https://stellafane.o...ltbearings.html
stellafane says the optimal size is 1.8X the mirror diameter. Going up to 2X seems a logical step.
There is no "optimum" size. The radius of the Alt bearings determines the position of the Alt axis of rotation and the OTA balance as a result. You optimize it for your scope, depending on relative masses of the UOA and LOA (upper and lower optical assemblies, aka mirror box and secondary cage).
Because the Alt bearings are just a segment of a disk, they move the center of mass of the OTA off of the optical axis, to "forward", or "below" it, depending on angle of the OTA. Other off-axis things such as focuser/ep assembly also effect that.
