Jaegers 6" F5 - Ready to Use:
After I got the focuser attached & centered, I put 2 coats of chalkboard black on the back plate interior. Takes the flash at close range to get any reflections.
Since these rings stay on the OTA, I built a "cage" around it, with a quick-release finder bracket. Ring placement is balanced with my oldest & heaviest 2" mirror diagonal + vintage Edmund / UO Erfle eyepieces. When I switch to 1.25" accessories, I'll have to add a finder, or slide the tube down some! I definitely want to keep the OTA weight as low as possible -- already 20# with 2" accessories...
He really doesn't need a finder: I can look up along the spine of the top bar -- but I may add an old peep / rifle sight to it...
Spent several hours this morning polishing away the deep scratches on the back plate exterior. I went for the "mirror surface" only on the edge -- and my shoulders are still sore! I do this work by hand, and use the 3M / Scotch sanding sponges. (No matter what color scheme I go with, I'm leaving this piece as bare metal -- turned out so pretty!)
ALL of the hardware I used for my MODS is vintage -- mostly brushed nickel. The 3 brushed nickel slot-screws that hold the Focuser on are antique, from one of the GW Adelaides I bought years ago. The 4 x #8-32 bolts fill the spaces made for the GSO focuser. For now, they're "holders" until I decide if I want to add baffles to the Eye End...
Like most of the ATM scopes that I've bought, the cells & such go on only One Way, or the screw holes don't like up. I put notches in the back plate & tube interior where it attaches; and notches in the lens cell & sky end interior. When assembled correctly... the Top of the Focuser aligns perfectly with the #1 Spacer + outer cell screw. Does that matter? I don't know! But the Dakin 4 had a similar symmetry, and I made sure to re-assemble it as designed...
Also, while the back plate has fixed tilt, the inner lens cell can be tilted about 8* from flush, so collimation can be adjusted. I'll address that when I put the Jaegers up on my DPAC rig.
Edited by Bomber Bob, 08 June 2022 - 05:33 PM.
