ASI 178MM Cool - testing
5 replies to this topic
#1 PiotrM
PiotrM
Posted 13 January 2016 - 06:00 PM
I got the ASI178MM Cool - mono cooled IMX178. Tested in home with FireCapture and Nebulosity4 and it seems to work nicely.
FireCapture bin1:
FireCapture bin2:
- Dark frame - 1min x 20 at -10C, lowest read noise preset, Nebulosity 4
- Bias frame - around 300 frames, -10C, lowest read noise preset, Nebulosity 4 (it's not a flat, bad filename ;))
- bin 1 image - lowest read noise preset, Nebulosity 4, 16mm C-mount lens
- bin 2 image - lowest read noise preset, Nebulosity 4, 16mm C-mount lens
The ASCOM driver has also "unity gain" and "highest dynamic range" presets, but offset/gain etc. can be set as you wish.
Edited by PiotrM, 13 January 2016 - 06:01 PM.
#2 aaube
aaube
Posted 15 January 2016 - 10:27 PM
If you ever get the chance, could you test it for solar Imaging, preferably Ha ?
Alain
Edited by aaube, 15 January 2016 - 10:30 PM.
#3 PiotrM
PiotrM
Posted 15 January 2016 - 10:44 PM
At the moment I don't have a solar telescope, but in general Sony sensors work correctly ;)
#4 aaube
aaube
Posted 15 January 2016 - 11:04 PM
No problem, thanks!
Alain
#5 easybob95
easybob95
Posted 16 January 2016 - 09:24 AM
Hello Piotr,
i am a bit disappointed with the dark and flat pictures.
The ampglow is there, maybe less then IMX224 sensor, but it is not very very good for a cooled brand new camera. I am wondering if the treatment will be so easy to do with that ampglow (which must not be always the same i suppose). I will be very hard to manage and maybe it will be difficult to make dark bank.
There is also a lot of dead pixels (maybe it is normal, i don't know).
The masterbias is also not very good. I expected better result.We can still see the FPN.
Maybe i expected too much with those new sensors.
Alain
#6 PiotrM
PiotrM
Posted 16 January 2016 - 12:24 PM
This is first-generation of multipurpose cooled cameras. The prices end just below prices for cameras like Atik 314L+ and the performance point is similar - just bit below. But still I'll see what I can do for DS imaging with it. Key object for all those pixels is the Moon. Slightly better performance than IMX174 - for planets.
But still people did super DS images with those type of Sony sensors and it's just matter of processing how much you can get from them.
