Review for the Celestron 102mm AZ refractor
This scope is not a widely sold scope, but was available a large wholesaler during this year's pre-Christmas sales. The overall boxing was not very large but neatly contained all of the packaging. The telescope package is separated in 3 boxes. The head and tripod fully assembled and the spreader tray in the largest box. The OTA in the second largest box, and the small square box contained the 10mm and 20mm lens, the diagonal, a small tool for removing the battery compartment cover and the battery to power the red dot finder.
The boxes suffice for sale but you will defiantly need to repackage the scope and tripod for travel. The boxes are fairly flimsy.
The mount
Assembly
It was fairly simple to remove the AZ mount and setup. Just spread the tripod legs and extend to the required height. Please note the height is not terribly high so tall users may encounter discomfort. The spreader bar was plastic and honestly seemed to be an afterthought in terms of quality. The lightness of the mount makes this far better for grass than concrete or smoother surfaces as nudge can move it a bit easily.
Pros
For its price it’s not half bad. It’s a bit light, but for the OTA that comes with it, it services it. Motion with default accessories is alright. Very quick to setup and its excellent if you want to quickly set up for a viewing.
Cons.
Once you want to use a quality eyepiece and diagonal, you will see the flaws with the mount. Balancing issues test the ease of motion and introduces sagging when settling on a target. Don't get me wrong, its alot better that some of the bargain scope mounts out there. Build quality is decent and finished surprisingly well. Motion is where the mount suffers. It can be a bit uneven depending on the accuracy of motion. Large sweeps are great but fine tweaks aren't so fine.
The OTA
At 102mm f/6 this is a surprising character.
Cons
Let’s get the bad stuff out. I personally hate zero magnification finders. Some do...but not me. Personal preference perhaps but as wide field as this scope is, getting dead center even with the dot can be tricky. Could be positioning but the default position leaves the dot not very useful to me.
The dovetail plate. What the hell were they thinking? Its too far up for correct balancing and to short to meaningfully correct the balancing. Get rings and you will find life easier.
Finally the focuser is not horrible, I have used worse. The back focus tube has a bit of play. I am not sure if it’s a construction issue.
The dewsheild is kind if glossy as well as the tube area in front of the objective. So stray light becomes an issue.
Pros
Even with all these flaws, is an excellent OTA
Even as a achromatic, the color fringing is kept under control. It’s present for really bright targets but visually it’s not very bad.
The construction is decent and feels fairly solid. Interior is alright in terms of baffling and for photography is fairly adequate.
Eyepieces.
Not terrible but you will quickly want better eyepieces for sure because of the weak optics. The diagonal is fairly ok for daytime but for night viewing i felt it was not so great in terms of light transmission. I compare it to the regular 1.25" diagonal and it felt brighter.
Recommendations for this scope
Tripod
Get a better one is the easiest answer but I would actually recommend it for quick grab and go. A spreader lower down would help.
The OTA can be excellent. But it needs help.
First, rings will make positioning of the dovetail significantly better for balancing. Second, a better focuser probably will make fine focusing better. Finally baffling the dewshield and the area in front of the OTA will make life better in terms of reflections.
First light.
I tried on planets and was pleasantly surprised the fringing really was not disastrous. Venus was difficult though. Jupiter was small but magnificent. At 8mm on a 8-24mm I was shocked how well it held up. Saturn was too low to reliably detail quality.
For DSOs it’s a beast. Getting past the red dot finder, objects in the field of view looked very very nice. And as a challenge i pushed the limit of clarity by checking the target as it rose from the horizon. The Orion nebula showed up well less than 5 degrees above the horizon!
I am happy with the scope and with initial modifications (baffling) its a very promising scope. Not bad Celestron!
