More Edmund Scientific!
505 replies to this topic
#476 John Rogers
John Rogers
Posted 01 March 2020 - 01:10 PM
Here are some more photos detailing the Deluxe Optical Alignment Telescope:
Infinity focus position:
Minimum focus (20-inches):
Telescope diameter:
Weight:
Edited by John Rogers, 01 March 2020 - 01:15 PM.
  • BillB9430, clamchip, Terra Nova and 3 others like this
#477 Bob Myler
Bob Myler
  • Loc: Davisville, MO
Posted 01 March 2020 - 05:44 PM
John, PM sent.....
#478 apfever
apfever
  • Loc: Colorado
Posted 01 March 2020 - 07:30 PM
The older ones like my 5/8” shaft Edmund GEM from 1966 used sawed off nails set in drill holes in 5/8” shaft collars for the setting circle indicators. They weren’t tapped and threaded, just pushed into slightly smaller drill holes.
I had some of those here. I thought there would still be one at least but found nothing. It is a little thinner so I could even inventory what's here. I had a few of those nail versions but none in the concrete room. I know I had more than one nail type at one time but nothing so I don't know.
  • Terra Nova likes this
#479 John Rogers
John Rogers
Posted 03 March 2020 - 05:25 PM
You can easily pick out the Moonscope finder (deluxe finder for the 8 inch in the early years)  in the pictures above.  The newer deluxe finder is slightly longer.
The eyepiece on the left below is the Kellner that came with the later model.  The middle eyepiece is the same Kellner without the eyeguard and the eyepiece on the right is the original Erfle with helical focuser that came with the Moonscope.
PawPaw,
Is the OD of the 30mm Kellner larger than 2" or has it been reduced to 2.0"
#480 PawPaw
PawPaw
  • Loc: West Central Missouri
Posted 04 March 2020 - 08:56 AM
PawPaw,
John...Am out of town when I get home will check.   I know they milled down the kellner a small amount to fit in the Auxillary scope.
  • John Rogers likes this
#481 apfever
apfever
  • Loc: Colorado
Posted 04 March 2020 - 03:24 PM
I get some issues keeping track, see if this helps, found this Edmund labeled box trying to get some scope work done that doesn't get done. It's probably nudged around but not really moved in a year or so and no vouching for before that. I just found it getting other pictures.
#482 apfever
apfever
  • Loc: Colorado
Posted 04 March 2020 - 03:26 PM
inside,  Edmund inventory soon. I can now get a summation I think.
  • mattyfatz, steve t, deepwoods1 and 4 others like this
#483 PawPaw
PawPaw
Posted 08 March 2020 - 10:33 AM
Good day to start out with an Edmund......I was surprised the Voyager fit the tripod made for their diminutive 3 inch reflector.  I just had to squeeze the forks together slightly. Now I can setup quickly and have an adjustable mount.
  • mattyfatz, John Rogers, clamchip and 6 others like this
#484 Defenderslideguitar
Defenderslideguitar
  • Loc: Connecticut
Posted 12 March 2020 - 09:05 AM
the little 63mm Voyager has quite the lens     just amazing what it shows
  • Joe1950 likes this
#485 PawPaw
PawPaw
Posted 12 March 2020 - 09:18 AM
I always thought it would make a good photo guide scope.  Designed by Dr David Rank the objective is actually 63.5mm  F/8 with a nice bright field of view.  I believe the objective is still offered by Edmund Optics.
  • Bomber Bob, Joe1950 and Defenderslideguitar like this
#486 Defenderslideguitar
Defenderslideguitar
  • Loc: Connecticut
Posted 12 March 2020 - 10:43 AM
just starting to use the one I got 5 weeks ago...   it is so sharp  and It is so easy to use
  the other night I picked it up off the car hood  and held it in my hand like a rifle scope and I was able to see M42 spectacularly...
p.s.     The Edmund red color has really grown on me
Edited by Defenderslideguitar, 12 March 2020 - 11:14 AM.
  • mattyfatz, clamchip, Terra Nova and 3 others like this
#487 apfever
apfever
  • Loc: Colorado
Posted 12 March 2020 - 01:18 PM
I'm no longer doing a lot of documenting like this any more but it was all here so all the boxes open and out again.  Edmund bought Anchor right around 1958, just up front of the new Edmund grey pier line up. Here's the group, Anchor in black, the thick circles on left, and the nail pointers in the box.
  • mattyfatz, Bomber Bob and Defenderslideguitar like this
#488 apfever
apfever
  • Loc: Colorado
Posted 12 March 2020 - 01:19 PM
had two photos, a little more angle on this one.
  • mattyfatz, astro140, Terra Nova and 1 other like this
#489 mattyfatz
mattyfatz
  • Loc: Boise Idaho
Posted 15 March 2020 - 10:31 AM
Great telescope. I had one for a while, and ended up selling it to a guy in Alaska. Big mistake. It's pretty much why I don't sell scopes anymore.
the thing that bugged me was that table top mount. It looked great but it functioned poorly. No zenith? Come on!
Edmund Voyager 6001
Edited by mattyfatz, 15 March 2020 - 10:34 AM.
  • Terra Nova, PawPaw, Bomber Bob and 1 other like this
#490 Terra Nova
Terra Nova
  • Loc: Under the Blue Moon of Kentucky
Posted 15 March 2020 - 11:45 AM
It definitely deserves a better mount. A Unitron 114 alt-az mount would be perfect!
  • mattyfatz and Bomber Bob like this
#491 mattyfatz
mattyfatz
  • Loc: Boise Idaho
Posted 15 March 2020 - 12:03 PM
I always thought that Mayflower Fork Alt-Az would be a good match too. You get to keep the fork- mount asthtetics that way.
#492 davidmcgo
davidmcgo
  • Loc: San Diego, CA
Posted 15 March 2020 - 12:23 PM
I bought a Vixen rail that has a couple of threaded 1/4x20 holes and drilled two holes to attach my Voyager where it screws to the cradle. Used a bit of the fuzzy side of velcro to pad where it contacts the tube.  But mostly I just use the tabletop fork.
Dave
Edited by davidmcgo, 15 March 2020 - 12:24 PM.
#493 Terra Nova
Terra Nova
Posted 15 March 2020 - 12:48 PM
That would be cool but would the tube fit? The Edmund looks like a larger diameter.
  • mattyfatz likes this
#494 PawPaw
PawPaw
Posted 15 March 2020 - 12:57 PM
Check post # 483 above.  You find these mounts now and then and it works both as an Altaz and a crude equitorial.
#495 Terra Nova
Terra Nova
Posted 19 March 2020 - 08:57 AM
If you re-read my comment, you will see that it concerns a comment specifically about the Mayflower model 814 fork mount which has a built-in clamshell, not the Edmund fork. The reason being, that the Mayflower tubes (like RAO, HOC, and Swift 839 tubes) were smaller in diameter than for example Unitron, Takahashi, Zeiss, and N-K tubes. The Edmund Voyager appears to use a bigger tube. If so, the Mayflower mount’s clamshell wouldn’t fit.
Edited by Terra Nova, 19 March 2020 - 10:49 AM.
  • PawPaw likes this
#496 AstroKerr
AstroKerr
Posted 22 March 2020 - 03:22 PM
Had this rather odd, grainy 8mm sepia image form in my head of you scurrying about in bathrobe and slippers, opening boxes and posing mounts, AP. You appeared quite intent.
Like the 'praying mantis' look in #483.
Like your 'dark' look, Terra. Makes me feel 'cringey' - nice, very nice.
I may have caused some confusion (imagine that!).  This is my Edmund 4" refractor's mount & tripod (with the pre-restored Mogey 3 riding on it):
The mount I posted earlier was a pass-through that I bought mainly to get the WWI military tripod & hub.  It was advertised as an Edmund, but the seller didn't know for sure...
Nice mount, JayDubyah - functional, slow-hand simplicity. Worth plaigerizing in a contemp form.
Be well, please.
#497 clamchip
clamchip
  • Loc: Seattle
Posted 31 March 2020 - 07:33 PM
A little on the Edmund Scientific Factory Store:
http://www.sjthings....-factory-store/
Robert
  • Eric P, John Rogers, Pete W and 4 others like this
#498 clamchip
clamchip
  • Loc: Seattle
Posted 23 May 2020 - 06:12 PM
When I search 'Edmund Scientific' I have seen this title before.
I decided to take a closer look.
This booklet was actually written by Norm Edmund as a retirement project:
https://www.ebay.com...EIAAOSwIWBeyMvv
I'm going to find a less expensive copy and read it, sounds interesting.
Robert
  • Terra Nova and PawPaw like this
#499 clamchip
clamchip
  • Loc: Seattle
Posted 23 May 2020 - 06:33 PM
I stumbled across Norm's obituary with much said about Mr. Edmund's
life outside of Edmund Scientific:
https://www.legacy.c...d&pid=155525030
Robert
Edited by clamchip, 23 May 2020 - 06:34 PM.
  • Vesper818, Pete W, steve t and 2 others like this
#500 Terra Nova
Terra Nova
Posted 23 May 2020 - 07:13 PM
Life was never quite the same without dear old Edmund Scientific, those wonderful black-and-white newsprint almanac-sized catalogs, and of course, all those wonderful toys. I wonder if Bruce Wayne shopped there? :question:
  • clamchip and steve t like this
