A clean poorly lit place
83 replies to this topic
#51 macdonjh
macdonjh
Posted 29 April 2019 - 08:15 PM
Go figure, the soaking wet, pressure treated 4x4s I used for my gantry beams warped as they dried out in the Texas sun and heat.  I had a distinct downward bow in both beams.  Rolling my roof downhill, then back uphill was a pain.  Time to install a couple new columns to take the bow out.
A good day to be in the country, playing in the sunshine.
My car did not like carrying 400 lb of concrete in the trunk.  Good thing the hardware store is only ten miles from my club's dark sky site.
More below, file size limit, you know.
#52 macdonjh
macdonjh
Posted 29 April 2019 - 08:18 PM
First order of business was to get the holes drilled with an auger and pour the concrete.  If you look hard you can see a couple of stubs of Sonotube sticking up near the edge of the cleared ground under my gantry.
Got the Sonotube removed, too, so the concrete is clean and fresh looking.
#53 macdonjh
macdonjh
Posted 29 April 2019 - 08:19 PM
And finally, new columns installed.  My gantry beams are back to being level and my roof is easier to open and close.
  • gundark likes this
#54 macdonjh
macdonjh
Posted 21 September 2019 - 01:06 PM
A small, but satisfying addition today:
Before:
After:
  • jcj380 and Stevegeo like this
#55 jcj380
jcj380
  • Loc: Hellinois
Posted 23 September 2019 - 08:50 AM
Really nice build there.  Curious though - how much "oomph" does it take to roll off your roof?  It looks pretty substantial.
#56 macdonjh
macdonjh
Posted 23 September 2019 - 10:03 AM
Getting it started requires some effort, but once it is rolling it's not too bad. It is a two-handed effort, though, I can't move it with one arm. It would have been much lighter if I had used metal roofing, but I like the look of shingles.
I am toying with the thought of installing a winch. I haven't because pushing the roof by hand is quick and not onerous. Even at 3:00 am.
  • jcj380 likes this
#57 macdonjh
macdonjh
Posted 27 October 2019 - 10:36 AM
I found weather like this when I arrived at my observatory Friday to install my new-to-me mount:
This was my starting point:
Time to get to work.
#58 macdonjh
macdonjh
Posted 27 October 2019 - 10:43 AM
First, out with the old:
You can see a touch of rust on the cap screws holding my saddle on:
My G11 is off and I am reminded how I installed the Losmandy MA adapter.  I'd forgotten how many small screws I'd used.  The 1/2" bolt is 6" long with a washer or two at the end to hold it in place.  The small screws are threaded into coupling nuts at the ends of longer screws.
A few taps with a rubber mallet persuaded the concrete to let go of the MA.  I will recycle the MA for my portable pier which came with my MI-250.
And...
#59 macdonjh
macdonjh
Posted 27 October 2019 - 10:50 AM
My observatory looks a little empty with my scope on the floor and mount off.  You can see that piece of blue tape.  That's for marking north, as established by the installation of my G11.  It didn't work as well as I wanted, parallax between my plumb bob string and my pier caught me.
Setting the jig I made to ensure I drilled the anchor bolt holes plumb.  I was nervous I'd drill crookedly and come out the side of my pier.  You may be able to see in the photos there are three jack screws on top for leveling, and one on each side for securing the jig to my pier, making sure it didn't move as drilled the holes.  Checking for level here:
Adjusting the jack screws to level the jig:
And "screwing my courage to the sticking place", I started drilling:
Edited by macdonjh, 27 October 2019 - 10:52 AM.
  • Shannon Foye likes this
#60 macdonjh
macdonjh
Posted 27 October 2019 - 11:02 AM
First to clear the holes of dust and junk.
Even with the cup from my morning coffee, I still got mortar dust in my mouth and nose.  I'm sure the State of California would now refuse me health coverage because I'm a cancer risk.  smile.gif
It appears I missed a photo op or two.  No photo of my pier plate acting as a template to hold the anchors in place while the epoxy sets.  The directions said an hour or so (the De Walt epoxy is expensive, but it develops full strength fast).
And here is the form for the mortar:
And my pier with the mortar poured.  After screeding the mortar (and scooping out my anchors, should have put the screws in, duh), I set my pier plate and set it.  Then I used a trowel to remove the excess mortar.  The eye bolt and black hex head cap screws are jack bolts to help unseat my pier plate from the set mortar.
The mortar set much more quickly than I anticipated.  I was able to strip the forms Friday night, exposing the mortar to the air so speed up setting.  It was a good thing I had those jack screws: it took a couple full turns of all three to put enough up-force on the plate to get the mortar to let go.  There would have been no way to get the plate off without damaging the mortar without jack screws.
Edited by macdonjh, 27 October 2019 - 11:06 AM.
#61 macdonjh
macdonjh
Posted 27 October 2019 - 11:16 AM
After dark Friday night, I bolted my pier plate to the RA housing, so everything would be ready on Saturday morning.  After using a rubbing stone to smooth out the mortar, and remove some excess (and create a LOT of dust), I was ready to install the RA assembly.
Next was the declination assembly...
And...  done.
  • tim53 likes this
#62 macdonjh
macdonjh
Posted 27 October 2019 - 11:18 AM
Ready to go for the evening.  Polar alignment is off, so I need to work on that, but my MI-250 carries my scope better than my G11.
  • tim53 and drprovi57 like this
#63 brave_ulysses
brave_ulysses
  • Loc: far outside the wire
Posted 29 October 2019 - 06:08 PM
beautiful mount and obs - well done
#64 macdonjh
macdonjh
Posted 27 August 2020 - 10:10 AM
This past weekend I finally installed gutters on my observatory.  The gutter on the north side will hopefully slow the rot in my door.  I'll need to replace the door eventually.
The gutter on the south side was effective that same night in keeping dew from rolling off my roof onto the floor inside when I left the roof open.  I typically close my roof when I go to sleep exactly because one time when I left it open I had a pool of water on the north side of the floor the next morning.  It was nice to wake up and see the sky during the night.
#65 macdonjh
macdonjh
Posted 07 March 2021 - 11:35 AM
It's been close to four years and four months since I broke ground.  It is time for some upgrades to the inside.  Before I started I took a couple of "before" photos.  The first is through the doorway:
#66 macdonjh
macdonjh
Posted 07 March 2021 - 11:36 AM
... and the second is looking over the west wall:
#67 macdonjh
macdonjh
Posted 07 March 2021 - 11:38 AM
From later February 27, after the work for the day was complete (through the doorway):
And viewing over the west wall:
#68 macdonjh
macdonjh
Posted 07 March 2021 - 11:39 AM
A bonus photo, looking over the east wall:
#69 macdonjh
macdonjh
Posted 07 March 2021 - 11:47 AM
From yesterday, March 6:
As you can see from the previous photos I have condensation in my observatory.  I've almost never seen it, my gear is always dry when I arrive to observe.  I have seen a sheen from water on the floor once or twice, but that's all.  I was surprised when I removed the vinyl tile and found enough water to drip off the tiles.  Hopefully the water-proofing coating I've applied will stop that now.  The product I chose is supposed to be effective at water proofing basements from water under hydrostatic pressure; not just a sealer designed to keep rainwater from penetrating the top surface of a patio.  I hope it works.
The gray goop on my pier: when I was building my observatory I had planned to apply a skim coat of mortar to my pier to cover all the honeycomb and the spiral mark from the Sonotube.  I got impatient and painted it before I smoothed it.  Last year I called around and asked a few companies if they made a concrete patching product which would adhere to concrete coated with latex paint.  Everyone said no, I needed bare concrete.  My son and I had a brainstorm early last week, and I tried some Bondo yesterday.  It appears to work well.  I'll need to do a lot of sanding, though.
#70 macdonjh
macdonjh
Posted 13 March 2021 - 11:31 PM
Today was a long day, but the heavy lifting is done.  I went out Friday after work and got a few hours' in before dark.  I got the sheet rock trimmed away from the sole plate to make room for my new floor.  Then I installed the furring strips I cut last week.  Early to bed.
I was up and at it by 6:30 Saturday.  first step was to break into several boxes of my flooring and start sorting for length and color (actually, just two colors: "blonde" and "not-blonde").  That took a surprisingly long time.
First mishap: I had planned to glue the floor boards together at their ends and then push them together, leaving the floor floating.   However, I wasn't able to keep the boards together.  Off to the hardware store for a nail gun.  I was back to work after a bit more than an hour.  But...
Second mishap: I bought nails which were too short.  I tried to make them work, but no luck.  Back to the hardware store.  I tried getting a larger nail gun, but they didn't have the nails I needed for it.  I got longer nails for the nail gun I had (for all of two hours...) and got back to work.  Another hour gone.
The first couple of courses were problematic, but I got them in.  Installation went a bit faster after that.  Not as fast as I thought it would, though.  Lots of time spent bringing materials in; I couldn't bring too much in at a time or I didn't have room to work.  Lots of time spent finding the right length board then cutting it exactly right.  Anyway, not a bad day:
From the doorway:
While peeking over the west wall:
Not the glamour shots, everything cleaned and polished, yet.  I have some more mess to make before I spend time doing thorough cleaning.
Edited by macdonjh, 13 March 2021 - 11:40 PM.
  • tjay, dmdouglass and Benschop like this
#71 JMW
JMW
  • Loc: Nevada
Posted 13 March 2021 - 11:40 PM
The observatory looks great. I am envious of your wide open skies. I am impacted by my neighbors very tall trees at his property line.
#72 macdonjh
macdonjh
Posted 13 March 2021 - 11:43 PM
I almost forgot: thanks to my friend for his allowing me to use his observatory as a warehouse.  I wouldn't have been able to make this work without the extra floor space.
#73 macdonjh
macdonjh
Posted 13 March 2021 - 11:47 PM
Thank you for your kind words.  My observatory is approximately ninety miles west of my house in the middle of a pretty big field.  We're surrounded by trees which act as a "light shield" from the homes and ranches around us.  Our "horizon" is something like 15o, so the trees are far enough away from where we set up our scopes to not block much sky.
Next month will be the sixth anniversary of my installing my scope and starting to use it.  The inside was a little ratty, so I now have a project to freshen it up some.  I think it may kill me.  Not a bad way to go, though.
  • Benschop likes this
#74 macdonjh
macdonjh
Posted 20 March 2021 - 09:52 PM
Worked on my pier today: finished applying Bondo and sanded, sanded, sanded.  It isn't perfect, but it's much better.  Boy was there a lot of dust!  Here's a view through the doorway:
And the view over my west wall:
#75 macdonjh
macdonjh
Posted 03 April 2021 - 09:21 PM
Work for today was installing an air conditioner to protect my floor from humidity variations.  Getting the A/C was an adventure.  Two separate orders from HomeDepot.com (air conditioners weren't in stock locally when I started this) were delivered damaged.  When I returned the second unit I found some air conditioners in stock.  I ended up buying three A/C in two weeks and returning two.  Sheesh.
I didn't think I had a patch for the missing sheet rock under the air conditioner, but I found one.  I'll install that next time I go out (hopefully next week).  Work from here on is less taxing so I hope to observe in the evening as well.
