What did you work on today?
4768 replies to this topic
#2501 Andy Tucker
Andy Tucker
Posted 05 March 2018 - 07:25 PM
Finally finished assembling Dale's 3-axis stage.
Despite being a small project, it STILL took 2 trips for hardware!
  • CCD-Freak, roscoe, brave_ulysses and 8 others like this
#2502 Bob4BVM
Bob4BVM
  • Loc: W. Oregon
Posted 08 March 2018 - 02:10 PM
Universal lens-testing EP, to test performance of various low-glass EP candidate lenses. Two cells handle lens diameters 9-31MM, easy to change cells & lenses in the dark for OTF star-testing of single lenses & simple combinations.
More details in the EP forum.
CS
Bob
Edited by Bob4BVM, 08 March 2018 - 02:11 PM.
  • PrestonE, Rusted, brave_ulysses and 8 others like this
#2503 arcainemachinest
arcainemachinest
    Vendor (machinist)
  • Loc: Jacksonville Florida
Posted 09 March 2018 - 10:17 AM
mark 2 pattern for my mirror casting project
mirror6
mirror7
  • brave_ulysses and Augustus like this
#2504 jtsenghas
jtsenghas
  • Loc: The flatlands of Northwest Ohio 41.11N --Bloomdale
Posted 09 March 2018 - 08:36 PM
Looks nice! I like the large internal radii at the ends of the "spokes" or ribs, but why are they curved? I don't see a structural or manufacturing advantage to that design element. Can you explain?
  • Augustus and wna like this
#2505 arcainemachinest
arcainemachinest
    Vendor (machinist)
Posted 10 March 2018 - 12:46 PM
years ago i worked in a shop where we did proprietary milling programs on solid slabs of aluminum to make money comb structures for air craft  parts. these parts all had radial style ribs. we tested the radial vs the straight on twisting and flexing the parts with the radial ribs were very hard to twist or flex.
  • Augustus likes this
#2506 mark cowan
mark cowan
    Vendor (Veritas Optics)
  • Loc: salem, OR
Posted 10 March 2018 - 01:54 PM
They do have more mass than straight ribs...
#2507 Oberon
Oberon
  • Loc: Hunter Valley NSW Australia
Posted 10 March 2018 - 05:57 PM
Yes, it is reasonable to expect that curved radial arms will improve resistance to twisting, which is important in an aircraft structure, essentially because the curved support works in two dimensions. But that improvement comes at the expense of stiffness in the direction that applies to the much simpler gravitational forces on a mirror. Or else the aircraft structure was two plates separated by a honeycomb, which is an entirely different structure, and exactly what we recommended earlier in the thread.
#2508 Mike G.
Mike G.
  • Loc: Oberlin, Ohio
Posted 10 March 2018 - 05:59 PM
busy but productive day.  completely flocked the C6 (tube, secondary cell and baffle), then blackened the edge of the primary where the chamfer is ground.  cleaned everything up and put it outside to cool so I can collimate it tonight - looks really dark inside the tube now!  happy!  then, took the power board off my CG5 and fixed the on/off switch which had been causing some power downs during use.  back together now with no problems. just have to fix the dishwasher now before it gets dark or the wife will be unhappy....
  • Augustus and Allanbarth1 like this
#2509 Eikonal
Eikonal
Posted 11 March 2018 - 02:36 PM
I made a couple of supports for a counterbalance bar and for a finderscope.StuetzenimDrucker.jpg Stuetzen1.jpg
  • brave_ulysses, Pinbout and dmcnally like this
#2510 JohnH
JohnH
  • Loc: Squamish BC Moved!!!!!
Posted 11 March 2018 - 05:36 PM
Worked on getting back into shape instead of wasting time online
  • Pinbout, Eikonal, member010719 and 3 others like this
#2511 TonyStar
TonyStar
Posted 20 March 2018 - 06:31 PM
I converted my GSO laser collimator to barlowed laser. I only use the laser for aligning the primary (and then fine tweak on a star) and I was tired of sliding a barlow in and out every time....
  • Pinbout and cmooney91 like this
#2512 Joe1950
Joe1950
Posted 20 March 2018 - 07:47 PM
How is that done, if I may ask?
#2513 TonyStar
TonyStar
Posted 20 March 2018 - 08:17 PM
I removed the perforated aluminum block, slightly enlarged the pinhole on the back of the block and inserted a small (5mm dia) double concave lens in it.
  • Joe1950 likes this
#2514 Joe1950
Joe1950
Posted 20 March 2018 - 08:20 PM
#2515 TonyStar
TonyStar
Posted 20 March 2018 - 08:23 PM
Forgot to mention, you need to use a lens with at least 60-70mm (negative) F.L. otherwise the beam will be too spread out and the center dot shadow too dim.
  • Pinbout and Joe1950 like this
#2516 Joe1950
Joe1950
Posted 20 March 2018 - 08:34 PM
Okay. I'll check Surplus Shed. Thanks
Edited by Joe1950, 20 March 2018 - 08:35 PM.
#2517 Sean Cunneen
Sean Cunneen
    Let Me Think
  • Loc: Flossmoor Il.
Posted 21 March 2018 - 09:44 AM
I started this thread 3 years and one month ago, we are at 101 pages of ATM awesomeness! I dont think there has been more than a couple of days without a post! You guys make this niche of the hobby so cool, keep it up
Sean
Edited by Sean Cunneen, 21 March 2018 - 09:45 AM.
  • PrestonE, sglamb, roscoe and 3 others like this
#2518 Allanbarth1
Allanbarth1
  • Loc: Central New Jersey
Posted 21 March 2018 - 10:34 AM
Thanks for starting this thread. It's given me a few ideas of things to make or modify. One of the threads I truly look forward to see what's posted next.
  • brave_ulysses likes this
#2519 Rusted
Rusted
Posted 21 March 2018 - 11:42 AM
  • roscoe likes this
#2520 philipdo
philipdo
  • Loc: Flanders, Belgium, Europe
Posted 23 March 2018 - 11:42 AM
At our last club meeting a fellow ATM'er gave away this fully functional JMI motofocuser because of a crack in the plastic motor cover.
I took it home, replaced the cover and adapted it to the focuser of my 200 mm Kutter Schiefspiegler. I did not attach it directly to the shaft of the reduction knob but worked with a rubber belt for transmission of the slow movement. Works extremely well. It is a joy now to focus this f20 scope without touching anything and without vibration at high powers. Only drawback: since I need quite some focusing travel, when switching eyepieces, I remove the belt, do the coarse focusing by hand, put on the belt again an do the fine focusing in all comfort. Will be extremely helpful for webcamming the planets.
Edited by philipdo, 23 March 2018 - 11:44 AM.
  • brave_ulysses, Pinbout, dmcnally and 4 others like this
#2521 TonyStar
TonyStar
Posted 12 April 2018 - 09:22 PM
Due to crappy seeing and bad weather I decided to take the scope apart (literally, since it breaks down to fit in a suitcase) and to paint/powdercoat a bunch of parts (long overdue). Here is the UTA upper ring painted black
Those vanes are thin!
Edited by TonyStar, 12 April 2018 - 09:22 PM.
  • brave_ulysses, jdupton, Eikonal and 3 others like this
#2522 ImNewHere
ImNewHere
  • Loc: Bremen (but really Lakeville), IN
Posted 12 April 2018 - 09:27 PM
Finished my SN10 rebuild other than final collimation tweaking and touch up paint in a few spots.
#2523 Andy Tucker
Andy Tucker
Posted 12 April 2018 - 10:35 PM
I printed a holder for 1.25" filters to fit into a UV/Vis spectrometer the other day.  Today I tested a cheap filter:
  • PrestonE, brave_ulysses, Eikonal and 2 others like this
#2524 roscoe
roscoe
    curmudgeon
  • Loc: NW Mass, inches from VT
Posted 13 April 2018 - 06:49 AM
wouldn't it be wonderful if we all had access to real test equipment??   (I'm jealous!)
No more....I think this is a little yellower than that one, or I think this one scatters more than that one, just stick it in the magic box, and....yep, this diagonal's mirror is smoother than that mirror...or whatever.....
#2525 Oberon
Oberon
Posted 13 April 2018 - 07:03 AM
Beautiful and elegantly engineered. Everything is just right.
  • TonyStar likes this
