Finally a week later we had clear skies. Temps were below 80F and humidity briefly below 50%. The seeing was poor for the first two hours after sunset. The bright moon didn't help.
I took the dob out around twilight. Trees obscured the moon and planets. My only observing window is northeast to east.
Collimated with Glatter laser and Tublug. Verified with older version Catseye Cheshire and autocollimator (new tools on order)
Installed viewing assembly: Siebert OCS, TV Binovue with Siebert diopters, pair 30mm Ultimas.
First target was Vega. Able to focus (whew! - how many times I've tried a binoviewer scope combo and it didn't focus) The left and right didn't focus together. A little fiddling took care of that. No sign of miscollimated eyepieces. I did have problems from the exit pupil (my astigmatism) a little vignetting, and a little coma at the edge. The OCS is not used with the Paracorr.
Next I tried 24 Pans. Much better presentation from the wider apparent field and reduced astigmatism. 16 and 11 Naglere followed. Targets included Beta Lyr, T Lyr, M57, M13, Albireo, Blinking Planetary, IC 4996, and the rich background of the Cygnus Milky Way. I'm pretty sure I saw Chi Cygni also.
On M13 I compared the 16 T5's versus 13E + Paracorr. The Ethos provided a wide field and slightly brighter view. The BV view was a little dimmer, but not objectionable. There was no loss of details, no aberrations, the stars were round except at the edge where coma took over.
The moon transited a gap in the trees so I had about 10 blinding minutes of moon. Despite the poor seeing the moon reveals a wealth of detail. For example a triple point of light: the top of the central peak in Vieta, and the morning sun on either side of the peak's shadow. Saturn was too low to be visible.
I'm very pleased with the Siebert OCS after last night. I want to test it under dark skies and better conditions. I wish it accepted 2" filters. There's a big difference in using the TV 2x amplifier and the 1.3x OCS. It's nice to have both options available.
