"Up until the Edmund, I didn't think any mid-size achro could please me as much as my old D&G 5" f/10. I was wrong."
"Optical Quality. The Carton lens holds steady at 100x / inch (my personal high-quality standard)."- BB
I would agree that the Edmund optics are Excellent. Even impeccable in my opinion. I don't think they come much better. Optically my Edmund 4" F15 lens is very good, running neck and neck in optical performance with my older Unitron 4" F15. I would be hard pressed to pick a winner between them. (They are both of similar vintage ~1960 +/- 2 or so years.) Even so, 100X per inch is a bit over exhuberant, with human eyes and an earth atmosphere, even under the best of conditions. If you do the math, that yields an exit pupil of 0.25mm. My maximum useful magnification was 60X/inch under excellent atmospheric conditions with my younger eyes. Now I typically max out at around 40 or 50X per inch. The skies aren't what they were and neither are my eyes, but even so, I think 50X per inch (an exit pupil of .5mm) is a much more realistic limit for most any person, and most any telescope, even with perfect optics and perfect seeing. Beyond that, you are simply magnifying floaters in the eyes, dust and turbulence in the atmosphere, over a dimmer image. The key, is not in boosting the magnification to beyond useful limits, but instead, in increasing your observing time and concentration on a single object. While the former (increasing magnification) is a mental trick that might deceive you into thinking you are seeing more when you are not, the latter (what I call "visual stacking" after the imaging term), is a very useful mental trick of storing quality images in your brain to build up an overall better view of what you are looking at.
http://www.skyandtel...a-pupil-primer/
Edited by terraclarke, 17 June 2015 - 12:00 PM.
