Binoviewers Supercharging Service
180 replies to this topic
#76 denis0007dl
denis0007dl
    Binoviewers Expert
  • Loc: Umag, Croatia, Europe
Posted 04 May 2016 - 02:24 AM
I Supercharge only binoviewers!
Kind regards and CS
Denis
#77 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 21 May 2016 - 03:45 AM
Here is how looks like correction glass on Arcturus and simillar binoviewers, unblackened edge....
  • AndresEsteban likes this
#78 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 21 May 2016 - 03:46 AM
....and here is same correction glass when blackened in Supercharge service....
  • Procyon, nicknacknock, AndresEsteban and 1 other like this
#79 mgtroyas
mgtroyas
  • Loc: Spain
Posted 29 May 2016 - 03:29 AM
Hi, I recently had my Arcturus binoviewers supercharged by Denis (probably last photos are from mine!) and just wanted to comment the proccess was very fast, and openings on all sides are now bigger with a great craftmanship. I've tested them quickly by day and now they are perfectly collimated, and light gathering and vignetting seem much better, waiting for  next week for real testing. Denis has done a great job, I recommend his service.
Edited by mgtroyas, 29 May 2016 - 03:31 AM.
  • Live_Steam_Mad, Procyon, silv and 3 others like this
#80 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 31 May 2016 - 03:27 AM
Hi Marcos,
yes, exactly, pictures in posts #77 and #78 are taken from your binoviewer in process of Supercharge.
I am happy you are satisfied, and wish you to enjoy using now your improved binoviewer.
Kind regards and all best
CS
Denis
#81 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 13 June 2016 - 05:15 PM
Here is example of Supercharged and modified Carl Zeiss binoviewer.
Now, it have full 25mm CA instead 23-24mm orginally, and it is fully suitable for astronomy use.
Also, all prisms are additionally blackened.
#82 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 29 June 2016 - 06:26 AM
Here is TeleVue BinoVue before and after Supercharge some pictures shown....
#83 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 01 July 2016 - 10:58 AM
Let me introduce
Supercharge Service of Denkmeier Denk I, Denk II, and Denk DeepSky, and simillar binoviewers:
Upper prism, beamsplitter and correction glass are 26mm in diametrer.
Inside bino, Clear Aperture is limited to 24mm only.
After Supercharge you get full Clear Aperture of 26mm on each side of bino!
So it means you will have almost none vignetting when using Panoptics 24mm, Explore Scientific 24mm 68 degrees and simillar eyepeices.
CS
Denis
Edited by denis0007dl, 01 July 2016 - 11:03 AM.
#84 AndresEsteban
AndresEsteban
  • Loc: Rio de Janeiro, Brazil
Posted 18 July 2016 - 05:33 PM
I would like to take a moment to state that Denis and I have resolved our issue. I would like to thank Denis for stepping up.
Un gesto gentil de ambas partes merece ser reconocido siempre: acuerdo de caballeros!
A kind gesture from both parts always deserves to be recognized: Gentlemen's deal!
I'm happy that both of you could settle this problem!
We need the craftmanship Denis has to improve our equipment, not many people out there like him!
Regards
Andy
#85 EV1970VE
EV1970VE
  • Loc: Ontario, Canada
Posted 23 July 2016 - 09:32 PM
I purchased a supercharged Baader Mark V Binoviewer from Denis. It arrived from Croatia to Canada in just under 10 days. The supercharge service Denis performed is absolutely first rate. Widening of the field stops in the eyepiece holders and nosepiece, blackening of the prism edges and blackening of the nose ring is done in a manner that seems factory quality. It's definitely not a hack job. Now I can't comment on improved performance over a standard Mark V because I've never looked through one and don't have access to one to do a direct A - B comparison. All I can attest to is the supercharge service looking professional grade. I've only had the binoviewer for a few days and have had it out just a couple of times. No complaints with the performance, the views are beautiful. Thanks Denis!
  • Live_Steam_Mad likes this
#86 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 28 July 2016 - 11:40 AM
Here is one more TS Supercharged and modified binoviewer, with newest design back T2 INOX adapter, with same T2 connection design which have Baader Mark V binoviewer, so it is compatibile with Baader Quick Changer adapters.
Now openings on all sides are FULL 25mm of Clear Apertures!
Edited by denis0007dl, 28 July 2016 - 11:41 AM.
  • nicknacknock and dagadget like this
#87 faackanders2
faackanders2
Posted 30 July 2016 - 12:43 PM
Would you really notice a difference of only 1mm (~4%) diameter change from 27-28mm?
#88 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 30 July 2016 - 02:19 PM
Hardly to none.
Its all about vignetting on edges, and just bit better illuminated spot area. You actually get max of optics you can get.
Edited by denis0007dl, 30 July 2016 - 02:21 PM.
#89 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 14 August 2016 - 09:07 AM
Supercharging Siebert Black Night binoviewer
Thats Sieberet binoviewer with beamsplitter and upper prism in diameter 22.5mm, and 22mm in diameter of correction glass.
Clear Apertures are as follow in original setup:
---22.5mm CA on left eyepeice side
---20mm CA on right eyepeice side (limited by inner side)
---22.5mm CA on telescope side
After Supercharge you get:
---22mm CA on right eyepeice side
Beamsplitter and upper prism are not bleckened, while correction glass it is.
I do blackening both beamsplitter and upper prism as shown in photos.
  • silv likes this
#90 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 14 August 2016 - 09:16 AM
---right eyepeice upper side before Supercharge have 21mm CA, and after Supercharge full 22mm CA.
#91 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 14 August 2016 - 09:25 AM
---right eyepeice inner side have 20mm CA, and after Supercharge full 22mm CA.
#92 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 14 August 2016 - 09:28 AM
---beamsplitter and upper prism not blackened in original setup, and same items in process of Supercharge are finally cleaned and blackened.
Edited by denis0007dl, 14 August 2016 - 09:48 AM.
  • silv likes this
#93 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 21 August 2016 - 03:07 AM
Supercharge Service of Siebert Echelon 40 binoviewers
HUGE binoviewer, and biggest binoviewer in serial production made with all prisms!
It have HUGE 40mm in diameter beamsplitter, cube design.
Next to beamsplitter, Siebert use errecting prism 34mm in diameter, to reflect light from beamsplitter to right eyepeice side.
So, Siebert here does not use correcting cylindricall type of glass which is common in all prism design binoviewers.
He get same results here.
Light from beamsplitter which goes striaght, incoming in 34mm in diameter errecting prism, and after again in 34mm in diameter errecting prism which reflect light to left eyepiece side. (two prisms here, and same results at the end like any other prism design binoviewer).
Clear Aperture on telescope side is 38mm, and can be Supercharged to 39.4mm.
Clear Aperture on right eyepeice side is 28mm, and can be Supercharged to 31.5mm.
Clear Aperture on right eyepeice side is 30mm, and can be Supercharged to 31.5mm.
CS
Denis, binoviewers expert
Edited by nicknacknock, 01 September 2016 - 02:34 AM.
  • Procyon likes this
#94 Waldemar
Waldemar
  • Loc: Netherlands
Posted 05 September 2016 - 09:51 AM
I just got my bino's back from Denis:  what a surprise..it's like Christmas!!
Had my eye on a Baader Mark V, but they were not available until further notice. To me that means a looong waiting time.
Denis offered me an alternative so I bought a black Zeiss super bino from him and had it supercharged right away.
Also send him a maltreated secondhand MaxBright bino, which was in a really bad shape and far out of collimation. He collimated and supercharged that one too.
As I said: today my bino's arrived and I was totally overwhelmed when I saw them. Especialy the Zeiss is just awesome. It looks like the Baader Mark V, but beautifull black. I am glad now the Baaders were not available!
I have not been able to test them, yet (Murphy, the atronomers patron) but will a.s.a.p. and leave a comment here.
I can only say the work Denis does is absolutely superb. My experience with him and our communication was nothing less then unbelievable. This does not happen that often...
So a great thank you to Denis for his fantastic work and the great deal he gave me!
Waldemar
  • silv and denis0007dl like this
#95 Pingster
Pingster
Posted 05 September 2016 - 10:38 AM
I am waiting for work to be done on my WO and i will also be getting a black zeiss bino from him.
Looking at your photos has got me truely excited. It looks beautiful. Even better than picture he had sent me to show me what it looks like.
#96 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 05 September 2016 - 11:16 AM
Be patient Pingster, you will get your pocket soon :)
#97 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 08 September 2016 - 02:22 PM
More Supercharge Service infos:
VERNONSCOPE binoviewers!
These are very expensive binos, whole made from metal, and built like a tank!
With Supercharge you get:
***24.5mm Clear Aperture on left eyepeice side, vs originally limited 22mm
***24mm Clear Aperture on rifgt eyepeice side, vs originally limited 22mm
***24.5mm Clear Aperture on back/telescope side, vs originally limited 22mm
Eyepeice holders are BEST I ever used in bino world, self centring, and very precise. I like them most of all holders existable!
Light transmittion is very very high, with excellent transparency.
Bino suffer like most binos from polarisation effect.
All in all, this in ONLY bino IMO which stays very tight head by head vs premium and worldbest Carl Zeiss binoviewers!
There are 2 versions of these binos: one have 1 set screw on each eyepeice side, and second have like this on post self centring eyepeice holders.
P.S. this is my modification with T2 INOX custom made adapter scope connection, and blackened middle plate.
  • Pingster likes this
#98 Pingster
Pingster
Posted 11 September 2016 - 05:17 PM
Hey Denis. Do you know what is the reason some binoviewers have no polaraisation, some, & lots of polarization? What is different about the internal design that makes the result?
#99 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 12 September 2016 - 03:11 AM
Hi Pingster,
polarisatioin cause property of a different material having a different refractive index of material.
#100 junomike
junomike
  • Loc: Ontario
Posted 12 September 2016 - 08:07 PM
Denis, I think he may have also  been asking the reason manufactures incorporated the Polarization effect into the design.
My understanding was it was an easy way to get the 3D effect in the "early years"......
