Atik Infinity Color Camera - Initial Impressions
143 replies to this topic
#76 JonNPR
JonNPR
Posted 10 January 2016 - 03:37 AM
Beautiful! These are with your C11, right?
#77 kuba_mysluk
kuba_mysluk
Posted 10 January 2016 - 05:58 AM
Hiten,
Thanks for all work You done for us.
Your pics are pretty awesome,  hope will have same results in the future.
Im still waiting for delivery of my Infinity
Kuba
#78 Astrojedi
Astrojedi
Posted 10 January 2016 - 10:53 AM
Thanks Jon. All images in this thread are with my Evo C8.
#79 Astrojedi
Astrojedi
Hiten,
Kuba
Thanks Kuba.
#80 glennshiller
glennshiller
Posted 10 January 2016 - 06:31 PM
Why would you buy a 414 at $1500 when you can buy an infinity for $500 less.  You don't need the cooling with the low noise infinity.  Please explain this.
#81 Astrojedi
Astrojedi
Posted 10 January 2016 - 07:22 PM
Cooling starts to become relevant if you are doing exposures longer than 2-3 minutes due to dark current accumulation. If you think your sub exposures will be less than 2 minutes then the Infinity fits the bill otherwise get the 414.
Some folks also want to use the camera for astrophotography along with EAA in which case the cooled 414ex makes more sense due to the same reason.
#82 DSO_Viewer
DSO_Viewer
Posted 10 January 2016 - 08:36 PM
Hilten, I would hope that the exposures would be under 2 minutes for EAA Observing if not then why not just get into CCD imaging :lol: . Honestly waiting beyond 2 minutes to see an object would either put me to sleep or drastically limit the amount of objects that I could view on a single clear night, so it sounds to me like my buddy who does imaging and is lucky to capture a couple of images for the night.
#83 kuba_mysluk
kuba_mysluk
Posted 11 January 2016 - 11:29 AM
Do anyone tried how Infinity works with binning 2x2? Had to be similar to older cameras with significant shorter exposition.
#84 JMW
JMW
Posted 11 January 2016 - 03:26 PM
I think you would give up color in the process of binning pixels.
#85 JonNPR
JonNPR
Posted 11 January 2016 - 04:03 PM
Shakes head in appreciation.
And with any luck, anticipation.
#86 kuba_mysluk
kuba_mysluk
Posted 11 January 2016 - 04:28 PM
Ahhh yes, of course You are right.
#87 Astrojedi
Astrojedi
Posted 11 January 2016 - 05:40 PM
Also binning on the color sensor will not produce the same sensitivity or resolution as on the mono sensor due to the Bayer matrix.
#88 kuba_mysluk
kuba_mysluk
Posted 12 January 2016 - 04:59 AM
Know it, but from the theory only :) still waiting for delivery of my Infinity.
#89 Astrojedi
Astrojedi
Posted 12 January 2016 - 11:58 AM
 I tried it and I can confirm : )
#90 kuba_mysluk
kuba_mysluk
Posted 12 January 2016 - 12:28 PM
Should be better if I will trust You :)
Can You say a word about Your reducer setup used for last photos from C8 F4.3 ? Type, distances... I still looking for it, Your stars look pretty good.
#91 DonBoy
DonBoy
Posted 12 January 2016 - 12:34 PM
In Fire Capture I'm able to view in color 2x binning of ASI224 in the Preview window but images outputted are b&w.
#92 Astrojedi
Astrojedi
Posted 12 January 2016 - 12:48 PM
Kuba was talking about the Infinity. When using binning with the 224 I get color but I see little or no increase in sensitivity. I don't think the ASI224 does HW (charge domain) binning but maybe Sam can confirm.
Edited by Astrojedi, 12 January 2016 - 12:55 PM.
#93 Astrojedi
Astrojedi
Posted 12 January 2016 - 12:52 PM
I used a Meade 3.3 focal reducer at f4.3. I think the 825 sensors will produce least aberrations with a focal reducer at f4.5 or slower. To image at faster than f4.5 either you have to accept and live with vignetting and some coma around the edges or get a hyperstar which allows you to image at f2. But at f2 with a C8 your image scale will not permit viewing/imaging of smaller DSOs.
#94 DonBoy
DonBoy
Posted 12 January 2016 - 12:56 PM
Kuba was talking about the Infinity. When using binning with the 224 I get color but I see little or no increase in sensitivity. I don't think the ASI224 does HW binning but maybe Sam can confirm.
You will see a sensitivity difference with the HW Bin either checked or unchecked, I don't remember which way it should be.
#95 Astrojedi
Astrojedi
Posted 12 January 2016 - 12:58 PM
Only if the camera supports HW binning otherwise it is just adding pixels together. I have not experienced any real sensitivity increase with binning on the 224 (edit: based on photometric analysis I did).
Edited by Astrojedi, 12 January 2016 - 01:01 PM.
#96 kuba_mysluk
kuba_mysluk
Posted 12 January 2016 - 04:08 PM
Maybe I can catch Meade 3.3 from second hand.
For now: my local shop have Celestron and AlanGee, can borrow AG and try to play with spacers, they also have all extenders from Baader system. Hope can find "sweet spot" for my SCT 9.25 XLT.
#97 Carlscope
Carlscope
Posted 13 January 2016 - 06:13 AM
Hi all heres a video just on you tube showing the binning being used when moving to target and some nice views with the infinity.
https://www.youtube....h?v=LvUpQl7EeyQ
Carl
#98 roelb
roelb
Posted 13 January 2016 - 05:53 PM
Carl
What are the telescope / focal ratio / ... specifications?
#99 Astrojedi
Astrojedi
Posted 13 January 2016 - 07:18 PM
I believe they have a C14+Hyperstar
#100 saguaro
saguaro
Posted 14 January 2016 - 08:15 AM
Carl
Thanks for posting the video!
Which display monitor do you use for your live views in the observatory? Thanks.
