The weather is going to be bad for a while, so I packed up my Mak till better days.
What did you do to your Scope/Mount Today?
#51
Posted 18 February 2015 - 08:22 PM
- Terra Nova likes this
#52
Posted 18 February 2015 - 08:54 PM
I installed my plastic adapter and I trust the glue joint after all.
If you use the correct ABS glue for the ABS fittings and follow the directions the joint actually fuses together the two parts and its very strong, stronger than the base material.
I'm worn out after wrestling these dinosaur bones.
- TOM KIEHL likes this
#53
Posted 18 February 2015 - 09:12 PM
I was trying to take a picture of my clutch, I'm very proud of my clutch it works very well but I actually got the idea from Edmund so it not my idea. The camera focused on the gear teeth and aren't they beautiful teeth, those are Byers teeth. I wish I knew what telescope this gear set came from, anybody know?
- Terra Nova and TOM KIEHL like this
#57
Posted 19 February 2015 - 05:15 PM
Ive done nothing but work today. Yesterday I got paint, primer, sandpaper and aluminum tape at the hardware for the Monolux 40mm...
Edited by Vesper818, 19 February 2015 - 05:19 PM.
- Terra Nova and fjs like this
#58
Posted 19 February 2015 - 05:55 PM
I re-mounted my newly acquired C90 on my C8 today and got some outside pic's. I just cant get enough of this set up, it's by far my most used scope. It really needs some nose weight though. Need to find a period sliding weight setup.
Edited by Compressorguy, 19 February 2015 - 06:02 PM.
- BarabinoSr, A6Q6 and John Higbee like this
#60
Posted 23 February 2015 - 12:04 AM
Edited by Vesper818, 23 February 2015 - 12:04 AM.
#61
Posted 24 February 2015 - 02:38 PM
#62
Posted 24 February 2015 - 06:31 PM
I spent this afternoon in the machine shop making a sliding dew shield for my 4" F/15 Edmund refractor. I have never liked the original extruded aluminum dew shield. It's too short, thin, bell-shaped and cheesy looking. So I decided to make a new heavier, longer sliding dew shield from a length of 1/8" thick 6061-T6 (aircraft grade) aluminum tubing. I bought a foot of 4.5" o.d./4.25" i.d. tubing from Online Metals, Today I cut it to 10 inches length. I then took a few hundredths off the outer wall, polished out the surface, and chamfered the edges at either end- the front bevelled outward, the back bevelled inward on the lathe. I will flock the inside of it tomorrow. I will also spray a clear coat of polyurethane on the exterior. The original dew,shield will of course be stored. I also finished dew shield for another refractor project as well.
Edited by terraclarke, 24 February 2015 - 07:46 PM.
- Mr Magoo, BarabinoSr, Vesper818 and 9 others like this
#63
Posted 25 February 2015 - 06:27 AM
Looks good.
Rich (RLTYS)
#65
Posted 28 February 2015 - 08:48 PM
Scott - that's a beautiful set up you have there...your mod increasing the height of the wedge/OTA is on my short list of projects to accomplish.
Working to get some vintage accessories for my C8 and C14. Picked up a piggyback mount and a single axis '70s Celestron drive corrector (in orange) for my C8, along with a counterweight rig (see below). I'll also install my University Optics orange 8X50mm RACI finder at the same time to finish the C8 upgrade.
Also picked up an original Orange Tube C90 and a piggyback mount...the C90 is going on the C14. Both of these, "tricked out" will be at the CN Classics Telescopes display at NEAF 2015 this April
I think the counterweight rig that C8s used was the "stack 'o weights" model that bolts to the front tube ring. I actually did pick up a sliding counterweight rig for my C8 off the CN classifieds recently...but it looks like a C-11/14 rig with the bar cut to fit the length of the C8 tube...haven't seen it advertised as a stock item in any of the vintage Celestron catalogs I've looked through. I'll post a picture of it shortly.
John
#67
Posted 01 March 2015 - 10:27 AM
They did sell an 8" version of that in the early 1980s. I had one and returned it since my 1975 C8 was assembled with the front cell clocked a little rotationally and the brackets didn't quite line up. Plus it didn't fit in the footlocker with that attached.
dave
#68
Posted 01 March 2015 - 01:16 PM
I flocked the new dew shield that I made last week for my 80mm custom red project scope/RFT. This scope gave amazing views of Comet Lovejoy in January, and the Pleiades and Orion Nebula were beautiful. Perfect view of the Trapezium. The contrast and sharpness are superb!
- Mr Magoo, BarabinoSr, Colin exraaf and 1 other like this
#69
Posted 01 March 2015 - 01:45 PM
Here is a picture of the kit for my C8. The lower mount attached with two screws through the wings but the upper mount used the single button head screw through the center of the mount that would go in the same hole as the stacked weights.
- Mr Magoo and Terra Nova like this
#71
Posted 01 March 2015 - 02:03 PM
Jon - that's the one I have. The brackets are painted black (they'll be gray soon), and I have setscrews in the brackets for retaining the bar, vice the thumbscrews.
John
#72
Posted 01 March 2015 - 05:11 PM
I added a Telrad to the Wonderscope and Glowy is furious. He's been trying to point it at the sun to burnout the reticle.
I also added a knob for steering the telescope so I can keep my paw off the rim. I did not drill a hole for the knob there was already one for the spider vane's original location. I marked the knob with a pink arrow.
When I finally restore the scope I'll loose this very handy modern convenience. And probably the Telrad will be removed also.
Another thing I'll miss is the Meade focuser you see in this picture. Its a very very good focuser. No slop, no shift, its made and machined perfectly square bore to mounting flange. Extremely smooth through the entire range of focus, helical cut rack and pinion gears. I've owned aftermarket focusers like this one before but none were as nice as this one.
I'll be restoring the Cave next time earth gets a major asteroid impact and blankets the planet in ash. Otherwise I just can't take it out of service to restore it. When I do restore the scope it will be 100% original.
Robert
- clusterbuster likes this
#73
Posted 01 March 2015 - 08:44 PM
Nothing as truely skilled as Terra. More akin to the day-laborer, but I love to clean and polish. Worked on my new Selsi 80 box. A little glue (exterior veneer - left front, ripples remain; acc. box cover veneer, a few of the odd tie-down bits; case dovetails; and a little oil (3 coats actually of lemon-almond, exterior only). Not to bad, amazing how the surface scuffs disappear. No handle upon arrival. I have a strap-on coming so I can keep the original hardware!
Timestop
#75
Posted 01 April 2015 - 09:53 AM
- BarabinoSr, SDStargazer, mitsos68 and 3 others like this
