What did you do to your Scope/Mount Today?
10123 replies to this topic
#9301 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 04 August 2024 - 07:08 AM
I will use my spray gun to paint the inside and outside of the tube.  I still have a lot of the $200 a gallon flat black I used on the q7 when I restored it.
That is what bottom paint for my boat cost back in the 80's.
#9302 deSitter
deSitter
    Still in Old School
Posted 04 August 2024 - 08:24 AM
Wow, that must be "Spinal Tap #11 - Smell the Glove". I still think flock paper is blacker :)
-drl
#9303 ccwemyss
ccwemyss
  • Loc: Massachusetts
Posted 04 August 2024 - 11:48 AM
Wow, that must be "Spinal Tap #11 - Smell the Glove". I still think flock paper is blacker smile.gif
-drl
As I recall from a previous discussion, that paint is what is used for aerospace applications to minimize reflection in a wide range of wavelengths. It’s tricky to apply for maximum effect but is actually superior to flocking, and more durable.
Black 4.0 from Culture Hustle comes close, but I haven’t tested it for thermal stability. Their 3.0 wasn’t stable, but 2.0 is.
Chip W.
#9304 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 04 August 2024 - 04:48 PM
-drl
have to buy  a special thinner that only works with the paint.
https://www.cerakote.../armor-black.
It is very black
#9305 CHASLX200
CHASLX200
Posted 04 August 2024 - 06:47 PM
Moved the 826 OTA from the leaking roof. Getting snow in July thanks to a Cane.
#9306 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 04 August 2024 - 07:53 PM
Edited by starman876, 04 August 2024 - 07:54 PM.
  • Michael Covington and Werckmeister like this
#9307 CHASLX200
CHASLX200
Posted 05 August 2024 - 05:46 AM
Rain anytime for me is like getting snow in July.  I can use a cane a week for months to make up for the lack of rain i have had the last the 5 years.
  • Jehujones likes this
#9308 jkmccarthy
jkmccarthy
  • Loc: Los Angeles, California U.S.A.
Posted 06 August 2024 - 09:42 AM
I believe they will also fit the older CG-5 mounts, as they are practically the same as the Polaris.
But the CG-5's have a little opening to read the RA.
Initially I too thought the small rectangular notch in the Vixen GP polar scope eyepiece cover was to be oriented at 12 o'clock for viewing the top of the setting circle, but I've since learned that its design purpose and dimensions are so that the polar scope eyepiece cover will clear the rectangular extension on the bottom (6 o'clock) of Vixen's #3830 digital encoder set for the GP and GP-DX / GP-D mounts:
Now you know ...
      -- Jim
  • mdowns, Bomber Bob, LU1AR and 1 other like this
#9309 norvegicus
norvegicus
  • Loc: en route
Posted 06 August 2024 - 10:37 AM
oooh, GP/DX with encoders....
  • mdowns, Bomber Bob and jragsdale like this
#9310 jkmccarthy
jkmccarthy
Posted 06 August 2024 - 02:27 PM
Every once-in-a-long-while on Zen I'll spot a GP with encoders installed on it -- visible in the photos -- being offered-up by a surplus-reseller on Yahoo! Japan Auctions who doesn't even mention the encoders in their listing title or description.    (The mount pictured in the Vixen 'Stellar Guide' advertisement photo is a GP, but from first-hand experience I can attest to the fact that the Vixen 3830 encoders for GP can be installed perfectly well onto a GP-DX [a.k.a. GP-D] mount instead, as the relevant shaft O.D.s and threads at the ends are the same, only steel instead of aluminum : - ).
What I haven't tried (but admit to being tempted : - ) is adapting the GP encoders to the SP-DX, which I don't expect would make for a perfect fit, despite the polar-scopes and counterweight-shafts being basically interchangeable --- in addition to the encoders' central bore engaging the mount's rotating shafts, the encoder housings also need to be affixed to the end of the [non-rotating] housing of each axis, and unlike the SP or SP-DX, the axis housings of the GP mount family have notched/slotted features to facilitate this.
It's also worth noting that the Vixen 3830 encoders provide 'only' 3000 encoder pulses per 360-degrees of rotation, i.e., 7.2 arcminutes on the sky per tick ... which is rather coarse by modern standards, but certainly not a major limitation for visual use.   Nevertheless, the Vixen SkySensor 3-D (where "D" stands for Deluxe) controller has a second multi-pin connector that accepts encoder inputs as well as RS-232 serial communication with a computer ... the former actually being of greater interest to me than the latter ....
Clear Skies,
      -- Jim
  • deSitter and Bomber Bob like this
#9311 deSitter
deSitter
    Still in Old School
Posted 06 August 2024 - 02:46 PM
Clear Skies,
      -- Jim
That's 1/4th of the Moon!
-drl
#9312 jkmccarthy
jkmccarthy
Posted 06 August 2024 - 03:13 PM
-drl
Yes, indeed so !    (see also this CN > Classics > Craigslist etc post of mine from back in April ... https://www.cloudyni...ads/?p=13421090  ... the second or third Zen-spotted GP with encoders I'd run across [and I'd previously pulled the trigger on the 1st one, a green GP], and this 3rd one actually was a GP-DX  : - )
        -- Jim
Edited by jkmccarthy, 06 August 2024 - 03:18 PM.
#9313 jragsdale
jragsdale
  • Loc: Idaho
Posted 06 August 2024 - 06:46 PM
3D printed a dew and stray light shield for an Astroscan I have. Works with the existing cap and slides onto the tube with felt so doesn't scratch the body. Works with existing peep finder in place too. Lightweight at only 3.3oz.
  • deSitter, CCD-Freak, PYeomans and 7 others like this
#9314 jragsdale
jragsdale
  • Loc: Idaho
Posted 11 August 2024 - 09:36 AM
Continuing on my quest to design and print all the major accessories for the Astroscan. I finished a rough draft on the tripod mounting adapter. Turned out really good with some custom red 3D printed knobs.
  • tim53, CCD-Freak, clamchip and 6 others like this
#9315 k5apl
k5apl
  • Loc: Arkansas
Posted 11 August 2024 - 06:22 PM
My Bushnell Sky Chief Jr. focuser tube shifted side-to-side when focusing, because the rack had too much play in the focuser trough. The trough was allowing the rack to shift when the pinion gear was turned one way or the other.  Although I couldn't see any problems with the image at about 150X, it bothered me.  Many materials were tried as shims on each side of the rack without success, until I tried zipties.  The 3 inch version was the correct width and thickness--just trimmed it to size and wedged it in the focuser housing trough.  Fixed it.  No shift now, and I wasn't out a lot of money.
Wes
  • deSitter, Bomber Bob and kjkrum like this
#9316 k5apl
k5apl
  • Loc: Arkansas
Posted 12 August 2024 - 04:55 PM
I collimated my diagonal today.  The red-dot laser collimator was inserted in the diagonal.  I held a piece of plate glass over the
telescope side of the diagonal (flush and flat).  The diagonal is the inexpensive prism model made by Celestron.  The red dot
was reflected back to the target, and I adjusted the two 1.5mm allen head screws until the dot was centered.  Done deal.
Hopefully I'm through for a little while, and won't keep making as many posts.  Waiting now for clouds to go away.
Wes
  • Bomber Bob likes this
#9317 jragsdale
jragsdale
  • Loc: Idaho
Posted 12 August 2024 - 05:48 PM
Going a little crazy with the 3D printed Astroscan parts. Custom solar finder in red PET-G.
  • CCD-Freak, clamchip, Bomber Bob and 3 others like this
#9318 CHASLX200
CHASLX200
Posted 12 August 2024 - 06:01 PM
I moved the AP800 to sweep.
  • deSitter likes this
#9319 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 13 August 2024 - 01:46 PM
Gave my 1980s spectros (Swiss) Amici Diagonal a thorough cleaning before joining the 3 Big Kellners (35mm barrels) in storage:
spectros Diagonal Prepack S01 - Disassembled (TP FL).jpg spectros Diagonal Prepack S02 - Disassembled (TP ZM).jpg spectros Diagonal Prepack S04 - Reassembled (ES FL).jpg
This diagonal is as heavy as my Vixen 4-slot rotary eyepiece holder.  The prism is a beautiful piece of glass - I can believe that spectros sourced optics from CZJ.  THAT would be a great rumor to confirm!
BIF:  The only scope that natively accepted its 35mm barrel is my Tinsley 6 Cass, and that's only because it has the clamp on the focuser barrel.  But the views of Jupiter at 100x with the 30mm Big Kellner were fantastic - well worth the trouble.  Using the 1.25" adapter with my other Classics works, but all that weight put a lot of stress on the old focusers!
BIF2:  Didn't Pentax use a non-standard barrel size?  Seems like I've seen a few item ads over the years with 35mm specs...
Edited by Bomber Bob, 14 August 2024 - 10:14 AM.
  • deSitter, mikerepp, Kasmos and 2 others like this
#9320 cavedweller
cavedweller
  • Loc: Ridgecrest, CA
Posted 13 August 2024 - 01:49 PM
Did you also move it back? No pictures, then it didn't happen.
#9321 andylsun
andylsun
Posted 13 August 2024 - 02:31 PM
I found that what I thought was a 52 tooth 2GT printed gear, was actually a 50 tooth 2GT printed gear. That may explain the RA drift.
#9322 deSitter
deSitter
    Still in Old School
Posted 13 August 2024 - 04:58 PM
Yes, and let's hope the broom was properly stored.
-drl
#9323 CHASLX200
CHASLX200
Posted 13 August 2024 - 05:59 PM
Well here is the messed up flow as i call it. Gotta strip and rip and repaint.
  • deSitter, CCD-Freak, mdowns and 3 others like this
#9324 deSitter
deSitter
    Still in Old School
Posted 13 August 2024 - 06:35 PM
This is a very elegant telescope!
-drl
#9325 CHASLX200
CHASLX200
Posted 13 August 2024 - 06:43 PM
-drl
After trying a million mounts it is on a real mount now. I  about had to pay AP900 prices to get it back jack.
