Magnitude Reach with short exposure - survey
48 replies to this topic
#26 A. Viegas
A. Viegas
Posted 30 August 2015 - 07:45 AM
Conditions were not very good last night, full moon, and thin clouds.  But I gave this challenge a try with my C11 and MCX icx418 class 0 at F4.4
The MCX has a gain setting, and typically I use half-way or AGC4.  With the skyglow I had to use a filter or else I would get the image washed out.  In order to not use a filter I had to lower the AGC to 2. Similarly, to meet the requirements of the OP and see just how fast you can get to Mag 14 or better, I tried using max AGC or AGC8.  But with the sky conditions, and even with using my astronomik UHC filter the best I could get was 8s exposure before we got washed out...   see below:
NGC 6910 - 8s exposure using AGC8... & UHC filter (max gain).  Easily gets to 14 mag
ngc6910 agc8 Uhc 9s
NGC 6910  10s exposure using AGC4 & IR filter  (usual setting) - can detect the 14 mag stars, but not as easy
ngc6910 agc4 IR 10s
NGC  6910 10s exposure using AGC2 NO Filter (1/4 gain) - 13 mag visible, 14 mag not easy to detect
ngc6910 agc2 10sMcx
Al
#27 MartinMeredith
MartinMeredith
Posted 02 September 2015 - 08:50 AM
This is a 10s exposure of NGC 6910 from last night at 36 deg N with the Lodestar X2 mono coupled to a Skywatcher Quattro 8" f/4 alt-az mounted Newtonian. SQM 19.5 (86% moon at 5 deg elevation); shot through a Baader C (clear) filter and captured with LodestarLive.
Martin
Edited by MartinMeredith, 02 September 2015 - 08:54 AM.
#28 nytecam
nytecam
  • In Memoriam
Posted 02 September 2015 - 09:08 AM
I think you win Martin but what is the faintest star recorded?
I'm guessing m17.15 via Wikisky away from the core near the bottom edge but it's not very reliable near nebulae and N6910 is in the middle of a diffuse nebula ;-(
Nytecam
Edited by nytecam, 02 September 2015 - 09:37 AM.
#29 MartinMeredith
MartinMeredith
Posted 02 September 2015 - 09:29 AM
I'm hoping there will be more entries...
Here's a chart with stars down to mag 20 from the PPMXL catalogue in case it helps.
Attached File  NGC6910.pdf   86.42KB   49 downloads
Martin
#30 Dragon Man
Dragon Man
Posted 02 September 2015 - 10:41 AM
attachicon.gifNGC6910.pdf
Martin
Here ya go Martin.
I found a few in your image down to Mag 19  :waytogo:
#31 MartinMeredith
MartinMeredith
Posted 02 September 2015 - 11:36 AM
Thanks Ken, but I'm guessing that the original chart provided is V mags while the bulk of those in PPMXL are B if I recall correctly, so some correction will be required. It is worth checking how well the PPMXL mags correspond to the V chart. At some point I'll try to plot these mags to one d.p. on the chart too, though spotting the correspondences is a lot of fun ;-)
Martin
#32 Censustaker
Censustaker
Posted 02 September 2015 - 06:09 PM
What's the difference between V mags and B mags?
#33 MartinMeredith
MartinMeredith
Posted 03 September 2015 - 02:04 AM
The V magnitude is computed over the central part of the visible range of frequencies while B is computed over the blue range (see for example this filter set or this page on Photometric systems for an exhaustive list of passbands used in photometry). V and B are not in general equal but which is larger will depend on star colour, roughly speaking.
Martin
#34 nytecam
nytecam
  • In Memoriam
Posted 03 September 2015 - 02:23 AM
Also Google 'colour index' for an explanation.  V mags are rarely used by pros as traditionally the plates of 100yrs ago were blue sensitive (B mag) and most of the star types via temperature etc can be deduced via spectroscopy in the blue region.  Although modern detectors like CCDs are more sensitive to red/NIR the system has never been rescinded.
Nytecam
#35 mclewis1
mclewis1
    Thread Killer
Posted 03 September 2015 - 09:34 AM
And the sensors we're using for much of our EAA work are quite sensitive in the blue range making objects that are brighter in the B values seem substantially easier to see than what the published V values might first indicate.
I've seen this where folks crow about being able to view very faint Hickson objects that actually appear at least a magnitude brighter than the traditionally published values because of the camera used.
#36 MartinMeredith
MartinMeredith
Posted 03 September 2015 - 10:14 AM
This plot shows the locations of the B and V band centres relative to the spectral response of the camera I used, showing that it is significantly more sensitive in the V region.
Sources: http://www.sxccd.com/lodestar-x2-autoguider ; https://en.wikipedia...tometric_system
Martin
#37 MartinMeredith
MartinMeredith
Posted 03 September 2015 - 11:15 AM
Regarding NGC 6910, according to this article the mean B-V for the cluster is just over 1, meaning that on average the mag 19 (B) stars detected correspond to mag 18 (V). A couple of caveats:
(i) for each individual star, one would need to know its spectral class (or equivalently have a measurement in another band) to apply the appropriate correction. For example, any blue stars labelled as mag 19 have a V magnitude larger than 19. Since the majority of stars are at the other end of the spectrum, as it were, it is more likely that the V magnitude is smaller than the B magnitude (also shown by the colour excess B-V quoted).
(ii) the magnitudes plotted on the chart are rounded to integers.
So based on these points, it seems reasonable to say that most mag 19 stars detected are likely to have a V mag between 17 and 18.5.
Martin
#38 Censustaker
Censustaker
Posted 03 September 2015 - 07:31 PM
Thank you all for the explanations!
#39 GlennLeDrew
GlennLeDrew
Posted 04 September 2015 - 10:40 PM
A slightly bluish, white star such as Vega, which has a B-V of 0.0, has the same V and B magnitude.
A random star not significantly suffering interstellar extinction is expected to have a B-V of about 0.6, meaning the V magnitude is brighter than B by 0.6m.
The discrepancy between B and V magnitudes depends also on the presence of interstellar extinction, which is generally strongest near the galactic equator due to the flattened system of dark molecular clouds. And NGC 6910 is almost exactly on the glacic equator, and moreover lies in a region of quite notable fairly nearby dark clouds which make up the Great Rift.
As noted, the mean B-V for the cluster is a little larger than 1 magnitude, which for such a young and hence bluish object implies that this color excess is due almost entirely to extinction and reddening. This cluster is comparatively nearby. As we look to ever fainter stars in the field, some will most likely be even more distant non-members, and hence probably even more strongly dimmed by the greater optical depth of interstellar dust. It could be the case that some such distant stars could be suffering a color excess of 2, or 3, or 5 magnitudes, if not more. And so a B magnitude will be fainter than a V magnitude by that amount.
Incidentally, a color excess of 1 magnitude is a total visual extinction of about 3.1 magnitudes. In the absence of the intervening dusty clouds, NGC 6910 would otherwise be a bit more than 3 magnitudes brighter.
#40 Daniel Mounsey
Daniel Mounsey
    Vendor (Woodland Hills)
Posted 04 September 2015 - 11:46 PM
What is YOUR magnitude reach?  How deep can your scope/camera combination go in a 10 second, single frame?
I'm hoping to comply here some data to compare apertures and cameras with a standardized exposure of 10 seconds.  No stacking, please, just a single shot.  Hold off on the post-processing as well, please.
Tell us what camera you are using, scope, aperture and the condition of the sky, etc.
The targets are NGC 6910 and NGC 7031, both conveniently situated in Cygnus.   Magnitude data from Roger N. Clark's excellent (and long out of print) Visual Astronomy of the Deep Sky  will be used to get your image's approximate limiting magnitude.    The diagrams are below.  Mention your limiting magnitude based upon the diagrams....
Let the games begin!
Dave
Dave,
Great post! This is a fantastic test! I'll have to give this a go when possible. Lot's of factors to consider of course. :D
#41 A. Viegas
A. Viegas
Posted 05 September 2015 - 08:22 AM
Here is an image of NGC 6910  I took last night using my DSO-1 a $99 camera and my C80ED  (80mm refractor)
There is no 10s  exposure, so I set it at X512 which is 8s - so close enough and I could get down to almost 15mag.   Not too bad and pretty impressive in mag per $...   hmmm  $99/Mag 15 = $6.6 dollars per mag...    Lodestar X2 is what $600?  Thats $600/19  or almost $32 dollars per mag  :lol:    Tonight if I get a chance I will put the DSO-1 on the 8"  bet I can get close to mag19 too...
Al
Edited by A. Viegas, 05 September 2015 - 08:23 AM.
#42 mclewis1
mclewis1
    Thread Killer
Posted 05 September 2015 - 08:42 AM
Al,
That certainly is very impressive, and the price/performance king too ... lol.
What are your skies like? (pretty good if I remember the images from your NSN broadcasts)
I was curious what the little Sony sensors could do ... what are you using for a frame grabber?
I'm assuming that you used the C80ED natively (no focal reducer)?
I've been meaning to try out my SCTs natively in this test. I think I might also dust off a refractor to try.
Another thought is to go up in image scale (Barlow) and use a more sensitive camera (In my case that would be an MC Xtreme vs. the Skyraider AGm), the different cameras used at different focal lengths would highlight the trade off between image scale and resolution/star quality.
#43 A. Viegas
A. Viegas
Posted 05 September 2015 - 08:56 AM
Hi Mark
This location is 70 miles north of Manhattan, so although its not THE CITY, it is still suburban and orange skies.  I am using a Dazzle 100 and this shot was done at native or F6.5 I think it is 600mm I believe.
I tried this same target with my MCX icx418 class 0 and I think I got down to like Mag 17 or so, but not quite as good as the Lodestar X2 which got down to Mag 19, see image below.  This of course suggests my old MCX is not as sensitive or as good on price performance, $1499/17 =  $88/mag  ( Ouch!! )   AND I was using the C11 at F5 ish...  so in this regard again the cheapo camera is a big winner and the more expensive older generation icx418 MCX is not that great in terms of $ per mag performance.
Al
Edited by A. Viegas, 05 September 2015 - 08:57 AM.
#44 jgraham
jgraham
Posted 05 September 2015 - 02:06 PM
NGC 6910 – Open Cluster in Cygnus, Single 10s Frame
Telescope: Meade SN10, Orion Atlas EQ-G
Camera: Baader Modified Canon 550D (Rebel T2i)
Filter: Orion Imaging Skyglow Filter
Guide scope: None
Exposure: 1x10sec, ISO 3200 saved as RAW
Darks: Internal (Long Exposure Noise Reduction On)
Flat: None
Average Light Pollution: Red zone, Very poor transparency
White Balance: In-camera using a sky reference frame
Software: Backyard EOS, Photoshop (cropping and annotation only)
This is a single source frame without any processing. The RAW image was converted to TIFF using Digital Photo Professional. The image was cropped and labeled in Photoshop. No levels, no curves, no adjustments of any kind. I did use the in-camera darks and color balance, which is part of my normal EAA routine. I may have a chance to do better than this tonight. On this particular evening the humidity was very high and the transparency was about as bad as it gets, but it was the best that we’ve had in the past week. The limiting magnitude is well below the chart that we are using as a reference.
#45 jgraham
jgraham
Posted 05 September 2015 - 02:07 PM
NGC 7031 – Open Cluster in Cygnus, Single 10s Frame
Guide scope: None
Flat: None
This is a single source frame without any processing. The RAW image was converted to TIFF using Digital Photo Professional. The image was cropped and labeled in Photoshop. No levels, no curves, no adjustments of any kind. I did use the in-camera darks and color balance, which is part of my normal EAA routine. I may have a chance to do better than this tonight. On this particular evening the humidity was very high and the transparency was about as bad as it gets, but it was the best that we’ve had in the past week. The limiting magnitude is at least 16.1. Note that the star on the reference chart given as 17.2 is not visible.
#46 nytecam
nytecam
  • In Memoriam
Posted 06 September 2015 - 04:09 AM
Here's my annotated effort from last night - both fields reaching the limiting V magnitudes [and fainter!] than the charts above. Used my Meade LX 200 30cm f/3.27 SCT+SX Lodestar-Cx2 colour camera - no filters used in 10s exp.
Whilst on the 10s 'thingy' I shot planetaries M27/M57/NGC6781 and NGC40 + M71 globular.
10s gallery = http://www.cloudynig...3-10s-exp-pics/
Amazing what 10s exp will reveal ;-)
Nytecam
Edited by nytecam, 06 September 2015 - 04:30 AM.
#47 MartinMeredith
MartinMeredith
Posted 06 September 2015 - 11:07 AM
Based on this article, and given some scope data (aperture, central obstruction if any) camera data (mean quantum efficiency in relevant band, read noise, pixel size, dark current), it is possible to compute a limiting magnitude for a given exposure length and sky conditions. What the approach actually does is provide the signal-to-noise ratio (SNR) for a given target magnitude, so it is necessary to choose at what SNR you consider an object to be detectable. Let's use a value of 3.
For the Lodestar X2 mono and my scope, it turns out that this is the case for a mag 17.35 target in mag 19.5 skies in 10s, assuming a FWHM of 2.5. This ties in pretty well with Maurice's analysis of my result. The benefit of the modelling approach is that it can answer questions such as: what would happen if I increased exposure to 100s (answer: mag 18.6) or if my skies were say 18.5 instead of 19.5 (answer: mag 16.8).
Martin
#48 mclewis1
mclewis1
    Thread Killer
Posted 06 September 2015 - 01:08 PM
Martin, Awwww your spoiling all the fun!  :lol:
Seriously, thank you for the article, that's a very interesting read.
#49 Stargazer3236
Stargazer3236
Posted 26 May 2016 - 02:10 PM
Here is an image I took of M57, reversed the color to get a black on white image. I Googled Photometry of the region around M57 and added the star mags. I used a ZWO ASI224MC camera and a Nexstar 6SE.
