I couldn’t find a 2 inch adapter for my Meade 826 so I made one. I bought a piece of 2 inch I.D. 2.5 inch O.D. Aluminum pipe. It was a little over 3 inches long. It was about .005 too small I.D. Which is better than too big. I reamed it until it was close then wet sanded until the 2 inch eyepiece and the 1.25 adapter fit. I drilled and tapped the hole for the screw that holds the eyepiece. I filed a notch for the 1.25 adapter. I have read that these came with a two inch extension. My 40mm and Galoc eyepieces I had to pull out of the factory adapter to achieve focus. I had the machine shop cut it 1.25 inches longer than the 1.25 adapter it came with. The also cut the threads. Lastly I wet sanded with 350,500, and 1000 grit sandpaper then used a polishing compound. I may eventually paint it black.
Nice work! This is an ideal candidate for home anodizing, home electrochemistry at its smelly, dangerous best.
https://sendcutsend....ng-in-10-steps/
-drl
