[DIY] Astro CCD 16-bit Color 6Mpx Camera
astrophotography ccd DIY equipment imaging
1242 replies to this topic
#1151 kalalaa
kalalaa
Posted 06 October 2017 - 06:01 AM
Thank you WSG!
I tried it but didn't work for me. Nebulosity stopped working after exposure. I think because i tried with trial Nebulosity4.
#1152 WSG
WSG
  • Loc: Germany
Posted 06 October 2017 - 02:38 PM
That is a pitty that it apparently won't work for you. Just to me sure that you did it the same way I did here a more detailed description:
1. Installation of Nebolusity and the additional driver for it to act as a ASCOM camera for other Tools
2. open Nebolusity and connect to cam84 ASCOM Driver
3. take 2 or 3 one second preview exposures with with Nebolusity to be sure you have a stable connection to cam84
4. Nebolusity is now inactive and waiting
5. open Sequence Generator and select "ASCOM Camera Driver for Nebulosity" as Camera.
6. make your exposures as required with Sequence Generator
I use a 64bit Windows 10 Laptop for this.
I do not think the trial version of Nebolusity causes the problem. As far as I know the trial version only disturbs the taken frames when stored with some stripes.
#1153 Cyntrifical
Cyntrifical
  • Loc: Lynchburg, VA
Posted 21 October 2017 - 08:46 PM
Does anyone still have a lead on schematics for a CAM10-R board? Many of the parts on the source list are outdated but going to try to build the CAM10-R, since I have a few MT9M001 color sensors. I can still find the original CAM10 schems on astroccd.org, but the cam10-r board was buried somewhere in a russian/ukranian astro forum that today I have lost track of. Has anyone been working with this lately? Trying to start off with a smaller build.
#1154 AstroMadd
AstroMadd
Posted 22 November 2017 - 09:59 PM
I was able to grab this bunch of files, for the Cam10 10R ... dunno if they're of use ...
Cam10 10R:
https://mega.nz/#!g6...8BJM-nu6_QAr3So
The site I grabbed them from was here (astroclub.kiev.ua translated):
https://translate.go...760&prev=search
Martin
Edited by AstroMadd, 22 November 2017 - 10:07 PM.
#1155 ginnz
ginnz
Posted 06 January 2018 - 05:14 PM
Holy jesus....I cant belive what you guys are up to here. I just read the whole thread in one sitting. The images you guys have taken so far are out standing! especially for a color cam! unreal.
#1156 kalalaa
kalalaa
Posted 27 January 2018 - 06:12 AM
Somebody please help me! My new cam86 has a problem. The histogram is fragmented, camera has only a few shades. The minimum adu is 1028 wiht or without sensor, no matter if i change the offset. Please look at the link:
https://www.kephost.com/image/EzXS
I have 3 panels and each has 8224 ADU minimum without sensor.
DD13 is warm, but the 5V is stable 4.980V.  Overall current on 12V is about 120mA.
Edited by kalalaa, 27 January 2018 - 07:48 AM.
#1157 pagpatrice
pagpatrice
Posted 27 January 2018 - 07:59 AM
Which software you use ?
With CAMView it's the same?
#1158 kalalaa
kalalaa
Posted 27 January 2018 - 08:42 AM
Tried with maximdl, nebulosity, sequence generator pro and cam86 view-01. All the same. Tried may firmwares and ascom drivers. I checked 3 times all the components all the 3 board but nothing.
You see my arms, face and tshirt.
https://www.kephost.com/image/Ez1h
#1159 kalalaa
kalalaa
Posted 27 January 2018 - 09:48 AM
The 3rd AD9826 works fine. First i soldered it before the other components and it is electrostatic discharge sensitive device, so maybe i killed it. The second ic is a desoldered from other device. The third is a new.
Finally here is my camera. Fully sealed, tube filled with silica gel.
https://www.kephost.com/image/EzQA
Edited by kalalaa, 27 January 2018 - 12:31 PM.
#1160 zfedoran
zfedoran
Posted 01 March 2018 - 01:07 AM
I've got two cam86 boards waiting for sensors.
Hopefully all goes well, lol I'll report back when I get a sensor in place.
  • gregj888 and LarsMalmgren like this
#1161 zfedoran
zfedoran
Posted 20 March 2018 - 10:43 PM
Added a sensor to one of them, and it looks like things are working. I am able to take photos with it while holding a lens above it laugh.gif
Interestingly, I did not need to do anything special to get the sensor out of the metal housing, it popped out on its own. The epoxy residue is still attached to the back of the sensor though.
Anyone have ideas on removing the epoxy residue? is DMSO the only option?
  • euklides69 likes this
#1162 gehelem
gehelem
  • Loc: France
Posted 21 March 2018 - 01:25 AM
DMSO is working very well, and is the only known option...
(Congratulations...)
Gilles
#1163 Toups
Toups
  • Loc: Greater Boston Area, Massachusetts, USA
Posted 21 March 2018 - 05:54 AM
You might try a paint stripper containing methylene chloride for removing the chip from the carrier and removing the residue.  I had success with such a product and it was available at a local hardware store (at least in the US but is banned in the EU.)
See an earlier post: https://www.cloudyni...mera/?p=7270629 for more details.
#1164 zfedoran
zfedoran
Posted 29 March 2018 - 12:33 AM
Thanks guys, I'll see what can be done with paint stripper before moving to DMSO.
Does anyone have any recommendations on how to mount a T-thread to the enclosure? I've seen a number of approaches from 3d printing to custom milling an aluminum connector. Unfortunately, I don't have access to a lathe or anything that would allow me to create this component. Would anyone be up for helping me out?
#1165 gehelem
gehelem
  • Loc: France
Posted 29 March 2018 - 01:22 AM
Hi
Here is a "no-tools" idea :
https://www.diycam.f...le-pvc-pression
I've abandonned this one, but you can give it a try...
  • zfedoran likes this
#1166 Toups
Toups
Posted 29 March 2018 - 05:55 AM
Here is a thread I stumbled across where someone was able to cut large diameter threads without a lathe.  Rather ingenious solution, another technique one can put in one's tool chest.
https://www.cloudyni...athe/?p=7485916
#1167 gregj888
gregj888
  • Loc: Oregon
Posted 29 March 2018 - 11:29 AM
Grab a M42 to T-mount adapter off ebay.  Threads on both sides are the same diameter, but different pitch.
https://www.ebay.com...5.c100005.m1851
Enlarge the hole in the case so the adapter more or less screws in, then epoxy into place this something like JB weld  (metal filled epoxy, might cut IR leaks).
On mine I took the T-mount ring out and just mounted it, but that's in a machined housing.
As an additional FYI, extension tubes are also good sources of lens and camera mounts.
  • Toups and zfedoran like this
#1168 zfedoran
zfedoran
Posted 29 March 2018 - 08:25 PM
You guys are awesome, thanks for all the great suggestions!
@gregj888: do you have any photo's of what you ended up doing? Did you custom make the entire housing?
#1169 Toups
Toups
Posted 29 March 2018 - 09:13 PM
My cam84 is still a work in progress, however, my plan as been to use macro extension tubes as the basis for the connections (or possibly the mounting plate from the sacrificial camera.)
I am also using macro extension tubes to build a Dave Groski inspired H-alpha setup.  That's a story for another thread once I manage to make some more progress.
Edited by Toups, 29 March 2018 - 09:27 PM.
#1170 gregj888
gregj888
  • Loc: Oregon
Posted 29 March 2018 - 11:02 PM
Zfed,
Housing photos on page 37 of this thread;
Electronics are here, cam 84-   https://www.cloudyni...uild/page-2?hl= cam84
The camera wears white powder coat now.  I think I've posted that but didn't see it   It's a little hard to see in the photos, but there's a water channel (largish round holes on each side of where the wires come out.  Then there are small holes behind the sensor (well peltier) to provide water channels behind the peltier for back side cooling.
Edit- added photos
Edited by gregj888, 30 March 2018 - 02:25 PM.
  • PrestonE likes this
#1171 zfedoran
zfedoran
Posted 30 March 2018 - 03:59 PM
Nice work greg! That is one professional looking camera.
Did you end up water cooling it?
#1172 gregj888
gregj888
  • Loc: Oregon
Posted 30 March 2018 - 09:07 PM
Yes, I'm a fan of water cooling for cameras.  No vibration and much easier to reach lower temps with the peltiers.
#1173 hyper1on
hyper1on
Posted 02 April 2018 - 08:25 PM
i try launch cam84 driver on raspberri pi. Install raspian, install dependencies, instal indi server 1.6.0.
download and compile cam84 driver from sources. Launch indiserver as discribed in build file from github
indi client found cam84 driver but camera inaccesible
here log
pi@raspberrypi:~/libindi_1.6.0_rpi/indi_cam84_ccd/build $ indiserver -v -m 100 ./indi_cam84_ccd
2018-04-02T16:35:35: startup: indiserver -v -m 100 ./indi_cam84_ccd
2018-04-02T16:35:35: Driver ./indi_cam84_ccd: pid=1175 rfd=3 wfd=6 efd=7
2018-04-02T16:35:35: listening to port 7624 on fd 4
2018-04-02T16:35:35: Driver ./indi_cam84_ccd: snooping on Telescope Simulator.EQUATORIAL_EOD_COORD
2018-04-02T16:35:35: Driver ./indi_cam84_ccd: snooping on Telescope Simulator.TELESCOPE_INFO
2018-04-02T16:35:35: Driver ./indi_cam84_ccd: snooping on Telescope Simulator.GEOGRAPHIC_COORD
2018-04-02T16:35:35: Driver ./indi_cam84_ccd: snooping on Focuser Simulator.ABS_ROTATOR_ANGLE
2018-04-02T16:35:35: Driver ./indi_cam84_ccd: snooping on CCD Simulator.FILTER_SLOT
2018-04-02T16:35:35: Driver ./indi_cam84_ccd: snooping on CCD Simulator.FILTER_NAME
2018-04-02T16:35:35: Driver ./indi_cam84_ccd: snooping on SQM.SKY_QUALITY
2018-04-02T16:35:38: Client 0: new arrival from 192.168.1.101:51051 - welcome!
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error open interface A
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error open interface B
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error set bitbang mode interface B
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error set baud interface A (-3:USB device unavailable)
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error set baud interface B (-3:USB device unavailable)
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi BRA=-1 BRB=-1 TA=5000 TB=5000
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error set latency interface A
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error set latency interface B
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi BRA=-1 BRB=-1 TA=2400 TB=2400
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi interface A read chunksize 4096
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi interface B read chunksize 4096
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi interface A write chunksize 4096
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi interface B write chunksize 4096
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error purge RX interface A
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error purge TX interface A
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error purge RX interface B
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: libftdi error purge TX interface B
2018-04-02T16:35:47: Driver ./indi_cam84_ccd: write failed on channel 2)
and
pi@raspberrypi:~/libindi_1.6.0_rpi/indi_cam84_ccd/build $ lsusb
Bus 001 Device 005: ID 0403:6010 Future Technology Devices International, Ltd FT2232C Dual USB-UART/FIFO IC
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I have idea use raspberry pi to use camera as standalone application without notebook in travel.
It is real? Or usb speed will not be enough to normal reading?
#1174 Toups
Toups
Posted 02 April 2018 - 08:56 PM
That problem looks familiar, see http://indilib.org/f...iver/12650.html
I had to do a sudo to run the server as root in order to not have the ftdi errors.  Evidently properly setting the udev rules may fix it also.
Don't know if a raspberry pi is fast enough but certainly worth a try.  I'd be curious to know if you get it to work.
#1175 gehelem
gehelem
  • Loc: France
Posted 03 April 2018 - 02:18 PM
+1 for permissions problem
I don't remember the exact group you have to belong, it might be DIALOUT
Also tagged with one or more of these keywords: astrophotography, ccd, DIY, equipment, imaging
