It seems like most beginners worry too much about the clips impinging upon the mirror's surtface and the subsequent diffraction. This effect is so small that the additional diffraction will be very hard to find in a visual telescope.
When I was building my Definitive Newtonian Reflector (see below) this diffraction was a different story as I was trying to eliminate any diffraction that could be gotten rid of.
I came up with a solution that can be applied to any mirror clip. I use double-faced foam tape to fasten the mirror to the mirror cell. As for those vlips that creep up on the sides of the mirror, I did this: I filed off the top of the clip so that there was no impinging "bend" that would normally cause that small amount of extra diffraction. I applied some of that same tape to the sides of the clip and then applied it to the mirror. A little tightening of the screw that tightens the clip causes it to rest against the side of the mirror.
It is a firm hold but not one so tight that the mirror's figure would be effected. And yet, I've held a mirror in its cell upside-down with no danger of anything shaking loose! I think that's pretty good.
For any normal Newtonian, I would avoid doing anything except to use the clips to hold the mirror in place in a normal fashion. The extra diffraction caused by these clips is so minimal that it is not worth the trouble, unless one wants to be a crank and build a Newtonian that will equal the performance of an apochromatic refractor of equal aperture, namely me.
My article cited below is now being refereed by an optical journal, so we'll see what's what.
