Building a Celestron C8 binoscope with Matsumoto EMS
48 replies to this topic
#1 ArsMachina
ArsMachina
  • Loc: Germany
Posted 24 May 2015 - 06:29 AM
Hi there,
after I have been building a really fantastic Borg 125mm ED binoscope earlier this year I had the feeling that I need some more binocular aperture and resolving power.
Bigger refractors are long and heavy, double-dobsons are also quite heavy and uncomfortable to use (at least in my opinion)
So I decided to go for a C8 binoscope, as it will be still quite small and lightweight and having a comfortable view from the back.
While using Matsumotos EMS I will get an upright and right sided view like in standard binoculars, so I also can use the double C8 for daylight viewing ;-)
Last week I got a second C8 tube and started my new project:
The left scope has already black velours inside, the right one has still the factory black coloring.
The difference is quite obvious...
Here now both scopes taken apart on the floor:
Here you can see how I machined the back to shorten the light path and to attach the Matsumoto EMS
And here you can see how the EMS-UXL will fit the scope - I would say perfectly :-)
The main problem in such a binoscope will be the long light path and the resulting needed backfocus.
A big backfocus will cause two things, vignetting at the baffles inside the tehelscope and spherical aberration because the Schmidt corrector plate is not calculated for a focal ratio of f/12 or even bigger.
The vignetting can be lowered by shortening the baffles.
Here you can see how I shortened the main baffle, I did not yet decide if I also will shorten the baffle around the secondary:
I hope you enjoy looking at my building process, and sorry for my poor englisch, I am German :-)
Jochen
  • AndresEsteban, bsavoie, thomasr and 1 other like this
#2 junomike
junomike
  • Loc: Ontario
Posted 24 May 2015 - 06:52 AM
Jochen, you're projects are amazing.  I could only wish for the guts ans skills required for such a project. I'm excited to see the finished project.
What exactly was involved in regards to machining to get the EMS to fit?  Also, how are you going to deal with the increased SA?
#3 ArsMachina
ArsMachina
  • Loc: Germany
Posted 24 May 2015 - 07:23 AM
Thanks for your kind words, Mike!
So far I only used my lathe to shorten the main baffle, turning away the SCT threading and creating a flat surface at the telescope casing to attach an adapter for the EMS housing.
Actually I am waiting for more aluminium material to go on.
As far as I know there is unfortunately no way to do anything against the SA.
I will have to see how big it will be and need to accept it.
After my calculation the needed backfocus will be 240mm
This project is also a test for an perhaps next project with two C11 tubes.
But there the needed backfocus would be 295mm and I am not sure if the views then still would be very pleasuring...
Jochen
  • AndresEsteban and bsavoie like this
#4 bsavoie
bsavoie
  • Loc: North Alabama 35747
Posted 24 May 2015 - 10:05 AM
I am very interested in how this works out. My approach is to use two Z10 dobsonians. To reach focus, without changing much I add cabinet drawer sliders with 100 pound support rating. The idea is to allow focus using the normal two stage crawford focuser, then pull the two scopes together a nose length apart.
I just know there is a way that we astronomers can get two eyes on the sky. We can do that without spending all our money, and we can use inexpensive parts that were never intended for both eyes.
Certainly with the intelligence of the world it just just a matter of time, maybe you will lead us there. Your idea will be small and yet powerful. I would think a one eye, proof of technique. might be a way to reduce cost in the prototype. I am enjoying your enthusiasm. Thanks for the post.
#5 GlennLeDrew
GlennLeDrew
Posted 24 May 2015 - 11:30 AM
Jochen,
Impressive! You should post something in the binocular forum; it's not just about commercial hand-hold able stuff over there.
Unless your exit pupil is getting down to about 1mm, you likely will not be resolving any SA induced by the extra distance the focus is forced rearward. And in any case I feel atmospheric seeing might rarely permit to discriminate the not so large degradation--I hope. ;)
#6 ArsMachina
ArsMachina
  • Loc: Germany
Posted 24 May 2015 - 12:49 PM
Glenn, your are right, this thread would fit way better in the binocular forum.
Perhaps a moderator can move it there ?
I have no intention to use exit pupils smaller than 1mm, so the SA problem might be smaller that I feared.
Thanks for this information!
@bsavoie: Using both eyes for astronomy is great, observing is way more relaxed and you can see many more details.
This already happens using binoviewers but the real thrill is giving one objective to each eye especially when you want to go for wide angle views.
But to get this done there are many obstacles, getting both telescopes 100% parallel and rigid mounted together is the smallest of them.
When you are using objectives bigger than around 55mm you will need a way to match the light pathes your IPD (interpupillary distance)
Some are just using three star diagonals here, with the disadvantages of having the light loss of three reflections and reversed images, where you are unfortunately limited to the mirror sizes of 2" diagonals.
But to allow the full illumination of the eyepieces you want to use regarding the focal ratio of the objectives you have chosen you probably need bigger mirrors, especially when you have the intension to use wide field eyepieces.
This is something most binoscope builders are not taking care for.
Way better is the solution of Tatsuro Matsumoto who is using just two mirror reflections in the right angle and gets upright and right sided views with his system. The light path in his system is also shorter as in a three mirror setup.
He offers multiple sizes of his EMS so you can chose the right ones for the scopes and eyepieces you will be using.
Double newtonian binoscopes are much more tricky to build in any manner and its usage is not as relaxed and comfortable as a double refractor or double SCT.
What I wanted to say is, that your dream of cheap and good big binoscopes will be hard to match - unfortunately...
Jochen
  • AndresEsteban, bsavoie and Hilbily like this
#7 ArsMachina
ArsMachina
  • Loc: Germany
Posted 30 June 2015 - 10:55 AM
Today the parts to combine the two tubes arrived. They have been milled out of aluminium to make sure that the two tubes will be 100% parallel.
To mount the two C8 tubes together I will use three of these connectors:
Here they are at one of the tubes:
And now both tubes together:
Here you can see that the radii are perfectly matching:
Now I will have to drill holes into the tubes and mount them permanently together.
Best wishes Jochen
#8 Rickster
Rickster
  • Loc: NC Kansas Bortle 3 SQM 21.8+
Posted 30 June 2015 - 09:50 PM
Jochen, Please keep posting your progress as you go.  I have been thinking about such a project lately, so I find this very interesting.  And thank you for the information about EMS-UXL.
Rick
#9 ArsMachina
ArsMachina
  • Loc: Germany
Posted 01 July 2015 - 06:18 AM
Thanks for your feedback, Rick!
Here are sone new pics, also showing the awaiting C11 tubes :-)
But these are covered by another thread:
http://www.cloudynig...-matsumoto-ems/
Jochen
Edited by ArsMachina, 01 July 2015 - 06:19 AM.
  • AndresEsteban likes this
#10 John P
John P
  • Loc: Irondequoit, NY USA
Posted 01 July 2015 - 06:43 AM
What an interesting project.  Regarding back focus, did you consider some form of transfer lenses to increase back focus without adding magnification or otherwise impacting the image?  Please keep posting with photos...I love your inventive spirt.
#11 ArsMachina
ArsMachina
  • Loc: Germany
Posted 01 July 2015 - 08:29 AM
John, yes I thought about some lenses but prefer not to add any more things in the light path.
The EMS are the shortest way to bring the distance to my IPD and the needed backfocus will be 242mm, what is still in the good range.
Jochen
  • bsavoie likes this
#12 A6Q6
A6Q6
  • Loc: Stroudsburg,Pa,U.S.
Posted 01 July 2015 - 10:32 AM
Very cool, I haven't seen anything like that since the days of Roger Tuthill, I think he used two C5's :waytogo:
#13 ArsMachina
ArsMachina
  • Loc: Germany
Posted 02 July 2015 - 06:06 AM
Here we go :-)
Today I ordered the needed material to attach the EMS and to finish the fork.
As soon as it arrives I will continue my work.
Jochen
#14 woodscavenger
woodscavenger
  • Loc: Boise, ID
Posted 02 July 2015 - 09:00 AM
For me the weak  link of the C8 is the fork.  Why not use a few more of those mounting block and put it on a dovetail mount?
Great work however!!!
Where did you find the EMS and how much do they cost?
#15 ArsMachina
ArsMachina
  • Loc: Germany
Posted 02 July 2015 - 09:52 AM
Why should this fork be weak?
I can not imagine a more comfortable alt/az mount for visual use
I bought the EMS directly and new from Tatsuro Matsumoto
Jochen
#16 trevize
trevize
  • Loc: Hollis, NH
Posted 02 July 2015 - 02:59 PM
Why the focus knobs on the inside instead of on the outside.   I would think it difficult to reach while viewing and trying to focus with the knobs on the inside?
BTW looks awesome!   I'm following this project with keen interest.
  • ArsMachina likes this
#17 woodscavenger
woodscavenger
  • Loc: Boise, ID
Posted 02 July 2015 - 03:27 PM
Agreed on the alt/az.
My C8 with vintage fork has a tendency for vibration and wobble.
#18 ArsMachina
ArsMachina
  • Loc: Germany
Posted 02 July 2015 - 03:39 PM
trevize, I will not use the original focus knobs any longer as I will fix the mirrors at the central baffle.
This will avoid focus shift and I will focus the eyepieces with a focuser attached to the end the EMS anyway.
woodscavenger, I will not use the original center piece of the fork but will build my own one.
I have to see it it is rigid enough, otherwise I will probably look for a C11 fork.
But first I wanted to keep the setup as small and lightweight as possible, a further improvement is always possible.
Jochen
#19 ArsMachina
ArsMachina
  • Loc: Germany
Posted 04 July 2015 - 10:25 AM
Today just a little update as I am still waiting for new aluminium material to continue.
As suggested by some people in the C11 bino thread I added a connection rod at the lower side of the two tubes to take the momentum and make the setup more rigid.
The result is very good, I can not feel any more movement between the tubes now when I try to "bend" them.
Best wishes Jochen
Edited by ArsMachina, 04 July 2015 - 10:26 AM.
#20 jgraham
jgraham
Posted 05 July 2015 - 10:18 PM
The light baffle on the secondary should have no effect on vignetting. The limiting factor is the diameter of the secondary, not the baffle on the secondary.
Neat stuff.
#21 ArsMachina
ArsMachina
  • Loc: Germany
Posted 08 July 2015 - 02:34 PM
Today some more aluminium arrived at my house so I worked at the connection piece for the fork arms.
Here I am milling the center hole which will take the bearing with a rounded table:
Weight does matter, so I am milling away as much material as possible:
This is the finished piece together with the tubes and fork arms.
Tomorrow I will mount the bearing and mount the fork together.
Best wishes Jochen
#22 ArsMachina
ArsMachina
  • Loc: Germany
Posted 09 July 2015 - 03:27 PM
I am close, very close :-)
Jochen
Edited by ArsMachina, 09 July 2015 - 03:27 PM.
  • Bill Lee and AndresEsteban like this
#23 ArsMachina
ArsMachina
  • Loc: Germany
Posted 10 July 2015 - 12:07 PM
The binoscope is finished, the total weight is 14 Kilogramm
It is a nice and compact setup which is easy to carry using the bridge or one of the fork arms as a handle
Later today will be first light
If all is fine I will continue with the C11 Bino in the other thread.
Best wishes Jochen
  • rik ter horst, A6Q6, AndresEsteban and 3 others like this
#24 junomike
junomike
  • Loc: Ontario
Posted 10 July 2015 - 12:24 PM
Very nice work Jochen.  Looks like a Linhof's going to be holding the Binoscope?
#25 ArsMachina
ArsMachina
  • Loc: Germany
Posted 10 July 2015 - 12:49 PM
Hello Mike,
yes, the Linhof can take loads above 20 Kilogramm, this is working fine.
And for a binoscope a tripod with a rigid rack and pinion center column is a must - at least for me...
Jochen
