Binoviewers Supercharging Service
192 replies to this topic
#176 denis0007dl
denis0007dl
    Binoviewers Expert
  • Loc: Umag, Croatia, Europe
Posted 05 November 2018 - 01:36 AM
Denis, having had several Bino Vue units... What benefit would the Baader EP holders provide compared to the original TV splined collets? IME, they're effortlessly adjustable for sliding in/out for "diopter" tweaking, actually have a permanent diopter setting (at least one side - both sides on earliest models), are lighter weight, etc. What is, in your opinion, the advantage of that mod?
Hi slack,
main advantage is much shorter light path.
Even with installed Baader ClickLock eyepiece holders you save 7mm backfocus,
while if you install Baader Ultrashort eyepiece holders from link
https://www.teleskop...--T2-Clamp.html
you save much more light path.
Next advantage of T2 system is universality, which allow users to use on one side camera etc, and on other side you can use eyepeice, or any other combination you want who support T2 system.
#177 Starry Messenger
Starry Messenger
  • In Memoriam
  • Loc: Central Vermont
Posted 05 January 2019 - 07:39 PM
Would a new Denkmeier Binotron-27 need supercharging, or would it be possible to enhance these binoviewers thru supercharging? Please explain. Thank you.
Ronald Lewis
Green Mountain Astronomers
#178 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 06 January 2019 - 09:41 AM
Hi Ronald, yes, its possible to do it.
Dont know what you mean enhance.
#179 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 25 July 2019 - 12:48 PM
Supercharged Carl Zeiss binoviewer - 30mm prisms - Signature Series -
#180 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 25 July 2019 - 12:58 PM
Supercharged Carl Zeiss/Vernonscope binoviewer - Signature Series -
Limited Edition/Quantities made/modified by me!
 Same binoviewer model as selling under name Vernonscope, with added (custom made) many advantages as follow:
- added aluminium T2 eyepeice holder plates
- possible to change/switch eyepiece holders/astro camera
- added T2 bayonet on telescope side (compatibile with Baader Quick Changer system)
- added feature to accepts Baader Glass Path Correctors (just screw them on back side of binoviewer body)
 Specifications:
- high quality all metal design of binobody
- easy collimation possible
- high quality all glass inside made from German Schott glass
- precisely polished all glass surfaces
- high light transmittion
- prisms diameter is 24.5mm
- 24.5mm Clear Aperture (SUPERCHARGED), instead 22mm Clear Aperture originally on left eyepeice side
- 24mm Clear Aperture (SUPERCHARGED), instead 22mm Clear Aperture originally on right eyepeice side
- 24.5mm Clear Aperture (SUPERCHARGED), instead 22mm Clear Aperture originally on telescope side
- NO ANNOYING POLARISATION EFFECT LIKE COMMON BINOVIEWERS HAVE
- T2 bayonet connection on the telescope side, which originally accepts Baader Glass Path Correctors
- IPD: from 55mm to 75mm
- light path: 11.5cm with included Baader ClickLock eyepeice holders
- weight: 650 grams with all included equipment
  • Live_Steam_Mad and Pinac like this
#181 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 31 March 2020 - 04:19 AM
I am still doing Supercharge Service, cleaning, collimation, IPD tension adjustment etc on your binoviewers, all for tottal 100 USD only!
Because custom import rules, I am able to do it all that for European customers!
All best,
Denis, binoviewers expert
#182 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 22 September 2020 - 09:25 AM
Supercharged Leitz Wetzlar best binoviewer.
Thats best and largest binoviewer made by Leitz Wetzlar company, Supercharged and tottaly modified by me.
Weight of 1368 grams (yes, super heavy, but metals used are high quality, and no plastic parts like many nowdays binoviewers have).
Light path 12.2cm at IPD 67mm.
Supercharged from 23mm CA to 26.5mm CA.
More about it you can check here
https://www.cloudyni...wer/?p=10510656
Kind regards
CS
  • Pinac likes this
#183 junomike
junomike
  • Loc: Ontario
Posted 25 September 2020 - 06:10 PM
Is it for sale Denis (I'm content with my TV's for now, just curious).
#184 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 26 September 2020 - 02:32 PM
Hello Mike, I sent you PM
#185 ASTROFINE
ASTROFINE
  • Loc: UNITED KINGDOM
Posted 29 December 2020 - 06:35 PM
Hi Denis and happy xmas,
 I deaf so my english will not be that good, just easy english,
My bino is Baader mark V , so far it must be over 12 years old and its fab,  first time ever i just clean the glasses , now looks great clean and colimates allways  looks fine to me, so my normal eyepieces clamp is okay ??
I notices for ages right side is 26mm diameter like you said so can you just open up bigger just on the right side only ? or you can tell me,
  i bet it will it be worth it because i did put 5 x powermate with 20mm eyespieces in one at a time and the left side 28mm hole is brighter than the very dull right side 26mm hole !
and how much please ?
Kind regards
Henry
  • denis0007dl likes this
#186 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 30 December 2020 - 02:16 PM
Kind regards
Henry
Hi Henry,
28mm is max what I can do, becasue cylindrical glass is 28mm in dimeter, so cant be bigger!
100 Euros include Supercharge, Cleaning, and Collimation.
Shipping item back to you is 25 Euros.
Kind reagrds
CS
Denis
#187 ASTROFINE
ASTROFINE
Posted 30 December 2020 - 03:32 PM
Okay thanks Denis,    will try post to you around Feb to Marsh  2021, will let you know when through your email.
Regards
Henry
#188 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 30 December 2020 - 06:45 PM
  • ASTROFINE likes this
#189 Redek
Redek
  • Loc: Tbilisi, Georgia
Posted 28 October 2022 - 10:49 AM
Hi Denis, just curious how do you unscrew this part? I have exactly the same binoviewer and I want to replace it with something else, but I can`t understand how to remove it. I found only two small screws inside but it seems like their role is to change prisms position. Thx.
#190 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 04 November 2022 - 06:00 AM
Hello Redek, these eyepiece holders are glued with super strong glue...
I was able some dissasamble by using heat, but some not.
Hope it helps.
Kind regards
Denis
#191 Redek
Redek
Posted 04 November 2022 - 06:25 AM
Hope it helps.
Kind regards
Denis
wow, unexpectedly. Many thx! you warned me against breaking my binoviewer
#192 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 04 November 2022 - 09:54 AM
You are welcome!
Yes, its very tricky job, and you can very easily break bino due process....
Kind regards
Denis
#193 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 20 May 2023 - 06:38 AM
Binoviewers Supercharging, Collimation, and Cleaning, new price is 200 Euros.
Its possible only for EU customers unfortunatly due customs issues here in my country only, so if you can ship your binoviewer from any EU country, excellent.
Kind regards,
Denis
