What did you work on today?
4966 replies to this topic
#4951 bbbriggs
bbbriggs
  • Loc: Graham WA
Posted 09 August 2020 - 04:52 PM
52706C84-4CF0-4145-B165-CC7CB69658E5.jpeg 7EA4517A-F6AC-4120-8E2C-E3ECC5D0EC59.jpeg E7D03508-AA77-4ADF-BFC6-1BEAC5D0E591.jpeg Making more progress.
  • brave_ulysses, jdupton, Augustus and 2 others like this
#4952 mark77
mark77
  • Loc: PA
Posted 10 August 2020 - 01:10 PM
I cut down trees blocking my westerly view
  • bbbriggs, brave_ulysses, dmcnally and 3 others like this
#4953 don clement
don clement
    Vendor (Clement Focuser)
  • Loc: Running Springs, California
Posted 10 August 2020 - 01:38 PM
Worked on modifying the clutch mechanism on the Byers 8" worm gear set for use on the small GEM I am making so it fits on the 2.5" diameter RA shaft. I really like Byers  clutch design as it is floating wrt not putting any sideway force on the RA shaft or worm gear. I am going to replace the six 1/4" Nylon slugs  used as the radial bearing surface between the clutch hub and 4.25" diameter central hole in the aluminum worm gear with Turcite slugs. I will then chuck up the clutch hub in the lathe and in the same holding setup (not removing the clutch hub from chuck) open up the central hole bore to fit a 2.5" diameter shaft, turn the Turcite slugs to fit into the 4.25" hole in the worm gear,  undercut with grooving tool where the Turcite slugs meet the shoulder, and square shoulder surfaces. This way all turned surfaces are concentric and square.
Don
Edited by don clement, 10 August 2020 - 08:35 PM.
  • mark cowan, bbbriggs, brave_ulysses and 7 others like this
#4954 jtsenghas
jtsenghas
  • Loc: The flatlands of Northwest Ohio 41.11N --Bloomdale
Posted 11 August 2020 - 09:56 AM
I converted a TELRAD into a TELRUNT yesterday.
Details here
  • mark cowan, Mike Lynch, CCD-Freak and 6 others like this
#4955 macdonjh
macdonjh
Posted 11 August 2020 - 12:44 PM
Details here
  • jtsenghas likes this
#4956 charlieb123
charlieb123
  • Loc: New York
Posted Yesterday, 12:43 PM
Today @ lunch I made a bracket to mount a 50mm guide scope to an AT80ED.
  • brave_ulysses likes this
#4957 charlieb123
charlieb123
  • Loc: New York
Posted Yesterday, 12:51 PM
Also scrambled together an adapter to mount an HEQ5P to a wood tripod.
Rendering of tripod using the base adapter for wood tripod.
I ordered a bunch of material to make my own (someday).
  • dmcnally and Bill Schneider like this
#4958 charlieb123
charlieb123
  • Loc: New York
Posted Yesterday, 12:54 PM
Since I can't seem to find a decent cam anywhere I started designing my own using a Sony IMX291 sensor ($40).
Won't be as great as a ASI but should be adequate guide camera for my cheap DIY AP rig.
Edited by charlieb123, Yesterday, 12:55 PM.
  • brave_ulysses, Bill Schneider, mark77 and 3 others like this
#4959 Piero DP
Piero DP
  • Loc: Cambridge, UK
Posted Yesterday, 05:26 PM
In these days I completed my mirror cell. Triangles are in aluminium, bars and tailgate in stainless steel. Ring and fan board in ABS plastic. Fan is a Noctua 80mm. Glatter's sling.
All metal was cut with a jigsaw. Holes were drilled using a drill + Big Gator tools (great tools btw).
Rungs have a wall thickness of 3mm.
The cell was designed using PLOP.
Following post shows another profile. Collimation bolts are in stainless steel. The original M8 thread of the hand knobs was re-tapped for 3/8"-24 (UNF) threaded rod - which was cut too - for making the bolts. Collimation travel is 1/2". Loctite Blue was used for locking the nuts.
The nuts used for making the side pins bolts and the hand knobs for the collimation bolts were locked with Loctite green.
Next step: making the UTA. :)
Edited by Piero DP, Yesterday, 05:43 PM.
  • bbbriggs, brave_ulysses, dmcnally and 4 others like this
#4960 Piero DP
Piero DP
Posted Yesterday, 05:36 PM
  • musicengin and Himal Bhandari like this
#4961 bbbriggs
bbbriggs
  • Loc: Graham WA
Posted Yesterday, 07:44 PM
688DE953-D593-45AE-A696-1216C3BC7C4F.jpeg Oops
  • Himal Bhandari likes this
#4962 jtsenghas
jtsenghas
Posted Yesterday, 07:49 PM
Nice cutaway sample of a pocket screw!
(Is the recovery plan to install another nearby and to make a thin face frame? )
#4963 bbbriggs
bbbriggs
  • Loc: Graham WA
Posted Yesterday, 08:26 PM
I am going to screw a 3/4” thick piece of plywood to the top so I will probably just leave it out.
#4964 greenglass
greenglass
  • Loc: Hamilton. Ontario, Canada
Posted Yesterday, 08:39 PM
a long dob, 6.2"/95"FL.  almost done the 4 foot long bottom tube out of plywood.  bolting a 4 foot sonotube on it. I wonder how long before it gathers dust for being too big.
#4965 N7GTB
N7GTB
  • Loc: Kennewick, WA.
Posted Today, 12:41 AM
Made a 6" dia pitch lap to begin polishing the mirror...  When I took the second photo, I didn't quite have enough Cerium Oxide layer.  I've added more, and the lap looks considerably more white in color.  I'll need to trim the extra pitch around the edges, but other than that plan to begin polishing soon (tomorrow morning I hope!).
  • Himal Bhandari and GLS like this
#4966 sw196060
sw196060
Posted Today, 07:26 AM
Nice. Would love to see pics of the project.
#4967 GLS
GLS
Posted Today, 04:01 PM
I started rough grinding on a 6.25" pyrex blank.  Target is ROC of 32.4" for an F/2.7 mirror.  I have another project ongoing as well.  I have a surplus quartz mirror with a 32" ROC that I picked up surplus over 25 years ago.  A few  years ago, I lowered the curve using the turbo diamond cup manually to 54" and have started fine grinding with a tile tool.  I've put that on hold until I catch up with the 6".  That will lessen chances of grit contamination.  I've got about an hour and half into the smaller mirror and have generated so far a sag of .02" with target of .138". I've used up about 4 oz. of #80.  I've used a pipe flange, a paperweight with pennies on the edge and the diamond cup as ring tools.  Both the flange and cup are awkward to hold, but I solved that by inverting the pipe flange over the diamond cup.  It's working smoothly.  Not having made a mirror in over 25 years, I decided to start out small; the F/2.7 focal length is problematical enough without starting on the 10".  I am tempted to use #40 carbo for a spell.  Gil
  • N7GTB likes this
