how many use a lymax cat cooler with your SE SCT
7 replies to this topic
#1 coutleef
coutleef
Posted 03 May 2015 - 08:37 AM
i started using regularly my sct cooler from lymax
i was hesitant at first to introduce this long shaft inside my 8se and blow air inside. i simply let the scope cooldown for one to two hours before use. i can encounter quite dramatic temp differences between the house and outside.
using the sct cooler for 20 minutes resulted in dramatic differences for planetary views and my fears were not justified
really solved the cooldown problem of sct which sometimes interfered with planet observation
whathas been your experience??
Edited by coutleef, 03 May 2015 - 09:56 AM.
#2 Kon Dealer
Kon Dealer
Posted 03 May 2015 - 03:00 PM
Me :grin: on my 8SE.
But only in Winter.
#3 coutleef
coutleef
Posted 03 May 2015 - 04:43 PM
The company also states that it can help evacuate humidity in the ota. Never tried that
#4 coutleef
coutleef
Posted 04 May 2015 - 10:53 AM
ok well it seems that not very many use the lymax cooler!
#5 mich_al
mich_al
Posted 04 May 2015 - 12:59 PM
Anything with big glass needs auxiliary cooling, especially if it's closed.  I have a C9.25 that a Lymax makes a world of difference on.  I also have a DK that is open on each end.  Even it benefits greatly from active cooling.
#6 junomike
junomike
Posted 05 May 2015 - 03:14 PM
I took my Cat Cooler (made by someone else) and adapted it to work work with my SCT's.
Here is how It originally looked when used with my 8" SCT. (eventually replaced with 8" EdgeHD with active cooling)
when the 8" SCT was sold I cut the plastic tube and added some plumbing supplies in order to allow two different length rods to be used (one for C11 and one for C14).
Now I just swap out the rods when needed
Edited by junomike, 05 May 2015 - 03:18 PM.
#7 Ptkacik
Ptkacik
Posted 05 May 2015 - 06:42 PM
I used my Lymax cooler last winter but it is so much warmer now the temp difference doesn't seem worth it. My seeing isn't that good so maybe I'll try it and see if it makes a difference.  I have a 10" LX-200 and a C11 so they are pretty comparable otherwise.
#8 Starman81
Starman81
Posted 13 May 2015 - 03:10 PM
I cannot because mine is an EdgeHD. But I do have the TEMPest fans. But I wouldn't mind trying the Starizona Cool Edge for it, that's the only option, I think.
I would try one with my C6 though but they don't make one. I will follow the directions in this thread to make my own, though.
