If you are using a 4X barlow on a C14 that means you're working at about f/40 which is really too much magnification for the ASI120 camera (3.75 micron pixel size). A 2X barlow will easily give you the critical sampling that you need and that will also result in a two stop decrease in the required exposure times.
However, that still doesn't explain (fully) why your exposure times are so long so there must be something else happen here.
The other thing that seems a little odd is that there seems to be a lot of flare or haze in the image (screen shot) that you provided. Could it be that you had a very heavy dew on the front corrector of the telescope?
Yes, f44+ is far too much for the C14 which is an f11 scope at native...thus f44 even if the barlow has no extension between it & the camera sensor: you really need to get down to below 2X with any amplification!
But as James has said that doesn't explain your dilemma tbh - that haze around the planet looks very suspicious! I wouldn't expect to see any haze from a fogged-up corrector - well, we certainly never see this & it happens all the time when we image...the histogram drops off, but no haze etc.
Try looking down at the primary mirror in daylight to see your secondary in the primary mirror's reflections...recently we had a secondary which had become completely dewed over due to moisture getting inside the OTA...that is about all I can suggest atm...
EDIT: ps, you set the gamma at "50" for capturing & you don't need 50% histograms for Saturn with the 120MM...
Edited by Kokatha man, 08 July 2015 - 07:32 AM.
