Vite 23m Aspheric
620 replies to this topic
#1 kt4hx
kt4hx
  • Loc: Fredericksburg, Va
Posted 16 June 2015 - 12:03 AM
First off I will say that I don't have one of these, nor am I specifically planning on getting one.  But was curious if anyone might have bought one and tried it out.  I am aware of one person who did and said that in his ES ED127 it performed quite well for a $19 eyepiece, and he got pinpoint stars to the EOF.  Also mentioned he didn't notice any internal reflections or blackouts and that eye relief was decent.   First time I've heard of the label, and I see they also market a 4mm as well.  Sort of an odd mix, 23mm and 4mm.  Anyway, just curious if anyone has tried one for the sake of trying one.
http://www.amazon.co...1&keywords=vite
#2 BillP
BillP
Posted 16 June 2015 - 10:12 AM
I have ordered them to have a look and experiment.  What the heck...$27 for 3 eyepieces!!  If they turn out to be dogs will have fun taking them apart :grin:   I mostly use f/8 refractors so most eyepieces work well.  Should be here next week.
  • Mitrovarr, Procyon and Peter Besenbruch like this
#3 kt4hx
kt4hx
Posted 16 June 2015 - 05:14 PM
Thanks Bill, looking forward to your comments.
#4 precaud
precaud
  • Loc: north central New Mexico
Posted 16 June 2015 - 06:17 PM
Looks identical to those cheap Celestron aspherics.
  • DocFinance likes this
#5 kt4hx
kt4hx
Posted 16 June 2015 - 08:07 PM
Yeah I think you're right John.  Thanks for pointing that out.  But I have to wonder if they are truly "Celstron" or if the seller was just stating a name he thought would help them sell.  I don't see a brand name in any of the images they provided.
Edited by kt4hx, 16 June 2015 - 08:15 PM.
#6 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 17 June 2015 - 10:51 AM
Hey, if you built them would you put your name on them? :lol:
There's a lot of talk going on about these, some claiming they use at least one plastic lens.  It would be nice if someone tore one apart and told us for sure.....and really did some observing with one in various scopes.
  • Procyon, gnowellsct and penguinx64 like this
#7 kt4hx
kt4hx
Posted 17 June 2015 - 05:32 PM
I suspect Bill will dissect one and let us know.
#8 BillP
BillP
Posted 17 June 2015 - 09:42 PM
I'm thinking it was a new line that Celestron was considering, then had a test run, then decided against, and now the company contracted to make them is selling off the initial test run of units.  If it has a plastic lens, or more likely a polymer one or a polymer overlay that accomplished the aspheric, I really don't care.  If it performs is all that matters.  But will definitely take one apart to see what's up :grin:
  • Augustus likes this
#9 Alvin See
Alvin See
  • Loc: Singapore
Posted 18 June 2015 - 12:04 AM
As I have mentioned in an earlier thread, they actually bothered to coat the lens. Can one coat plastic lens?
#10 precaud
precaud
Posted 18 June 2015 - 07:46 AM
Sure, think sunglasses...
#11 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 18 June 2015 - 11:35 AM
Maybe I'll just give it all up and open a nail shop....pick a color!
#12 BillP
BillP
Posted 19 June 2015 - 07:06 PM
OK...received my no name, sometimes Celestron, 23mm Aspheric eyepiece today!
From the outside looked inexpensive, but still interesting.  Top of the eyepiece is rubberized so no issue for eyeglass wearers.  Housing is plastic.  Barrel is light gauge aluminum.  Eye lens is fairly large and eye relief not tight. And look, that dang undercut defect!  When will eyepiece makers learn :ohmy:
Unscrewing the barrel the retaining ring was plastic.  So housing and retaining rings definitely plastic, making unscrewing the retaining ring not so easy since plastic threading deforms quickly.  But got the ring out and popped the lenses out.
This is a 1-2 eyepiece.  The field doublet is strongly curved and large, heavy, and robust.  Nice hunk of glass.  The eye lens is inset in a spacer ring, and it is not glass...so plastic or polymer.  It appears to be coated as well, and definitely aspheric when looking at it.
Popped it quickly into an 80mm f.6.25 Apo and the view was nice.  Field curvature in the last 1/4 of the FOV but to be expected from this scope as most eyepieces do show it in this scope.  But overall a nice and sharp view.  But proof of performance will be in the evening with stars, not leaves in the daytime :lol:  AFOV I have to measure, but is large and generous so probably near the 60 degree mark.  It weighs little.  But 23mm and 60+ degree AFOV!  If it is acceptably sharp then will make a great light weight bino pair of EPs for only $9 each!!  Yes, I got a pair to binoview with :grin:
Cloudy tonight so perhaps tomorrow night for a test run.
Edited by BillP, 19 June 2015 - 07:08 PM.
  • Tom T, wprince, KeithC and 3 others like this
#13 precaud
precaud
Posted 19 June 2015 - 10:15 PM
OK...received my no name, sometimes Celestron, 23mm Aspheric eyepiece today! [snip]
We can count on Bill to go where no man has gone before...  :)
Edited by precaud, 22 June 2015 - 09:19 PM.
  • KeithC and gfstallin like this
#14 kt4hx
kt4hx
Posted 19 June 2015 - 10:52 PM
Thanks Bill, looking forward to your visual review.  Something like that might work well with my 60mm f/15 Jason refractor!
#15 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 20 June 2015 - 10:35 AM
Maybe they'll make the cover of BillP's new edition......really liked the original cover design that got cut.
#16 BillP
BillP
Posted 20 June 2015 - 01:10 PM
White light solar, binoviewing in the TSA was fantastic.  The AFOV is wide enough at this ling focal length that there was still some vignetting of the AFOV with the WO Binoviewers.  Also occurred with the 20mm 70 degree AFOV Meade RG Wide Fields, but not as bad as with those.  So with the 23mm Aspherics the field stop still visible just dimming before you get there.  With the RGs the field stop was not there to be seen in the WO Binos.
Trying to examine the FOV was a little tricky with white light solar, but appears right now that the field curvature was also there like it was in the 80mm f/6.25.  It could all be focused out with a 1/4 turn of the fine focus knob for a sharp sunspot at the field stop.
So used them at native 23mm (35x) and with the 1.6x OCA (57x) in the TSA.  Sun Spot details etched and mesmerizing.  I have to say that white light solar I think is so much more interesting than Hydrogen Alpha like with my PST.  The details in and around the sun spots, and watching them change and morph in real time is just incredible with white light...especially in a 100mm scope.
Anyway, these make a great $18 bino set of eyepieces for white light solar...and they weigh zero! :lol:
  • CollinofAlabama, KeithC, mwedel and 6 others like this
#17 Alvin See
Alvin See
  • Loc: Singapore
Posted 20 June 2015 - 09:47 PM
Bill, beware of the plastic housing melting under the sun!
#18 BillP
BillP
Posted 20 June 2015 - 09:50 PM
Not a chance of that happening!  I use a full aperture solar filter. :grin:
And again...the sun spot views they put up today were so detailed and memorable.  White light solar can be simply amazing!
Edited by BillP, 20 June 2015 - 09:51 PM.
  • Terra Nova and AndresEsteban like this
#19 Alvin See
Alvin See
  • Loc: Singapore
Posted 20 June 2015 - 11:58 PM
I meant melting from sun light hitting the housing and eye lens from the outside ... which is possible at where I'm at! :)
  • gfstallin and TiSaph like this
#20 Alvin See
Alvin See
  • Loc: Singapore
Posted 20 June 2015 - 11:59 PM
There was a guy here who left a Hyperion under the sun for a while ... and the eye lens cracked!
  • gnowellsct and gfstallin like this
#21 BillP
BillP
Posted 21 June 2015 - 11:08 AM
I can understand a lens cracking as stuff left in sun, especially dark colored, can reach 150 degrees F.  At that temp cemented glass is undergoing lots of stress.  Most plastics will not melt at that low of a temp; LDPE (low-density polyethylene) is a common consumer plastic and melts at about the lowest temp, which is just over 200 degrees F.  I think in order to actually cause a melt the sun would have to be going through a lens in the eyepiece and the converging rays of course can get very hot.  But just sitting in the sun with lens caps on doubtful I would think.  Plastics are a rather large family of compounds so can't generalize.  One of the more temperature resistant varieties needs over 500 degrees F to melt.
  • Roger Corbett likes this
#22 BillP
BillP
Posted 21 June 2015 - 02:00 PM
FWIW, the sunspot group I have been observing for the past few days with the 23 Aspherics is AR 2367 (http://www.astrobin.com/full/188709/0/).  Seeing about the level of detail in the pic if not a little more, and a more etched view as well.  Quite spectacular.
  • sopticals likes this
#23 BillP
BillP
Posted 22 June 2015 - 09:31 AM
Final comments on this eyepiece...
23mm Aspheric 62 degree No-Name or Celestron
Price
$9 (ebay) direct from China
Construction
Inexpensive construction.  So cheap but not the worst I have see.  Housing is a plastic material, top of housing is rubberized to protect eyeglasses, barrel is aluminum.  Optics are in the housing so the threading and retaining rings are all plastic as well.  There is no field stop so the barrel is used as the field stop.  Overall a very light eyepiece.
Optics
This is a 1-2 design.  The eye lens singlet is non-glass and aspheric.  Based on reflection off the surface it is also coated. Edges are not blackened.  However, this lens fits into a black retaining ring prior to insert into the housing.
The field lens glass doublet with a strongly convex field lens face and a lightly convex interior facing face.  Edges are blackened.
Performance
For daytime use it provided a nicely sharp and high contrast view in an 80mm f/6.25 Apo.  View was sharp across the field except for the region close to the field stop.  Primary off-axis issue for daytime use appeared to be field curvature (from the eyepiece or the scope).  Eye relief was generous and long enough that no contact with the eyepiece housing was necessary.  AFOV, although not quantitatively measured, was compared to other eyepieces and was easily in the 60-62 degree range.
For daytime white light solar viewing I used a TSA-102 f/8 Apo with WO Binoviewers.
White light solar viewing was excellent.  Sunspots were perfectly crisp and highly detailed.  As good of a view in white light solar as with any other eyepiece of any quality level.  Only issue was vignetting at edge of field in the f/8 scope, indistinct field stop due to use of barrel as field stop.  With disk of sun in center of the FOV the entire solar disk was crisp and resolute.  Crispness of the view only suffered in the outer most portion of the FOV nearer the field stop when the Sun drifted to the field stop.
For night time use used a TSA-102 f/8 Apo.
In the longer f/8 scope the field stop showed vignetting and a less than distinct edge.  This was probably due to the eyepiece using the barrel for a field stop.  I do not recall this behavior in the faster f/6.25 scope.  But quite obvious in the f/8.
Eyepiece was very sharp with excellent apparent contrast in the central 75% of the FOV.  At approximately 25% from the field stop very slight astigmatism and Field Curvature (FC) began.  FC was dominant and stars could be refocused to nice points until the star reached perhaps 10-15% from the field stop.  At that point astigmatism became the more predominant issue.
With Barlow (TV 2x, 2.8x Klee) the AFOV seemed to become a little restricted and again the off-axis remained vingnetted in appearance with an indistinct field stop.  However, it provided very crisp and nicely contrasted views.  Lunar viewing was superb.
As far as light artifacts only one was noted.  When a bright object was right at the field stop there would be a reflect off a component that appeared as a light just outside the field stop.  It was very minor though and not distracting.  Would happen if a bright star was right at the field stop or the Moon was at the field stop.  The interior FOV background remained dark with no light artifacts present throughout its use.
No lateral color was noted in any of the tests.
Overall Assessment
It is a $9 eyepiece so hard to fault anything for that price.  Performance was actually incredible for the price and given only a 3 element eyepiece.  If a field stop is inserted this would have been a much more pleasant eyepiece to use, with little faults.  And if the AFOV were restricted to 55 degrees it's performance would have been excellent!  So it has the potential with a little ATMing to be quite a find and also an excellent outreach eyepiece.
The use of plastic retaining rings and threads in the housing is of course the downfall for the eyepiece and will limit its life if disassembled too many times as stressing the threads will happen.  As far as the non-glass eye lens, I am going to have no judgment on it as performance of the eyepiece in the central 75% of the FOV was excellent.  Obviously the use of an aspheric allows this low lens count eyepiece to work exceedingly well.  My only question would be on the longevity of the eye lens after continued cleaning.  But if the coating used provides a hard enough surface, this may not be an issue.
Overall a very inexpensive build, with a matching price, but with performance well above its build and price characteristics.  For $9, certainly fun to have one in the box :grin:
  • Tom T, Jaimo!, mwedel and 11 others like this
#24 Sarkikos
Sarkikos
  • Loc: Right Coast of the Chesapeake Bay
Posted 22 June 2015 - 10:44 AM
We can count in Bill to go where no man has gone before...  :)
I think that was another Bill...
:grin:
  • doctordub, EuropaWill and precaud like this
#25 Peter Besenbruch
Peter Besenbruch
  • Loc: Oahu
Posted 22 June 2015 - 01:26 PM
I just rejiggered my eyepieces with some cheap ones. Now I have to start all over again. ;)
