This morning 10/25/2015 6-7AM(cloudy) 7-7:30AM I observered 1.1deg apart Venus/Jupiter (3 moons) and Mars (closest this pass) in the same view with FAAC’s 100mm right angle binos Orion/Vixen Tripod, and both my 9x63 and 15x63 Orion mini-giant binos on Garret pistol grip monopod with quick connect L brackets. I was set up on the sidewalk in front of a neighbor’s house who had a clear view to the East (and who previously said it was OK for me to observe there in the early morning). I was prepared to set up my 17.5” dob with binoviewers and single eyepieces, but the cloudy weather and wide field required to fit all 3 planets in same FOV favored binos today.
9x63mm Orion Mini-giant binos (5.0 deg TFOV, 7.0mm exit pupil, 26mm eye relief):
*Venus/Jupiter(3moons) in same 1.1 deg view plus Mars in same best view of morning, plus I also had the bonus of a meteorite passing through the triplet! – (1:30 o’clock) Venus appeared as very bright white medium size half phase (really crescent) with (12 o’clock) bright small/medium yellow Jupiter (bands not noticeable) and 3 moons in line (one close half diameter below, two far - one and 3 diameters away above). Small starlike orange Mars at bottom left (6:30'clock) with a binary-like parallel star on the edge of view at 7 o’clock. Jupiter/Venus also were the short parallel side of a trapezoid/trapezium with two stars forming the other parallel side at 11:30 o’clock 30/60 deg angle and 1 o’clock 20/70 deg angle on edge of view. All 3 parallel line segments (Venus/Jupiter/2star trapezoid/trapezium & Mars/star) fit in the same single awesome field of view, and I observe this great view most of the visible morning. Even when the orange dawn/twilight sky masked Mars’ light, I could still see Mars and the other stars in the bino FOV before I started to pack up).
*Orion Belt/Sword(M42 glow unfiltered)
15x63mm Orion Mini-giant binos (3.7 deg TFOV, 4.5mm exit pupil, 19mm eye relief):
*Venus/Jupiter(3moons) and two stars formed trapezoid/trapezium in same 1.1 deg view with 30% margin! Venus appeared lower right as very bright white medium/large size half phase (really crescent) with lower left bright small/medium yellow Jupiter (bands not noticeable) and 3 moons in line (one close half diameter below, two far - one and 3 diameters away above). Jupiter/Venus were the short parallel side of a trapezoid/trapezium and the other two stars formed the longer parallel side angled 30/60 deg angle on the Jupiter side and 20/70 deg angle on the Venus side. Easy Pan to Mars one field of view down and slightly to the left (slightly more left than using the Venus side of the trapezoid 4x the distance). Mars also has a star to the left parallel to and a quarter the distance of the Jupiter/Venus short side (trapezoid/traspezium).
*Mars/star – Very Small orange orb Mars easy to pan up and slightly to the right to the Venus/Jupiter/2star trapezoid/trapezium.
100mm 90deg right angle Orion binos w/ 24mm 68 AFOV Panoptic eyepieces (?? deg TFOV, ??mm exit pupil, ??mm eye relief):
*Venus/Jupiter(3moons) and two stars formed trapezoid/trapezium barely in same 1.1 deg view for second best view of morning! Venus appeared lower right as very bright white medium/large size half phase (really crescent) with lower left bright medium yellow Jupiter (bands not noticeable???) and 3 moons in line (one close half diameter below, two far - one and 3 diameters away above). Jupiter/Venus were the short parallel side of a trapezoid/trapezium and the other two stars formed the longer parallel side angled 30/60 deg angle on the Jupiter side and 20/70 deg angle on the Venus side (on edge of view). Easy Pan to Mars 3-4 field of view down and slightly to the left (slightly more left than using the Venus side of the trapezoid 4x the distance). Also it would drift from Jupiter/Venus to Mars in the center after a few minutes observing with the other binos, so I never really had to refind the planets! Mars also has a star to the left parallel to and a quarter the distance of the Jupiter/Venus short side (trapezoid/trapezium).
*Mars/star – Small orange orb Mars easy to pan up and slightly to the right to the Venus/Jupiter/2star trapezoid/trapezium.
100mm 90deg right angle Orion binos w/ 21 LOA 3D Denkmeier 21mm 68 AFOV eyepieces (?? deg TFOV, ??mm exit pupil, ??mm eye relief) – Note Denkmeier does not recommend for (non-DSO) planets but I attempted anyway:
*Venus/Jupiter(3moons) and one star of trapezoid/trapezium barely in same 1.1 deg non-3D view. Venus appeared lower right as very bright white medium/large size half phase (really crescent) with lower left bright medium yellow Jupiter (bands not noticeable???) and 3 moons in line (one close half diameter below, two far - one and 3 diameters away above). Jupiter/Venus were the short parallel side of a trapezoid/trapezium and the other two stars formed the longer parallel side angled 30/60 deg angle on the Jupiter side and had to pan to the upper right for the 20/70 deg angle on the Venus side (beyond edge of view). Pan to Mars 4-5 field of view down and slightly to the left. Mars also has a star to the left parallel to and a quarter the distance of the Jupiter/Venus short side (trapezoid/trapezium). Note only noticed the trapezium and 3 parallel lines in the other wider binos.
*Mars/star non-3D – Small orange orb Mars easy to pan up and slightly to the right to the Venus/Jupiter/2star trapezoid/trapezium.
P.S Most likely same equipment will work just as well tomorrow, but I do have to go to work.
Ken
Edited by faackanders2, 25 October 2015 - 01:20 PM.
