[DIY] Astro CCD 16-bit Color 6Mpx Camera
astrophotography ccd DIY equipment imaging
1234 replies to this topic
#951 wasyoungonce
wasyoungonce
  • Loc: Land Downunder
Posted 14 June 2016 - 02:48 AM
Yep that would be great karlfoxman , Farnell is same as element14 downunder.   I did a search for that mrn but element14 came up empty (although they had had other inductance in that range).  I'll wait for your spreadsheet them bug them.
Many thanks gents.
Brendan
edit:
**** just did a farnell (Element14) UK search....item not found!  ****!  hahaha the site edited and hid my bad words..heres a civil version  "Darn"!
I also have a Mouser account...FWIW.  Free shipping if over $60 order....this sounds good...RS is free for any order but **** If I need to run around for a part might as well just get them all from one spot..Mouser or Digikey.
edit edit:
I think mouser is free shipping on orders over $60, the mouser number I used was.       CDRH4D28NP-6R8NC.......
Hmmmm on checking of data sheets....this is not the same as the digikey mrn number and indeed the specs on this unit is not the same.  I think the digikey item is the correct one?
Edited by wasyoungonce, 14 June 2016 - 06:43 AM.
#952 Superdude68
Superdude68
  • Loc: Runcorn, England
Posted 14 June 2016 - 11:23 AM
Has anybody have Gerber fields for the tec board and thermal controller for the cam 84 0.41 please. Hello everyone and to remove the sensor from the base I used Chemset AP 1105 epoxy stripper that only took over night and all the epoxy was completely gone..
Edited by Superdude68, 14 June 2016 - 01:50 PM.
#953 kalalaa
kalalaa
Posted 14 June 2016 - 11:52 AM
wasyoungonce:
I used this one:
http://www.ebay.com/...5oAAOSw-W5UtsRs
But theese i think good too:
http://www.ebay.com/...XoAAOSwgQ9V3ren
http://www.ebay.com/...ewAAOSwPcVVn2p2
#954 karlfoxman
karlfoxman
Posted 14 June 2016 - 01:19 PM
Wasyoungonce
I am using the ones I spoke about with no issues from mouser it was closest I could find and works great. I will post the two bom I used soon. Been very busy so I'm relaxing for now.
#955 karlfoxman
karlfoxman
Posted 14 June 2016 - 01:27 PM
Has anybody have Gerber fields for the tec board and thermal controller please. Hello everyone and to remove the sensor from the base I used Chemset AP 1105 epoxy stripper that only took over night and all the epoxy was completely gone..
I have a TEC controller/usb hub design I built but I'm still testing it. It seems to work fine now but I need to change a few things on the schematic and then the pcb. After that I will share my gerbers.
Edited by karlfoxman, 14 June 2016 - 01:27 PM.
#956 Superdude68
Superdude68
Posted 14 June 2016 - 01:52 PM
Thanks I shall wait for you.
#957 gehelem
gehelem
  • Loc: France
Posted 14 June 2016 - 03:39 PM
Quick test with new ad9826 : current is below 100mA, but i must confirm
I've recovered images i had before : only vertical pattern.
I will try to post screenshots
#958 wasyoungonce
wasyoungonce
Posted 14 June 2016 - 06:53 PM
Wasyoungonce
Many thanks gents.  I too was thinking of the TEC as well....very decent of you to share the gerbers! :grin:
#959 karlfoxman
karlfoxman
Posted 14 June 2016 - 11:50 PM
Mouser
http://www.mouser.co...ssID=dda62357fe
Farnell
https://drive.google...iew?usp=sharing
Hope it helps :)
  • wasyoungonce likes this
#960 flolic
flolic
  • Loc: Split, Croatia
Posted 15 June 2016 - 01:37 PM
Today I tested my DIY 2-stage peltier module. For the first stage, I cut TES1-12704 30x30mm module into 20mm width. On top of that I glued with thermal conductive epoxy another module, 20x15mm TEC1-2304. Both modules are connected in series.
Results (without CCD) are promising, with 8V power supply, module draw 2 amps and can easily reach 60 degrees C temperature difference. 15 watts of generated heat I can easily dissipate with my CNC milled housing.
CCD will be thermally insulated and in a Argon filled chamber. Now I am worried about thermal sinking through the CCD pins...
More tests will follow.
  • gehelem likes this
#961 flolic
flolic
Posted 16 June 2016 - 02:37 AM
#962 Charl
Charl
  • Loc: terra firma
Posted 16 June 2016 - 12:34 PM
I would be more worried about thermal shock!
#963 Superdude68
Superdude68
Posted 16 June 2016 - 12:42 PM
  • wasyoungonce, hippieua and gehelem like this
#964 hippieua
hippieua
  • Loc: Kiev
Posted 16 June 2016 - 04:37 PM
You can raise power gradually
#965 Charl
Charl
  • Loc: terra firma
Posted 17 June 2016 - 12:14 AM
True, but what if the TEC supply is interrupted for some reason? Put your finger on the cold side of a Peltier, cut the supply and feel how rapidly it warms up. With its fragile construction I wouldn't risk subjecting a CCD to this. Having thermal mass between the two would be a lot safer.
#966 flolic
flolic
Posted 17 June 2016 - 02:33 AM
I have almost the same configuration where peltier is in direct contact with sensor on my other DIY camera, with Kodak KAI4022 CCD. That camera survived many thermal cycles without any problem.
I recently disassembled cooled CCD camera from Gel Logic 4000 Pro life science imaging system, in that camera sensor is also directly coupled to 2-stage peltier module.
So, while I understand possible consequences of thermal stress, I don't see it as a big problem. In the worst case scenario, I will just put another sensor. I have few spares and they are cheap to buy.
  • brucesdad13 likes this
#967 gehelem
gehelem
  • Loc: France
Posted 17 June 2016 - 12:17 PM
Ok, here are my results with different masks :
Mask on the  left, my image show this dark line on the left, good ! :
Left ccd
Left img
On the right my image show this (less) dark line on the right, (not so) good ! :
Right ccd
Right img
Horizontaly, well, baaaaaad, nothing :
Hor ccd
Hor img
Once again... any advice would be welcomed !
Gilles
Edited by gehelem, 17 June 2016 - 12:32 PM.
#968 Toups
Toups
  • Loc: Greater Boston Area, Massachusetts, USA
Posted 17 June 2016 - 05:04 PM
Did you try different exposures, offset and gain values?  What settings did you try?
Do you have a histogram of values?  (You may find either the trial version of Nebulousity or the freeware ImageJ useful for this.)
#969 gehelem
gehelem
  • Loc: France
Posted 17 June 2016 - 05:30 PM
well, i'm using Nebulosity
and i've tried different parameters.
For example :
Screen Shot 06 18 16 At 12.25 AM
This one was taken with a mask on the right of the CCD
Baudrate doesn't seem to change anything
When the gain is too high, image is saturated.
btw : i've 3 different CCD, almost same results on 3.
Gilles.
Edited by gehelem, 17 June 2016 - 05:32 PM.
#970 Toups
Toups
Posted 17 June 2016 - 05:49 PM
That looks promising.  Try making a quick pinhole camera.  Enclose the sensor in box with pinhole in front of the sensor.  Aim it at a light and try some exposures.  Use a piece of aluminum foil to make the pinhole.  The pinhole will act as a lens.
Maybe too much light with your current test?
#971 karlfoxman
karlfoxman
Posted 18 June 2016 - 02:14 AM
Also with no filter it's very sensitive to IR. Masking tape might not stop much if this. Looks OK to me though. You could also try a test I did. With something to protect the glass on sensor like tape add some blobs of blutac and do an image in very low light. I always kept my gain at 0.
#972 gehelem
gehelem
  • Loc: France
Posted 18 June 2016 - 07:22 AM
thank you
A quick test gives no result (same kind of image, whatever time or gain is)
i will try with IR filter
#973 gehelem
gehelem
  • Loc: France
Posted 18 June 2016 - 07:32 AM
With IR filter  : same results  :(
Whatever i do, i always get this kind of images, with vertical paterns
Edited by gehelem, 18 June 2016 - 07:33 AM.
#974 gehelem
gehelem
  • Loc: France
Posted 18 June 2016 - 11:17 AM
I've changed sony IC, and guess what ???
Smile
Screen Shot 06 18 16 At 06.27 PM
YYYEEEESSSS !!!!!
(using pinhole)
Thank  you so much, guys, i didn't know what i was about to start 9 month ago, and alone i would have certainly gave up
Edited by gehelem, 18 June 2016 - 11:28 AM.
  • gregj888, brave_ulysses and Dave O like this
#975 karlfoxman
karlfoxman
Posted 18 June 2016 - 02:52 PM
Well done that's fantastic news.
Also tagged with one or more of these keywords: astrophotography, ccd, DIY, equipment, imaging
