Meade Deep Space Telescopes DS-10 and DS-16
212 replies to this topic
#201 Paul Makinen
Paul Makinen
  • Loc: Carson, CA
Posted 18 November 2024 - 05:50 PM
I have another small question about the DS-10 mount:  How do you lock the RA setting circle in place for slewing after you've set the hour angle at the start of the evening?
AstroHopper is great, but does not seem to work well for large slews, so I still need the manual setting circles to navigate my very night-polluted sky.  The DS-10 manual does not seem to provide any detailed instructions.
Edited by Paul Makinen, 18 November 2024 - 05:55 PM.
#202 GalaxyPiper
GalaxyPiper
  • Loc: Sacramento, California
Posted 18 November 2024 - 10:56 PM
The RA setting circle should have a slight resistance, to be movable and set. It shouldn't move after that.
These scopes are now going on 40+ years old. If it too loose, then it needs to be taken apart and figure out what has deteriorated, gummed surface, thick grease, worn out felt...for examples...
Disassemble, Restore and reassemble...
I don't know what's underneath, or I would tell you.
#203 apfever
apfever
Posted 19 November 2024 - 09:10 AM
The RA setting circle is a loose collar that rest on the RA housing by it's own weight. It is a dry fitting and has no lock. You can add some stability by wrapping a two sided Velcro strip around the bottom of the circle that also grabs the RA housing lip the circle rest on. You can also use a rubber band but you might have to pull the DEC shaft to get a rubber band around the circle and housing.
  • Paul Makinen and GalaxyPiper like this
#204 GalaxyPiper
GalaxyPiper
Posted 21 December 2024 - 03:47 PM
TO those that have a 16" Starfinder or DS-16...now is your chance for a RA / DEC upgrade.
*NEW* in box...on eBay, Meade Magellan II complete kit.
https://www.ebay.com...:Bk9SR5zLkq_9ZA
Your welcome, and Merry Christmas.
Edited by GalaxyPiper, 21 December 2024 - 03:48 PM.
  • deSitter and Mr Magoo like this
#205 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 21 December 2024 - 04:53 PM
I wonder if this would work on a RG mount? I think the price is a bit nuts.
  • tim53 likes this
#206 GalaxyPiper
GalaxyPiper
Posted 21 December 2024 - 06:05 PM
Yeah, the price is a bit high. But if you have noticed, there is no bid...
Someone knows how rare this is....and has priced it accordingly.
Edited by GalaxyPiper, 21 December 2024 - 06:06 PM.
  • deSitter likes this
#207 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 23 December 2024 - 06:39 PM
The previous owner made this really nice rotating ring assembly but unfortunately threw out all the original parts to mount the tube to mount, so I can't return the scope to original.
That rotating ring system was not a DIY system it was a commercial system you could buy but I forget the name of it as I have one sitting in one of my garages or storage locations. I have owned 3 of the DS-16/16A mounts (16A had roller bearings on the RA axis if I remember correctly). One DS-16 I got with the 6" F15 Jaegers that was built for the late Dr. Green(e)  by Barry of D&G. The mount was equipped with a Byers 11.3" Star Master RA drive converted to a stepper drive  but the original tangent arm DEC was plumbed into the Byers control box. I originally bought a Byers 7.5" drive I was going to use to replace the tangent arm drive but never got around to doing it. Still have that mount, but sold the 6" F15. My use for the mount disappeared once I got a fully refurbished Schaefer AT-9 and later a really good Astro-Physics AP900QMD.
#208 clamchip
clamchip
  • Loc: Seattle
Posted 23 December 2024 - 08:12 PM
I did find the source of the rings 'Metro Machining' and this must be who you are thinking of.
Here's one of their ads:
  • tim53, Mr Magoo and GalaxyPiper like this
#209 GalaxyPiper
GalaxyPiper
Posted 24 December 2024 - 10:53 PM
Yes...that was an after market solution to a problem.
Remember, the mother of all inventions is to see a need and meet it.
You can make those straps with a very long hose clamp, or several ene-to-end and pop rivet some screen door rollers every 6 to 8 inches.
Because that was basicly what they were.
I have also witnessed the use of large drip line used in the same fashion.
Just noodle it around and experiment. Thats the way the ATM folks do it.
#210 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 25 December 2024 - 07:17 AM
He lived by me and made me rings for my 8" F/8 Edmund in 1988.
#211 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 25 December 2024 - 10:17 AM
A PiFinder would cost less and be more accurate I imagine. I’m really going to try and invest in one this coming year.
  • tim53 likes this
#212 CHASLX200
CHASLX200
Posted 25 December 2024 - 10:50 AM
They don't work on a EQ mount unless something changed as i was gonna get one before i got burned out.
  • Mr Magoo likes this
#213 GalaxyPiper
GalaxyPiper
Posted 25 December 2024 - 02:28 PM
Well, you have to remember this is mid 1980s technology...nearly 40 years ago...
That's about the same time frame as the Wright Flyer and the jet aircraft introduced in WWII...
The Apple IIe was a 1987 product at that time...
That "was" the most accurate thing customer's could buy at the time at the consumer level.
