A clean poorly lit place
83 replies to this topic
#76 macdonjh
macdonjh
Posted 24 April 2021 - 06:28 PM
A couple of catch-up photos from the past weeks.  First up: sheet rock repair and preparation for painting.  I hate sheet rock work, and I'm not good at it, but gotta do it, so:
And last week was paint:
This is kind of a "glamour shot" in that it doesn't show the pile of stuff displaced by the painting work.  It's safely out of sight in another corner.
#77 macdonjh
macdonjh
Posted 24 April 2021 - 06:35 PM
This week's goal was to get the trim installed and everything put back in place.  Like a dummy, I left my paint at my observatory last weekend so I couldn't paint it during the week.  I did get it painted today.  I also got all my lights, plates, and other bits reinstalled.  I cleaned everything as I went since some things hadn't been actually cleaned since I finished construction six years ago.  I also got the floor mostly cleaned up, though I'll have to borrow my missus' Swiffer next weekend to take up the dried dust and grime.
The base boards are simply laid in place, I didn't have access to an air compressor today, so I exercised some patience and didn't use finish nails and a hammer.  First is looking in the doorway:
And looking over the wall from the south-west corner:
Next weekend I hope to install the base boards and door molding, get the door jam painted, and do some work around the outside.  Oh, and get rid of those bags of stuff on the floor.  Then, since it'll be 3rd Quarter Moon, perhaps get some observing in.
Edited by macdonjh, 24 April 2021 - 06:40 PM.
  • Scott Mitchell likes this
#78 SkipW
SkipW
  • Loc: Oklahoma, USA
Posted 24 April 2021 - 07:57 PM
I hate sheet rock work, and I'm not good at it...
I resemble that remark.
Nice looking job, despite your trepidation.
#79 macdonjh
macdonjh
Posted 25 April 2021 - 06:45 AM
Thank you.
#80 macdonjh
macdonjh
Posted 15 May 2021 - 04:58 PM
Mostly finished with my floor project now. I installed the base boards this weekend.  I need to take some small screws out to secure things a bit better in a few places.  I also need to fill the nail holes, touch-up the paint and install that molding around my chart table.  First the photo looking through the door:
I brought two of my weights home to repaint them.  I'll paint the third the next time I go out.  The paint I originally used may be a good primer, but it trapped dirt and and allowed mildew to get a foothold.  I hope the gloss enamel I'm using as a new top coat will help me avoid those problems.
Then from the south-west corner:
Finally, the outside.  I did some spring cleaning this weekend as well.  Got rid of the worst of the weeds and spread a fresh layer of stabilized sand.
Next up: replacing the door and finishing the ceiling.  The latter I do not look forward to.
Edited by macdonjh, 16 May 2021 - 11:34 AM.
  • dmdouglass, R Botero and brave_ulysses like this
#81 stargzr66207
stargzr66207
  • Loc: Kansas, USA
Posted 15 May 2021 - 05:28 PM
Mac,
Well, you certainly have a deluxe, well finished observatory. Pretty snazzy! Your interior looks almost like a living room.
Hope you get to spend a LOT of time there!
Best wishes.
Ron Abbott
#82 macdonjh
macdonjh
Posted 16 May 2021 - 11:36 AM
Mac,
Best wishes.
Ron Abbott
Not nearly enough, but it is a fine place to go when I get the chance.  Especially this time of year when it's not too hot.  Sitting on the lawn in a reclining deck chair soaking up the quiet is a great way to wait for dark.
#83 macdonjh
macdonjh
Posted 29 May 2021 - 08:03 PM
Pretty small incremental changes today.  There is now a power strip with USB charger ports installed under my chart table, and the various cables are a bit more under control than previously.  I also filled nail holes in my base boards, getting them ready for touch-up painting, measured for a new door and installed a drain for the A/C to route the condensate away from my foundation.
  • dmdouglass and archer1960 like this
#84 macdonjh
macdonjh
Posted 12 September 2021 - 02:24 PM
After several years fighting poor pointing accuracy, my latest brainstorm was: prior to your observatory, your G11 could find objects even when your TFoV was 8' of arc.  What's changed?  One change I hadn't investigated is my power supply.  Prior to my observatory, I used a linear power supply, but my observatory had a switch-mode power supply.  As an experiment I unplugged the switch-mode power supply and set a linear power supply next to my pier and plugged it in.  Gemini behaved "better enough" to make me want to make that change permanent:
In this view you can see the (decloaked) linear power supply on the left.  It powers only my pier and the 12VDC outlets I have outside on my pad.  On the right is the remaining switching power supply, which powers the LED lights.  Everything else in my observatory is powered by 120VAC.
