Jupter in good seeing
4 replies to this topic
#1 Paul G. Abel
Paul G. Abel
Posted 14 April 2015 - 06:30 AM
Greetings all,
please finad attached a drawing of Jupiter I made last night.  Seeing conditions were rather good- indeed we've had a good spell recently of clear nights combined with good seeing.  The skies were a little hazy as is so often the case in times of good planetary observation. Points of interest include:
    The STB appears to be quite broad at these longitudes
    STropB visible, a slightly darker marking was present in the STropB close to the STB near the CM.
    SEB broad with some darker sections.
    NEB rather active containing numerous irregular lighter sections
    NTB hard to see, a small darker section present on the prec. side to about the CM.
    NTZ only seems to be clearly defined on the prec. side of the disk just before the CM.
    NNTB present byt irregular.
Best wishes,
-Paul
Jupiter_2015_04_13-2225UT_visual_PAbel_z
#2 star drop
star drop
    The Cardinal
Posted 14 April 2015 - 12:10 PM
A very nice sketch indeed.
#3 frank5817
Posted 16 April 2015 - 10:46 AM
Paul,
A fine looking capture.
You always do pull in some fine detail.
Frank :)
#4 niteskystargazer
Posted 16 April 2015 - 05:17 PM
Paul,
Nice sketch of Jupiter on Apr. 13th.  :) .
:thanx: ,
#5 Chuck Hastorf
Chuck Hastorf
Posted 16 April 2015 - 09:33 PM
Paul
Great sketch!
Chuck
