointing and it turned out to be way out of collimation. It's a bit tricky collimating a cell that wasn't designed for it, but I seem to have gotten the knack for it.
Then started to assemble a frankenscope 114 OTA that I've put together from a combination of spare parts that came with others and a few from donors. It has a "62mm" focuser, a slant-letter objective, and an indeterminate tube. It's amazing that pieces made that many years apart all fit together. Started collimating the cell, but realized the focuser isn't on straight, so I need to get that fixed first. This one has a mount waiting for it, but I also need to find or make a case for it.
There's a third one that needs a replacement for the front baffle. It's also missing the draw tube and tailpiece, no mount, and no case, so it's not a top priority right now. But at least it's collimated and gives nice images. That makes me a bit reluctant to take off the cell to insert a baffle.
Chip W.
  • Mbinoc likes this
#5127 icomet
icomet
  • Loc: Montana
Posted 17 February 2020 - 01:52 PM
Teflon studs.
"The better to rotate with my dear".
Clear Skies.
#5128 Chuck Hards
Chuck Hards
Posted 17 February 2020 - 02:01 PM
Today at lunch I made some minor modifications to a Tak 50mm finder bracket so it fits my TS-65, and painted it black to match.   Will install it and try to get it lined-up tonight.
  • Bomber Bob, Allanbarth1, Defenderslideguitar and 2 others like this
#5129 Chuck Hards
Chuck Hards
Posted 17 February 2020 - 08:33 PM
Here it is installed tonight.  Cloudy skies but I looked at the mountains across the valley, some nine to ten miles distant.  I used some rings and a Vixen dovetail I had on-hand, attached to a Celestron low-end tripod.  Not enough time to set up the Tak mount but I just wanted to align the finder and try the 70s vintage Tak orthos I got last year.   The finder is huge on a 65mm main scope.  I need to move it forward and rotate the reticle illuminator to a better position, or remove it.  It might only be needed under really dark skies.  There is nothing wrong with the factory 5x25mm finder- it is excellent, just a tad small.  A 40mm would be about right, actually.
I got the finder and bracket used, no illuminator but I had a couple of spares.  I had to remove just a bit from the front of the bracket foot to fit the TS-65.  The hole spacing is the same.  I think this is going to make the backyard sessions a lot easier this summer.  I picked up the Tak 1.25" visual back for the scope as well as 1.25" diagonal.  I used the .965" pieces to try the eyepieces.
  • CharlieB, DreamWeaver, Terra Nova and 9 others like this
#5130 Terra Nova
Terra Nova
  • Loc: Middle Earth
Posted 18 February 2020 - 10:30 AM
I love Takahashi finders. They are so sharp optically and are so well made!
  • Chuck Hards, Joe1950 and Defenderslideguitar like this
#5131 Chuck Hards
Chuck Hards
Posted 18 February 2020 - 10:31 AM
Here it is as received used from Khan Scope Centre.   All it needed was some light cleaning and the bracket modded and repainted to match the early Tak color scheme.
  • DreamWeaver, Terra Nova, rcwolpert and 5 others like this
#5132 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 18 February 2020 - 01:28 PM
Love Tak finders
