What did you do to your Scope/Mount Today?
10395 replies to this topic
#10176 clamchip
clamchip
  • Loc: Seattle
Posted 04 May 2025 - 05:32 PM
Be careful that you're not looking at an enlarged image of the ronchi screen off the flat.  That's happened to me more times than I care to admit.
What would tip me off if I'm looking at an enlarged image of the ronchi screen off the flat?
It's definitely going thru the right channels I'm sure of that, and I tested multiple times and got the same results.
It's just odd I can change the mirror spacing as much as I did without introducing spherical aberration. I can
move the primary a total of 1/2" inch, and dead straight jail bars the entire travel.
I'm very new to DPAC and have only tested a few Mak's so I'm not exactly sure what to expect. I look at the test
take notes and if I have questions I hunt for the answer.
When I read about some of the mirror spacing tolerances in the thousandth's you would think moving the mirror
a 1/2" you would see some bending in those bars, as sensitive as DPAC is.
Robert
Edited by clamchip, 04 May 2025 - 05:40 PM.
  • tim53 likes this
#10177 Eddie_Concatenate
Eddie_Concatenate
  • Loc: Maryland
Posted 04 May 2025 - 09:28 PM
I stared at my new FF107 as it served it's "time-out" in the corner. 8 days of rain in the forecast. Still waiting on the OAG.
  • LU1AR likes this
#10178 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 05 May 2025 - 05:54 AM
Not a classic.
#10179 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 05 May 2025 - 11:10 AM
This is an old CG-5 hub sitting on one of my tripods:
Here's an 826 (or 628) Meade mount.  I drilled and tapped a hole and added in a long bolt:
The 826 mount fits perfectly onto the CG-5 hub:
I initially thought that the post on the CG-5 mount would interfere, but it doesn't.  It helps to stabilize the 826 mount.
Edited by Garyth64, 05 May 2025 - 11:58 AM.
  • davidmcgo, deSitter, tim53 and 8 others like this
#10180 tim53
tim53
  • Loc: Highland Park, CA
Posted 05 May 2025 - 11:33 AM
Robert
First question:  Do you see the secondary shadow?  I actually wasted an hour or so on the 6" Kludgescope looking at what I thought was a terrific ronchigram, only to have Dave point out to me that there was no secondary shadow, so I couldn't have been looking at reflections through the system.
With my 6" Gregorian, the problems I've had testing it for figuring the secondary have been exacerbated by the fact that none of the surfaces are coated, and the secondary is made from a 2" flat, so I can get reflections off the back of the secondary that fool me.  I've never found the dpac reflection so I think I'll need to build an ota, collimate the optics on an insulator in daylight, then put it on the bench and align it with the test flat.
-Tim.
#10181 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 05 May 2025 - 12:01 PM
Tim, fine grind the back of the secondary.  Then you can null the Gregorian secondary.
  • tim53 likes this
#10182 clamchip
clamchip
  • Loc: Seattle
Posted 05 May 2025 - 03:59 PM
-Tim.
I do see the secondary and everything does seem to be running like it should.
I'll see how it looks in a star test which is coming up soon.
Robert
  • jkmccarthy likes this
#10183 deSitter
deSitter
    Still in Old School
Posted 05 May 2025 - 05:14 PM
Robert
You'll be happy :)
-drl
#10184 clamchip
clamchip
  • Loc: Seattle
Posted 05 May 2025 - 05:59 PM
I know the star test from this scope will be a thing of beauty, the DPAC sure is.
But what has me wondering is why I can't change the jail bars in a 1/2 inch of mirror movement.
There's a optimum spacing and I know where that is, and it's perfectly corrected there, and
everywhere around it too!
Maybe it takes more mirror movement before I'll see some bent bars, I only have 1/2 inch.
If I unscrew the front and rear cells and line the cells up on the bench I can have any mirror
separation I want. I'm not willing to do that unless another reason pops up like a mirror cleaning.
I might use another Mak for a guinea pig. Problem is I only own one other Mak with a perfect
DPAC and it has fixed mirrors.
Robert
Edited by clamchip, 05 May 2025 - 06:22 PM.
#10185 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 05 May 2025 - 06:11 PM
Robert, I have a question.  Where is the focus when you move the secondary?  Which way are you moving the secondary? (ok, two questions)
I know you know, that in these types of scopes moving the secondary a little moves the focus a lot.  I'm thinking that if you move the secondary 1/2", the focus would move very much, maybe even several inches.  So, let's say you see straight lines before you move the secondary.  Then you move the secondary, and depending on the direction you moved the secondary, did you move the ronchi to the new focus?  If not, then you could either be far inside the focus, or far outside the focus, and then the lines might continue to look straight.
Edited by Garyth64, 05 May 2025 - 07:48 PM.
#10186 clamchip
clamchip
  • Loc: Seattle
Posted 05 May 2025 - 06:38 PM
I didn't measure where in the 1/2" of mirror movement I found infinite focus with the supplied 26mm, I wish
I had. I did move the Ronchi to the new focus every time I moved the mirror. And at every new focus I observed
the bars both sides of this new focus looking for any change in the bars. My flat is uncoated but I can see
very well in white light. I see no color fringing on the bars the meniscus might add, no CA, so I did all the testing
with white light.
I did remove the control box so I could get right up to the port in the rear cell, and the other direction I add
quite a few inches of back focus by changing the mirror spacing. Still though I was limited to 1/2" mirror
movement by the focusing mechanism and the clip on the sky end of the baffle tube.
Robert
Edited by clamchip, 05 May 2025 - 06:50 PM.
  • Garyth64 likes this
#10187 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 05 May 2025 - 09:29 PM
  • deSitter and steve t like this
#10188 deSitter
deSitter
    Still in Old School
Posted 05 May 2025 - 10:22 PM
A man's reach should exceed his grasp. :)
-drl
#10189 ericb760
ericb760
  • Loc: Palm Springs, CA
Posted 06 May 2025 - 09:55 PM
A recent thread here regarding 60mm tube rings got me remembering that I had a set from a Celestron CO-60 I picked up awhile ago. I also scored a Bushnell SkyChief Jr. 60/700 in the original box last year. Unfortunately, the mount is in need of repair and I haven't got around to it yet. Instead, I mounted the Bushnell OTA onto my Svbony 225 mount with the 60mm rings. I also swapped out the original .965 visual back with a 1.25" that fit perfectly, allowing for 1.25 EP use.
I gotta say that for a scope nearing 60 years old, the views of the moon are nothing short of astonishing. No CA at all and the view is almost freaky sharp.
Bushnell1
Bushnell
Bushnell2
Moon Bushnell
Edited by ericb760, 06 May 2025 - 11:00 PM.
  • k5apl, steve t, Marc-Andre and 3 others like this
#10190 norvegicus
norvegicus
  • Loc: en route
Posted 07 May 2025 - 10:17 AM
Those are amazing scopes.  Modern 1.25" eyepieces really wake them up.  Mine always made me smile every time.
Edited by norvegicus, 07 May 2025 - 10:17 AM.
  • ericb760 likes this
#10191 deSitter
deSitter
    Still in Old School
Posted 07 May 2025 - 10:39 AM
I am amazed by my 80/900mm Vixen, which can get to lower powers with long Plossls. It is harder to appreciate the virtues of classic refractors at f/16 instead of f/11.
-drl
  • Bomber Bob likes this
#10192 CHASLX200
CHASLX200
Posted 07 May 2025 - 10:47 AM
I rolled the AP900 2 feet to put on a wall plate just now.
#10193 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 07 May 2025 - 02:06 PM
  • deSitter likes this
#10194 scout
scout
  • Loc: Mount Diablo, CA
Posted 07 May 2025 - 02:30 PM
I've taken apart the alt-az mount to my Asahi-Pentax 60mm f/13.3 to adjust the alt motion. It was getting a bit jerky. After 65 years the original grease is black sludge, so I need to clean and relubricate it.
I've been using the refractor on another mount lately and I miss using the classic mount with the unique clutches. I've always wanted a modern long-fl 60mm Takahashi, but every time I use the old Asahi-Pentax I lose that urge. It's such a sharp refractor.
  • deSitter, Bomber Bob and Kitfox like this
#10195 deSitter
deSitter
    Still in Old School
Posted 07 May 2025 - 03:09 PM
Chas has a go-to mount after all - "Go to the living room."
-drl
#10196 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 07 May 2025 - 03:15 PM
I haven't tested one of the A-P 60x800 refractors yet, but I doubt you'd be blown away by my 1972 TS-65S / 1000.  IME, with these top-tier old scopes, the differences are more aesthetic than analytical.  This Triplet has better color-correction than the '56 GOTO 60 F20 that I had, but both showed the same very fine lunar & planetary details.  Ditto comparing the FC-50 F8 vs my TS-50 F14.
  • scout likes this
#10197 starhunter50
starhunter50
  • Loc: Tilbury,Ontario 42N , 82W
Posted 07 May 2025 - 03:31 PM
building a new spider vane system for my Taiwan 8 inch F3.75 , scope.
  • ericb760, steve t, Bomber Bob and 2 others like this
#10198 CHASLX200
CHASLX200
Posted 07 May 2025 - 06:15 PM
2" a sec.
#10199 deSitter
deSitter
    Still in Old School
Posted 07 May 2025 - 07:58 PM
2" a sec.
Everyone in Florida drives like a maniac!
-drl
  • steve t and Bomber Bob like this
#10200 deSitter
deSitter
    Still in Old School
Posted 07 May 2025 - 07:59 PM
What is the effect on the diffraction pattern of non-radial vanes? That would worry me.
-drl
  • starhunter50 likes this
