What did you do to your Scope/Mount Today?
6358 replies to this topic
#6301 Star.Monger
Star.Monger
  • Loc: Maine
Posted 06 October 2021 - 06:35 AM
Cant help but notice how sweet your Jaegers looks in natural color
like my Jaegers 4 inch f 15.5
Love these scopes!  I've been on a polished alu tangent for the past couple of years. Somewhat inspired by Moonraker scopes and general 1950's sci-fi vibe. grin.gif
  • Terra Nova, Defenderslideguitar and 25585 like this
#6302 Terra Nova
Terra Nova
  • Loc: 39.07°N, 229m AMSL, USA
Posted 06 October 2021 - 09:19 AM
I used to have a shorter 4” in a polished aluminum tube. I enjoyed that scope a lot!
  • Mr Magoo, steve t, icomet and 3 others like this
#6303 Senex Bibax
Senex Bibax
  • Loc: Ottawa, ON
Posted 08 October 2021 - 08:40 AM
Yesterday i finished the reversible conversion of the RAO EQ mount for my Sears 6339A to a dovetail base. Here is what I have done:
  • Removed the original clamshell
    clamshell
  • Fabricated an adapter using a 15 cm length of 1"x2" rounded corner aluminium tubing, with holes drilled and tapped for the mount shaft, the slow motion worm gear bracket and to mate to a SVBONY double clamp dovetail base.
    adapter
    adapter with dovetail
  • Added a thick greased washer as a spacer between the adapter and the mount.
    washer-spacer
  • And here is the finished result.
    adapter On mount
Now I can use this very stable mount, on my SpectraPhysics surveyor's tripod base for all of my telescopes. I have fitted (again, all reversible mods) matching dovetail bars to my Sears 6339A, Polaroscope 60mm, Omcon 118SE and Bushnell 4.5" reflector. If the original setup could easily handle the 6339A - the longest and heaviest scope - it should have no problem with any of the others.
  • Pete W, deepwoods1, icomet and 7 others like this
#6304 icomet
icomet
  • Loc: Montana
Posted 08 October 2021 - 04:45 PM
Astrograph needed more c-wt.
Clear Skies.
  • deepwoods1, Marc-Andre, Terra Nova and 2 others like this
#6305 clamchip
clamchip
  • Loc: Seattle
Posted 10 October 2021 - 06:20 PM
Brother Alan Vogt, who you probably know here from his Seattle area outreach with his 4 inch
Unitron equatorial, gave me his Tasco 10TE-5 project. Thanks again Alan !
He found one in excellent unrestored condition and he wondered if I would like to take the reins
on his project.
I have the optical tube back together. I replaced the felt in the focuser and cleaned things up
and made a few missing screws.
I must say it has a very fine lens. I've always wanted a 10TE, and I'm not surprised at all the
lens is jaw dropping since I own a 7TE-5, this is just a supersize version of it.
I decided to skip DPAC, I knew it was going to be perfection and it is.
The focuser is excellent now with Home Depot 3/8" self-adhesive felt pads, these are just right
for the job.
I have the mount to go through next, for now it's on my Unistar.
I'm looking forward to doing some 3 inch f/15 observing.
Robert
  • deepwoods1, mdowns, Marc-Andre and 7 others like this
#6306 clamchip
clamchip
  • Loc: Seattle
Posted 10 October 2021 - 11:19 PM
I'm using a .965" to 1.25" hybrid prism diagonal right now and my 1.25" eyepieces.
I do plan on observing with the original .965" eyepieces so I'm not modifying the
focuser for 1.25" accessories.
The 10TE-5 manual states the clear aperture is 76mm making the focal ratio f/16.
As well made as this scope is I found one place I can improve it, flock paper  the
draw tube. I show a Edmund tube getting the treatment.
Robert
Edited by clamchip, 10 October 2021 - 11:28 PM.
  • deepwoods1, Marc-Andre, Terra Nova and 4 others like this
#6307 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 11 October 2021 - 04:03 PM
Putting that Baader 36.4mm to 1.25" Adapter Ring with Micro-Focus on the C102 F10 really paid off -- and I saw that last night:  Up to about 200x, the C102's stock R&P is fine, but above 50x per inch, the Baader is essential for me.  NAILED focus on Jupiter at 313x (AT Para 3.2mm) -- 78x per inch!  Stuck with that extreme magnification for almost an hour as the seeing bounced around 8/10, and got micro-seconds of awesome details.
  • deepwoods1, Marc-Andre, Star.Monger and 1 other like this
#6308 clamchip
clamchip
  • Loc: Seattle
Posted 13 October 2021 - 09:53 AM
My new Tasco 10TE-5 Alan Vogt gave me is fabulous.
I want to clean all the original .965" eyepieces and optical accessories and clean and lube
the original mount so I can experience what it would have been like to observe thru it when
it was made in 1966.
The eyepieces scare me a little especially the 4mm. And the mount, I guess I'll start taking
out screws and see if it opens up to expose the inner workings.
Robert
Edited by clamchip, 13 October 2021 - 09:56 AM.
  • deepwoods1, icomet, mdowns and 7 others like this
#6309 DreamWeaver
DreamWeaver
  • Loc: Tucson, AZ
Posted 13 October 2021 - 11:21 AM
This thread will help with the mount.  https://www.cloudyni.../?hl=10te mount
  • mdowns and Alanvogt like this
#6310 clamchip
clamchip
  • Loc: Seattle
Posted 13 October 2021 - 04:43 PM
It sure will, thanks !
Robert
  • DreamWeaver, mdowns and Alanvogt like this
#6311 bmwscopeguy
bmwscopeguy
  • Loc: Oak Bay, New Brunswick
Posted 13 October 2021 - 05:08 PM
Grueling 30 minutes...  I attached an SVBONY standard 1/4-20 tripod block to my 1980s Mizar BN-80 Nature Scope (still waiting on the dovetail clamp).  Mizar built the scope to take a lickin' so naturally I had to test that concept:  I attached the new dovetail block to the existing block (for reversibility).  And, Mizar made their block semi-proprietary.  My solution:  Single 1/4-20 bolt to the Mizar block, plus a 1/4-20 grub screw for no wiggle + leveling:
Also:  See the camera platform on top?  A long screw runs through the back strut to the focuser flange...  Took me a confused couple of minutes to figure that out.  Really, Mizar?  Who is gonna put a 35mm SLR on top of this scope?
Hi Jeff,
Yeah, but that same mounting point will be perfect for an ASIair Pro which has a 1/4-20unc tapped hole on two sides...
  • Bomber Bob likes this
#6312 clamchip
clamchip
  • Loc: Seattle
Posted 14 October 2021 - 07:04 PM
Today I spent a considerable amount of time looking for a  1.25" eyepiece holder to
screw into the end of the long skinny Astro Optical draw tube.
I tried things like the inlet of a star diagonal, inlet of a barlow, misc camera adapters
etc with no luck. I threw in the towel and just ordered a straight thru adapter:
https://www.ebay.com...4.c100667.m2042
In this photo I'm using a .965" to 1.25" hybrid diagonal and what you see is the draw
tube drawn out to focus at infinity, this is how much it is drawn out and is why its
important to have tight felt holding this draw tube inside the focuser. I replaced my
felt with Home Depot self-adhesive 3/8" diameter felt pads, they are perfect for the
job.
Robert
  • mdowns, Terra Nova, Bomber Bob and 3 others like this
#6313 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 14 October 2021 - 08:15 PM
I've had a couple Tasco 10TEs and a few Sears 6339a scopes.  They all were excellent performers.  Putting them on old cg-5 mounts they were great for outreach events.  (even in my own backyard.)
The only thing I didn't like was the long skinny draw tube.  And on all of those scopes I did the chrome drain pipe mod.
Why didn't they make the tube a little longer?  (-well, it wouldn't fit in the wood box!)
I found that an ATCO 1254, 80x1200 scope has a longer tube than the Tasco and Sears scopes.  I think the 80x1200 Monolux and some others do too.  Those scopes don't have the long skinny draw tube and they accept the "vixen-style" 1-1/4" VB.
I also found that the RAO lens assembly from the Tasco/Sears scopes attaches directly on to the ATCO tubes.
So, here is my ATCO RAO 76.2x1200:
The ATCO is APL, and riding on it is my APL Manon.
When I repainted the ATCO tube, I also repainted the lens cell to match the color of the focuser.  So it looks like a match, but the ATCO lens cell is a different design and cannot be collimated like the RAO cells can.
Edited by Garyth64, 14 October 2021 - 08:21 PM.
  • clamchip, icomet, mdowns and 7 others like this
#6314 Pete W
Pete W
  • Loc: Hutto, TX
Posted 14 October 2021 - 10:40 PM
etc with no luck.
Here’s an option that should work:
https://www.cloudyni...okyopentax-j60/
In my 10TE I had to use a 30.5mm to 37mm step up ring, then a 37 to 42mm ring.    The 30mm to 42mm ring was too small to thread onto the drawtube.
  • clamchip and mdowns like this
#6315 Senex Bibax
Senex Bibax
  • Loc: Ottawa, ON
Posted 15 October 2021 - 07:30 AM
That is also essentially the same mount that i recently adapted to use an SVBONY dovetail clamp instead of the clamshell. Of course, Robert is more interested in clam chips rather than their shells.
  • clamchip and Bomber Bob like this
#6316 clamchip
clamchip
  • Loc: Seattle
Posted 15 October 2021 - 06:11 PM
I have a terrible craving for Manhattan style clam chowder, oh wow I can't stand it.
Its been ages, I hope Ivar's has it. Their New England is so good I don't even look at the
menu. And I go for Cod & Chips, much better than the Pollock & Chips, but you get more
for your money with the Pollock.
Today I've been looking at the eyepieces that came with my 10TE-5 wondering how am I
H20mm not too bad, HM12.5mm I feel some pain coming, SR4mm IMPOSSIBLE !
They are too dirty to clean with the glass in place. I need to remove the elements otherwise
I risk the grit scratching the coatings. I want to remove the tiny retaining rings, remove the
glass and soak these tiny lenses and gently clean between my finger tips in a flood of
water from the kitchen facet.
I think I have just the tool, my Edmund industrial microscope. It's made for looking at
machined parts, etc. vs biological stuff. If you want one I see'em on ebay all the time.
Robert
Edited by clamchip, 15 October 2021 - 06:16 PM.
  • steve t, Marc-Andre, Terra Nova and 2 others like this
#6317 clamchip
clamchip
  • Loc: Seattle
Posted 16 October 2021 - 10:17 AM
I mentioned a spot welder in another post and I thought I would show off my
Harbor Freight spot welder:
https://www.harborfr...lder-61206.html
I bought the 240 volt model but it's available 120V too.
Good deal for $160 and a 20% off coupon. You can make all kinds of telescope parts without the
need for tapping and threading or any fasteners.
Robert
Edited by clamchip, 16 October 2021 - 10:18 AM.
  • steve t and Bomber Bob like this
#6318 clamchip
clamchip
  • Loc: Seattle
Posted 18 October 2021 - 10:09 AM
My new Tasco 10TE-5's focuser is way too notchy feeling.
It works fine when turning slow, as in fine focus, but when you coarse
focus you can feel every tooth.
I know what the problem is.
The red arrows point to grub screws to adjust the focuser tube. Under
the grubs there is a red fibre sheet, mine was missing and I replaced it
with a piece of cardboard. Well, I got the cardboard too thick and now
the teeth are meshing too deep. If this sheet is missing you will know it
because there will be play in the focuser tube and at the knobs.
I could dig thru the grub locking paint and adjust the grubs, but I've chosen
to make a new grub sheet with thinner cardboard, 'cut and try' method.
Robert
  • steve t, deepwoods1, mdowns and 1 other like this
#6319 clamchip
clamchip
  • Loc: Seattle
Posted 18 October 2021 - 12:52 PM
My cardboard grub sheet was too thin, not too thick as I thought.
Here's how you do it:
If you have the 3 red fibre sheets at 120 deg around your focuser tube clean these of all
lube and shinny spots otherwise this can cause sticky movement. Clean these in place with
alcohol, you can remove the grub sheet because it's not glued in place.
Now, without the pinion gear/focuser shaft on the focuser adjust the two grub screws for
just the right amount of drag, and also watch for play in the tube, you want to zero-out any
side-to-side-up-down play in the tube it's full travel.
When you are finished with the focuser tube install the pinion shaft and it's retaining block.
You can adjust the knob turn resistance with the pinion block screws to some degree but these
focusers are going to require a pretty fair amount of turning torque, more than I like personally
but its the nature of the beast.
Robert
Edited by clamchip, 18 October 2021 - 01:01 PM.
#6320 Borodog
Borodog
Posted 18 October 2021 - 06:20 PM
I haven't done it yet, but I've order the part. I'm going to defork my 1985 white tube C8 from the Byers drive unit. It makes me quite sad to break it up, but I have had no luck in figuring out how to correct the wicked periodic error that was introduced during the motor replacement. :O/ Before the motor failed the PE was < 10". Now it's more like 250". So the white tube will be used on the CGEM instead. As sad as it makes me, it's also exciting, as I should be able to image some DSOs with the pair.
#6321 jragsdale
jragsdale
  • Loc: Idaho
Posted 19 October 2021 - 10:55 AM
Received a CGE tripod that was critically damaged during shipping, was able to get it TIG welded back together locally and back in business!
  • tim53, CCD-Freak, steve t and 6 others like this
#6322 clamchip
clamchip
  • Loc: Seattle
Posted 21 October 2021 - 12:01 AM
I read somewhere a telescope manufacture would test lenses during the day observing a brick
wall, the surface of the bricks, the mortar, etc.
Another one used newspaper, which is what inspired me to print clams and post them on fence
posts on the other side of the valley. Resolving the growth lines is a great test.
Robert
Edited by clamchip, 21 October 2021 - 12:05 AM.
  • CCD-Freak, DreamWeaver, steve t and 6 others like this
#6323 Borodog
Borodog
Posted 22 October 2021 - 09:34 AM
Deforked and ready for transplant. ADM Losmandy D plate arrives today.
  • CCD-Freak, mdowns and Bomber Bob like this
#6324 clamchip
clamchip
  • Loc: Seattle
Posted 22 October 2021 - 10:09 AM
I didn't sleep well last night.
My wife got a hair cut yesterday and the perfumed shampoo made her have breathing problems.
I know what happened, they were so busy chatting they both must have forgot to use the free & clear
stuff like we do here at home.
Since I couldn't sleep well I did get quite a bit done on my telescopes.
They say if you can remember your dreams you didn't sleep well, that's how I know, I woke up with
everything figured out.
Now I just need to go upstairs and hope what I dreamed I can come thru with.
What I dreamed is I have a large Towa equatorial. And I think I have a electric drive for it too.
I want to put my new Tasco 10TE-5 3 inch on it for double star observing. Serious double star observing
and is why I want a drive.
And, according  to my dream I might have a adapter plate to mount the Towa eq head on my GM8
tripod.
I hope I can make it happen, it truly will  be a "dreamscope."
Robert
Edited by clamchip, 22 October 2021 - 10:16 AM.
#6325 clamchip
clamchip
  • Loc: Seattle
Posted 22 October 2021 - 12:06 PM
I didn't do so good.
The drives are:
Orion 07825 Accutrack SVD Electronic Drive
Celestron 93511 Logic Drive
I might be able to modify one of these to fit the 10TE-5 mount but not the Towa.
The adapter plate won't work ether, and I'm not sure what it's for, maybe Unitron.
Robert
Edited by clamchip, 22 October 2021 - 12:06 PM.
  • Terra Nova and Bomber Bob like this
