What did you do to your Scope/Mount Today?
10058 replies to this topic
#9551 deSitter
deSitter
    Still in Old School
Posted 20 October 2024 - 01:25 PM
Made this bar for my Vixen Custom - allows use of standard rings.
-drl
Head
-drl
  • davidmcgo, tim53, k5apl and 12 others like this
#9552 clamchip
clamchip
  • Loc: Seattle
Posted 20 October 2024 - 05:32 PM
Today I draw filed the track on my Odyssey focuser.
I noticed it would slip occasionally and tightening the adjustment screws was no longer helping.
I inspected the track and noticed micro grooves, and these are where the focuser shaft would
hang up and slip, and I think over tightening the adjusters aggravates the problem.
I was reluctant to remove any metal but I was faced with no choice, do it or continue fighting it.
Focusing is critical on this scope with it's super fast f/4.5 focal ratio. I almost wish it had a two
speed but this unknown Crayford works really well, extremely well now.
Draw filing is you grasp both ends of the file and pull or push the file sideways perpendicular to
your work. A single cut file is preferred and it leaves a very smooth flat surface. I wanted the
track flat, very flat, and no sandpaper which can embed grit in the soft aluminum.
Robert
Edited by clamchip, 20 October 2024 - 05:37 PM.
  • deSitter, tim53, CCD-Freak and 6 others like this
#9553 clamchip
clamchip
  • Loc: Seattle
Posted 20 October 2024 - 06:24 PM
My Odyssey 10 reminds me of a moonshine runner's jalopy.
Looks like a moonshine runner don't it.
Stock '40 Ford on the outside so's not to attract attention to it, and practically a race car on the inside.
Edited by clamchip, 20 October 2024 - 06:31 PM.
  • deSitter, mattyfatz, CCD-Freak and 6 others like this
#9554 deSitter
deSitter
    Still in Old School
Posted 21 October 2024 - 03:39 AM
"Not tonight boy - it's Odyssey time!"
-drl
  • CCD-Freak, clamchip, Terra Nova and 2 others like this
#9555 deSitter
deSitter
    Still in Old School
Posted 21 October 2024 - 04:36 AM
Robert
Is there a rubber roller for contact with the track? Actually a vinyl one might be better. Say, a length of coax insulation. Could even try heat-shrink solder joint covering.
-drl
#9556 clamchip
clamchip
  • Loc: Seattle
Posted 21 October 2024 - 09:34 AM
-drl
It's metal on metal, and it works great now that the track is smooth. if it gives me anymore trouble I'll
make it a steel track.
Robert
#9557 John Huntley
John Huntley
  • Loc: South West U.K.
Posted 21 October 2024 - 03:24 PM
I've been busy adapting my 1985 Fullerscopes MkIII equatorial head to fit onto my Berlebach Uni 28 tripod. It will ultimately carry my brass 3 inch F/16 BC&F / Elliott refractor. I'll post pics when the whole setup is assembled, meanwhile the mount / tripod are looking quite business like:
  • davidmcgo, deSitter, CCD-Freak and 7 others like this
#9558 norvegicus
norvegicus
  • Loc: en route
Posted 21 October 2024 - 03:59 PM
Boxed it up and sent it to CO.  (FS-128, sold it to fund my next project).  Bittersweet.
  • deSitter, John Huntley and Bomber Bob like this
#9559 clamchip
clamchip
  • Loc: Seattle
Posted 23 October 2024 - 12:13 PM
Recently I've been seeing the effects of winter in the eyepiece of my 6 inch Mak.
I'm surprised I made it this far. I'm sure I got an extra month out of it because it has a ceramic primary
and 10th wave optics, but I can now see it struggling after bring it outside from my cool shop to a chilly
outdoors.
I think what's happening is rapid cooling is causing air movement inside the tube. The top inside of the
sealed tube is shedding it's heat faster and creating the air inside the tube to be in motion.
I thought I would try slowing down this process and making it less violent with Reflectix insulation. It now
looks like a macho burrito, if it works I don't care what it looks like.
I'm not sure what to do about the meniscus, I will let the felt lined plastic dew shield help at that end.
Robert
Edited by clamchip, 23 October 2024 - 12:16 PM.
  • deSitter, John Huntley, Exnihilo and 4 others like this
#9560 Cavs56
Cavs56
Posted 23 October 2024 - 01:01 PM
I was having the same issues with my Meade 2080. I did the same fix as you. It worked, views were much more stable.
  • clamchip and Bomber Bob like this
#9561 norvegicus
norvegicus
  • Loc: en route
Posted 23 October 2024 - 05:42 PM
I did it with my C9.25 last winter, extending the Reflectix a bit over the dew shield.  Worked great, instant decent views.
#9562 jragsdale
jragsdale
  • Loc: Idaho
Posted 23 October 2024 - 08:29 PM
I just finished building a peltier-powered SCT cooler for use with my closed tube scopes to help keep them cool. I've been using the other fan models to try to cool down my C14 and it would only get it within a few degrees above ambient, as my temperatures here drop fast in our desert climate. So still not ideal for critical planetary viewing.
I decided to pump below ambient temp air into the tube to cool down the mirror faster. This peltier unit draws about 5A at 12V and has a 100mm fan and heatsink on the backside blowing the warm air away from the scope, and it has a 40mm fan and heatsink on the cold side, blowing cold air into a channel that goes into the tube about half way between the baffle tube and the secondary with nozzles to direct the airflow towards the primary.
The Peltier + fans was off the shelf at Amazon. Âľ" aluminum pipe from Ace and the rest was designed and 3D printed here at home.
So far it works well, but I need to add a stronger cold side fan to push more air as the air filter I installed is choking it a bit. But it's still getting cold air into the tube quite effectively.
Edited by jragsdale, 24 October 2024 - 07:59 AM.
  • deSitter, mattyfatz, Bomber Bob and 2 others like this
#9563 clamchip
clamchip
  • Loc: Seattle
Posted 26 October 2024 - 07:06 PM
My Mak is ready to go with it's new Reflectix insulation.
It'll probably light the place up like a disco studio if I'm not careful with the lights.
Robert
Edited by clamchip, 26 October 2024 - 07:10 PM.
  • deSitter, John Huntley, Terra Nova and 3 others like this
#9564 Roger Belveal
Roger Belveal
Posted 27 October 2024 - 06:14 PM
My old Universal Astonomics tripod was in need of a paint job. So I figured I'd go Celestron orange. Now I'm trying to decide wether the mount needs to be black or just leave it white. I'm leaning for black...
  • deSitter, mdowns, Bomber Bob and 1 other like this
#9565 Roger Belveal
Roger Belveal
Posted 28 October 2024 - 05:10 PM
Decided to do the mount as well! I like it!
  • davidmcgo, deSitter, mdowns and 3 others like this
#9566 deSitter
deSitter
    Still in Old School
Posted 28 October 2024 - 05:34 PM
Sure! That's a complete scope. :) Trick or treat! Awesome!
-drl
  • kjkrum likes this
#9567 clamchip
clamchip
  • Loc: Seattle
Posted 29 October 2024 - 10:57 AM
During a brief intermission from my clam chipped telescope junk yard I took on a Russian center focus 8 x 40 binocular
I bought at a swap meet for 8 dollars some time ago. Can you believe it $8, the asking price. I have a feeling it's
because this binocular is a bit crude looking and could be mistaken for a cheap one. Don't let that fool you, buy it.
Cleaning and a stiff focuser, good as new, built like a vintage American Standard 5 gallon flush toilet.
I just wanted to mention this because it is superb, just like the Russian telescopes I've enjoyed very much.
Robert
Edited by clamchip, 29 October 2024 - 11:05 AM.
  • deSitter, CCD-Freak, Terra Nova and 3 others like this
#9568 MGAR
MGAR
  • Loc: North Seattle
Posted 29 October 2024 - 01:55 PM
Not mine anymore but Clamchip now has two pumpkins...
  • deSitter, clamchip, Terra Nova and 4 others like this
#9569 CCD-Freak
CCD-Freak
  • Loc: Graham,Texas
Posted 29 October 2024 - 10:15 PM
Clamchip made me do it !!!!  (^8
  • deSitter, tim53, clamchip and 4 others like this
#9570 Terra Nova
Terra Nova
Posted 30 October 2024 - 11:58 AM
Happy Halloween to all of you from Falls City!
  • CCD-Freak, clamchip, Bomber Bob and 2 others like this
#9571 scout
scout
  • Loc: Mount Diablo, CA
Posted 30 October 2024 - 05:53 PM
I disassembled my Meade ETX-60 to get to the tarnished diagonal flip mirror that needs replacement. It's crazy how the entire assembly has to be taken apart just to reach the mirror. I might as well clean off the gobs of thick slime from the gears and re-grease them while I have it open.
It was actually kind of fun figuring out how to take it apart without consulting a video or guide.
Edited by scout, 30 October 2024 - 06:06 PM.
  • deSitter, Bomber Bob, LU1AR and 1 other like this
#9572 clamchip
clamchip
  • Loc: Seattle
Posted 31 October 2024 - 12:16 AM
Today I cleaned my favorite star diagonal, the first time I've done this to it I reckon.
I like this one because it's dead nuts 90, and the ports and prism are as large as possible. Also the colors
presented through it are very natural, it doesn't change colors like some of my modern multi-coated and dielectric
star diagonals.
I decided on disassembly vs Q-tips or other means, less risk of a scratch. Removing the prism enabled me to
clean it under a flood of tap water with cotton balls, like I like to do with optics.
You remove the prism cover and push the prism out of the body with a protected finger. The prism is
sandwiched between cardstock shims on both sides of it. You install the prism by pushing it home against
the ports and if the body is nice and square like this one is you're done.
Robert
Edited by clamchip, 31 October 2024 - 12:21 AM.
  • deSitter, CCD-Freak, Bomber Bob and 1 other like this
#9573 deSitter
deSitter
    Still in Old School
Posted 31 October 2024 - 12:48 AM
star diagonals.
Robert
R.F.A.?
I have a Celestron/Japan 45 deg Amici prism erector. It has a plastic body, but the plastic is the modern sort that is so hard and perfect you could machine it. In fact the screws that keep it together are machine screws. Same thing, push in the prism between the shims unit it seats and you're done. It is the sort of plastic you don't mind dealing with.
-drl
#9574 clamchip
clamchip
  • Loc: Seattle
Posted 31 October 2024 - 09:59 AM
R. F. A. is Rich Field Adapter. It came with a focal reducer I'm pretty sure.
It's a nice plastic, Bakelite. And yes machine threads as if it were made of metal.
Some even have brass inserts for the screw threads if you go back far enough.
As time went on the product was cheapened by removing the cast-in brass inserts
and the set screws to center and hold the prism in the housing.
A very good star diagonal that came with the Celestron SCT telescopes, plenty
of them out there for sale.
Robert
Edited by clamchip, 31 October 2024 - 10:01 AM.
  • kjkrum likes this
#9575 Cavs56
Cavs56
Posted 31 October 2024 - 11:06 AM
I couldn’t find a 2 inch adapter for my Meade 826 so I made one. I bought a piece of 2 inch I.D. 2.5 inch O.D. Aluminum pipe. It was a little over 3 inches long. It was about .005 too small I.D. Which is better than too big. I reamed it until it was close then wet sanded until the 2 inch eyepiece and the 1.25 adapter fit. I drilled and tapped the hole for the screw that holds the eyepiece. I filed a notch for the 1.25 adapter. I have read that these came with a two inch extension. My 40mm and Galoc eyepieces I had to pull out of the factory adapter to achieve focus. I had the machine shop cut it 1.25 inches longer than the 1.25 adapter it came with. The also cut the threads. Lastly I wet sanded with 350,500, and 1000 grit sandpaper then used a polishing compound. I may eventually paint it black.
  • deSitter, Bomber Bob and kjkrum like this
