What did you do to your Scope/Mount Today?
5227 replies to this topic
#5201 icomet
icomet
  • Loc: Montana
Posted 20 March 2020 - 06:11 PM
Worked on a mirror cell today, with a little help
from one of my friend's "mouse traps".
Clear Skies.
  • davidmcgo, tim53, mattyfatz and 8 others like this
#5202 mattyfatz
mattyfatz
  • Loc: Boise Idaho
Posted 21 March 2020 - 03:20 PM
I've always wanted to mount an ETX90 to a Criterion 4000 fork drive...
here goes nothin....
  • Deven Matlick, Terra Nova, Bomber Bob and 6 others like this
#5203 bridgman
bridgman
  • Loc: Mosport, ON, Canada
Posted 21 March 2020 - 05:13 PM
That seems like a nice combination.
Speaking of ETX90's, I took the wedge head off my ETX90 tripod (a "DT1" which seems to be a no-name clone of the #883) and ran a 3/8"-16 bolt through the hole in the tripod base to mount a Desert Sky DSV-M which I recently bought used.
The result is surprisingly solid with the 80mm f/6 Stellarvue AT1010. Really needs an extension column but usable as is with some tripod movement. This gives me a really light grab & go rig for the first time** and frees up the AZ8 for the AT115 & C8. It would be nice to say that my master plan is coming together but this has been more of a random walk.
Yes I need to remember where I put the set screws that hold the laser into the empty bracket. And yes the handle is pointing the wrong way laugh.gif
** I originally had the AT1010 sitting on a cheap photo tripod but that was not a particularly usable setup so I'm pretending it never happened. Same for DSV-M on the cheap tripod.
Edited by bridgman, 21 March 2020 - 06:27 PM.
  • mattyfatz, steve t, Bomber Bob and 3 others like this
#5204 Corcaroli78
Corcaroli78
  • Loc: 55N, 9E, Denmark
Posted 22 March 2020 - 07:55 AM
Did some experimenting with a Zeiss Barlow 1.3 on my Telementor. I was lucky to find this extremely rare accessory item after years of searching. I consider the Zeiss Barlow 1.3 a great addition for advancing the magnification potential of any Zeiss refractor. Unlike with cheap Barlows, the Zeiss 1.3 will not compromise picture quality at all. I used my 6mm Zeiss Ortho with the 1.3 Zeiss Barlow and found image quality on par with sharpness, contrast and detail utilizing the ridiculously expensive Zeiss 4mm Ortho at only marginally less magnification. The 1.3 Zeiss Barlow mounted in front of my 4 barrel Zeiss turret is uppening the magnification spectrum tremendously. Great on nights with steady air. Never thought much of Barlow lenses. My Zeiss Barlow 1.3 is a keeper.
On the other end smile.gif , i have been playing with the extreme "affordable" solution to the Zeiss turret
So far, in combination with the Skymeca Quck Change Adapter, the Q-turret makes the observation easier as i do not need to change EP´s so often and the Telementor has no issue with the weight
Carlos
  • Deven Matlick, mattyfatz, steve t and 4 others like this
#5205 Geo.
Geo.
    Vendor - Nexstar Parts
  • Loc: Upstate NY
Posted 22 March 2020 - 11:24 AM
Clear Skies.
At first sight I thought, "D**n funny brake drum."
Once drove through the Green Mts. with a calico in that position helping me drive. Nothing will teach you to take the curve as smoothly as possible than a cat hang'in on your neck!
  • CCD-Freak and deepwoods1 like this
#5206 Geo.
Geo.
  • Loc: Upstate NY
Posted 22 March 2020 - 11:47 AM
Here is the wedge with a Questar adapter plate that I made last summer. After polar alignment, the polar alignment scope and it’s mounting are swapped out with the Questar mounting plate and then the Q is mounted, all precisely polar-aligned and ready to locate objects with its setting circles and clock drive.
Roger Tuthill sold one similar this.
O.K.  I had my 4 minutes of rest from the last "scope build/restore" project.
Started to collect parts for the next one.
10" f/7.5 project will commence soon.
Just sold an Onstep kit to a fellow in Calif. who is working on this mount. Said he had a Byers on RA was looking for something for Dec. So I tossed in a 180 tooth Meade crown and worm. Beats hobbing one.
  • Deven Matlick, steve t, Bomber Bob and 1 other like this
#5207 Senex Bibax
Senex Bibax
  • Loc: Ottawa, ON
Posted 23 March 2020 - 08:20 AM
Finished overhauling the EQ mount for my Sears 6339, and fixed it to the top plate of my SpectraPhysics surveyor's tripod. It's stable but very heavy.
  • steve t and Bomber Bob like this
#5208 Vesper818
Vesper818
    Astronomess
  • Loc: Right brain, Left Coast
Posted 23 March 2020 - 02:31 PM
I finished the new focus adapter for the Tasco 6vte "tasconado". The draw tube is 1.5" brass sink tube with a compression fitting attached to the f12 OTA. Attached to the tube is a 1.25" svbony helical focuser. Seems to work well, but it's cloudy here....
  • clamchip, DreamWeaver, steve t and 2 others like this
#5209 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 24 March 2020 - 05:34 PM
Small Project, Big Time (& Effort):  I love the spectros eyepieces & Amici prism diagonal with the 35mm barrels, but I have only 1 focuser that'll take these without using the step-down to 1.25" adapter:
... and that's my Tinsley Cassegrain.  (It also worked with that Unitron 142, but I sold it.)
Now that I have a bunch of scopes with 2" focusers, I want an adapter that'll fit the 35mm stuff to the 2" scopes without any vignetting.  Rummaging in the shed, I found a thread-in ring and a short chrome 2" focuser tube that the ring fits.  Cool.  But the ring is bored for 1.25" accessories.  Bummer.  But the ring is brass, a soft metal that I can work with my limited machining tools.  Cool.  I marked the ring for a 35.5mm opening.  All I have to do is remove 2mm of metal, and I'll have my adapter.  Oh, Yes!  I turned my Dremel on it, and quickly cut through... what turned out to be a .25mm thick brass band/bushing inside a steel doughnut.  Oh, No!  Cutting stopped, and grinding started.  Stopped when my hand went numb.  Still have about 1mm of steel to grind away...
Kept telling myself, No pain, no gain!   These spectros eyepieces are BB's Zeiss set (as close as I'll ever get), and they're worth the effort.  Carpal Tunnel is reversible, right?!
  • steve t, Allanbarth1, Defenderslideguitar and 1 other like this
#5210 mattyfatz
mattyfatz
  • Loc: Boise Idaho
Posted 24 March 2020 - 10:36 PM
That's how most of my shop projects turn out
  • Bomber Bob likes this
#5211 Allanbarth1
Allanbarth1
  • Loc: Central New Jersey
Posted 25 March 2020 - 07:02 AM
I'm sure it will be all worth it as soon as you take your first look through them.
#5212 Defenderslideguitar
Defenderslideguitar
  • Loc: Connecticut
Posted 25 March 2020 - 03:19 PM
What did you do to your mount   ?          I left the mount in the trunk ..................
I met the seller (GoodAsh) in the  parking lot to pick up this CG-5 for his  low low price
Our new protocol went like this.... I pull in and I  park ten feet away and opened my  trunk... The cash is in the trunk and has been there 2 days......Seller takes the mount from his trunk wipes down the mount and puts it in my trunk. He takes the cash and we chat  from ten feet away. We agree that extra precautions are not foolish. Agree to talk again ... hopefully at Neaf.    I will leave the mount in the trunk for a couple of days. The 17 year old sedan does not complain.
My first CG-5
Edited by Defenderslideguitar, 25 March 2020 - 03:22 PM.
  • Deven Matlick, steve t, Masvingo and 4 others like this
#5213 Astrolite
Astrolite
  • Loc: S. Central Pennsylvania
Posted 25 March 2020 - 03:25 PM
My first CG-5
I feel like I'm living in a science fiction movie!
  • Deven Matlick, CCD-Freak, Terra Nova and 1 other like this
#5214 clamchip
clamchip
  • Loc: Seattle
Posted 25 March 2020 - 08:03 PM
Remember The Andromeda Strain, serious chiller:
https://www.youtube....h?v=YMbSpnlOOtE
Robert
Edited by clamchip, 25 March 2020 - 08:04 PM.
  • Terra Nova likes this
#5215 mattyfatz
mattyfatz
  • Loc: Boise Idaho
Posted 25 March 2020 - 08:27 PM
Robert
More like a Terry Gilliam comedy
#5216 steve t
steve t
  • Loc: SW Ohio
Posted 27 March 2020 - 02:04 PM
Today, I used a few scraps of wood to build a small eyepiece tray that clamps onto the semi-pier of the 4" F10, Babbitt bearing, pipe mount. Since I mainly only use three eyepieces, when I observe, it didn't need to be that large. Once the current travel restrictions are lifted, I'll pick up some red oak and rebuild it, (along lessons learned from my first attempt) so it will match wood of the tripod.
Steve T
  • Vesper818, Deven Matlick, Pete W and 3 others like this
#5217 Pete W
Pete W
  • Loc: Hutto, TX
Posted 29 March 2020 - 10:14 AM
On the same "scrap of wood" trend, constructed a solar projection screen for my old Jason 313 from leftovers from our kitchen install:
Pinky the cat doesn't seem impressed; perhaps that'll change after it gets a white screen.
  • Deven Matlick, steve t, deepwoods1 and 6 others like this
#5218 steve t
steve t
  • Loc: SW Ohio
Posted 29 March 2020 - 12:53 PM
attachicon.gifIMG_0210.JPG attachicon.gifIMG_0209.JPG  attachicon.gifIMG_0214.JPG
Very nice
Steve T
  • Pete W likes this
#5219 Bomber Bob
Bomber Bob
Posted 30 March 2020 - 05:39 PM
I packed my Edmund 4" F15 refractor & mount for shipping to its new owner...
  • Terra Nova, PawPaw and Esso2112 like this
#5220 Pete W
Pete W
  • Loc: Hutto, TX
Posted 30 March 2020 - 05:58 PM
BB, dunno if I should offer congratulations or condolences...
  • Bomber Bob and TSSClay like this
#5221 Bomber Bob
Bomber Bob
Posted 30 March 2020 - 06:21 PM
It's all good -- she's staying in the Community.
New Owner will have some fantabulous views -- even before Mars, Jupiter, & Saturn are in prime time.
  • Terra Nova and Allanbarth1 like this
#5222 Augustus
Augustus
    Fly Me To The Moon
  • Loc: Stamford, Connecticut
Posted 30 March 2020 - 07:25 PM
Put an original 6x30 on my RV6; it came without one.
  • deepwoods1 and Bomber Bob like this
#5223 Compressorguy
Compressorguy
  • Loc: Clayton, NC
Posted 01 April 2020 - 11:05 AM
Installed a TV Focusmate 2 speed focuser on my TV Genesis. Works wonderfully!
  • mattyfatz, steve t and Bomber Bob like this
#5224 Terra Nova
Terra Nova
  • Loc: America’s Heartland
Posted Yesterday, 01:45 PM
I ordered four 1/2” thick 3’x3’ interlocking rubber waffle shop-mats online at Lowes yesterday and we drove through customer pickup to get them yesterday afternoon. I put them down over the 1/2” thick dense rubber 6’x8’ mat that rests on sand. Absolutely no vibrations, it’s very easy on the knees and feet and tripod feet go right into the holes in the mats so no spreader needed. It will be perfect for the surveyors tripod that has the 1” shaft Jaegers GEM that I rebuilt last fall.
  • tim53, mattyfatz, DreamWeaver and 10 others like this
#5225 rcwolpert
rcwolpert
  • Loc: South Hutchinson Island, Florida
Posted Yesterday, 03:15 PM
Looks like a great idea. Have you already used it at night while observing?
